Revit OpEd: Alternate Units - Part Two
    A few comments in yesterday's post made me aware of a couple perspectives I had not given enough fair play in my mind. Thanks for the comments and the attitude adjustment. Just to repeat myself, I'm not opposed to showing alternate units or defending Revit's lack of the concept. I'm all for Autodesk making alternate dimensions a priority for documenting in Revit. Hopefully it will happen sooner than later.
    One comment asked about using a dimension style that uses "no lines". I exaggerated, it does use the dimension line but that will overlap the other so it is "invisible". A video will help see how I apply it and these two dialog boxes will show what settings I used. Hope it helps...a little.
    Setting the Type Parameters:
    Setting the Units (from within Type Parameters):
    Here's the VIDEO and the version at You Tube:
