RFO Blog: How to set up a connection between Revit and Microsoft Access, via DBLink
    The following instructions describe how to set up a connection between Autodesk Revit and Microsoft Access, via DBLink, using the specs of hardware and software mentioned below (this information might be useful for other specifications as well).
    Hardware & Operating system:
    Intel i5 , 4 gb RAM & Windows 7 Professional 64 bit
    Software:
    • Revit Architecture 2012
    • Microsoft Access 2010 (* see note at the end of this page for other versions)
    • Autodesk Revit DBLink for 2012.
    Downloads:
    • From the Subscription Center, from the list of Product Enhancements, download "Autodesk Revit DBLink for 2012", from this link:
    http://subscription.autodesk.com/sp/...74&id=14499814
    Steps:
    • Once you have downloaded and installed DBLink, the next time you open Revit, there will be a new tool, named as "External Tools" > "Revit DBlink" in a tab named as "Add-Ins" on the ribbon.
    • Open a project, for example the "rac_basic_sample_project.rvt"
    • Do: Add-Ins > External Tools > Revit DB Link.
    • From the "Link Revit Model with Database" dialog box, from the ODBC tab, select "Select a new connection" and click on "Export".
    • From the "Select Data Source" dialog box, click on "New".
    • From the "Create Data Source" select "Microsoft Access driver" and click "Next.
    • From the "Create New Data Source" dialog box, provide a name for the connection, such as "My connection". Click "Next".
    • From the "Create New Data Source" dialog box, click "Next".
    • From the "ODBC Microsoft Access Setup" dialog box, click on "Create".
    • In the "New Database" dialog box, type the name of a new database, such as "my sample project", and specify the path where you want the file to be created. It will be created as a ".mdb" file. Click OK.
    • There should be a confirmation letting you know that the file was created successfully. Click OK.
    • Back into the "ODBC Microsoft Access Setup" dialog box , click OK.
    • Here is something strange: I always get an error message, saying that "The file data source was not saved". Just click OK to that message.
    • Back into the "Select Data Source" dialog box, browse or scroll to the right until you find your "My connection.dsn" file, and click OK.
    • Back into the "ODBC Microsoft Access Setup" dialog box, click OK (again!)
    • There will be a window on the screen, entitled "Link Revit Model with Database". It will begin linking... after a few seconds it will say "(Not responding)" Don't panic, just wait... it is working... actually, you now have an Access file (my sample project.mdb) with all the data.
    • From the ribbon, click again on "External Tools > Revit DBLink".
    • From the "Link Revit model with database" dialog box, from the ODBC tab, select your connection, that should be now on the list, and click on "Edit and import".
    • After a few seconds, you will see a big window, named as "Edit Database before Import", from where you could see all the data of the model, in database format.
    Comments
    The process for setting up this connection definitely has some flaws. I did this using the latest and greatest in hardware and software, and I still got some strange errors, that should not have happened. Anyway, if you follow the steps described above, DBLink will be now up and running. Finally!
    Note:
    * If you don't have Microsoft Access 2010, but other previous versions, you need to download and install the proper drivers from Microsoft, either 32 or 64 bits, from this link:
    http://www.microsoft.com/download/en...ng=en&id=13255
    Posted in the Revitforum blog by Alfredo Medina on June 25, 2011
    To follow up comments about this topic in this forum, please refer to this other thread.
    Don´t want to see the Blog Posts on the forum? Just [url="http://revitforum.org/profile.php?do=addlist&userlist=ignore&u=2540"clic k here[/url] to add the Blog Fetcher to your Ignore List
