Revit ST: Excitech Revit Toolkit - Coordinates 2012
    The Excitech Revit Toolkit - Coordinates is now available for download for Revit 2012.
    The Excitech Revit Toolkit is a set of utilities developed and published by Excitech to enhance the benefits you get from Revit technology.
    The Revit toolkit contains a modular installation utility that makes additional utilities easy to add in and manage.
    The first tool released is for Coordinate Scheduling.
    Revit Coordinate Scheduling Tool
    The FREE Excitech Revit Coordinate Scheduling application is a powerful tool for Revit Architecture, Revit Structure and Revit MEP that will enable users to automatically acquire precise X, Y and Z coordinates from certain Revit objects.
    This allows users to more rapidly produce schedules of, for example, piling and services; as well as to publish coordinates for complex geometry across 3D space.
    The coordinates are added to the objects element properties which will allow schedules to be generated and tags to be placed.
    The application has been designed to publish X,Y and Z coordinates to selected object categories and store these within the objects instance properties.
    To maintain the accuracy of the coordinates the Excitech Revit Coordinate Scheduling Tool has the following built-in checks which will prompt the user when performing one of the below operations.
    •Viewing Schedule Tables
    •Printing
    •Saving Documents
    •Saving As
    •Opening a document
    •Exporting a file
    •Closing Documents
    •Synchronising with the Central File
    You can download the toolkit
    here
    Don´t want to see the Blog Posts on the forum? Just [url="http://revitforum.org/profile.php?do=addlist&userlist=ignore&u=2540"clic k here[/url] to add the Blog Fetcher to your Ignore List
