Revit OpEd: Which Phase Filter?
    There are several phase filters that stock templates come with. Sometimes people aren't certain which ones to use or why they exist. There are three options that affect how elements are influenced by Phase Filters: By Category, Overridden and Not Displayed.
    By Category - Project Object Styles and/or view's Visibility/Graphics Overrides govern.
    Overridden - Revit will change the appearance of elements based on the Phase Graphics Overrides settings (see next image). Note that a Filter (View not Phase) applied to a view can still influence an element affected by a Phase Filter.
    Not Displayed - Yes, this means elements are not displayed in the view.
    What does it take for Revit to regard an element as being New, Existing, Demolished or Temporary? It varies according to the Phase of the view we see it in and which Phase Created and Phase Demolished parameters values are assigned to it. The following conditions define which Phase Status an element belongs to in a given view. For the following images assume this view is assigned to Phase New Construction and that we are looking at the Phasing parameters of four different walls.
    New - Element's Phase Created parameter is assigned to the phase of this view and the Phase Demolished parameter is set to None.
    Existing - Element's Phase Created parameter is assigned to an earlier phase than the phase of this view and the Phase Demolished parameter is set to None.
    Demolished - Element's Phase Created parameter is assigned to an earlier phase than the phase of this view AND its Phase Demolished parameter is assigned to the same Phase as this view.
    Temporary - Element's Phase Created parameter is the same phase as this view AND its Phase Demolished parameter is also assigned to the same phase as this view.
    Any given element can belong to one of these four Phase Status in any given view according to the Phase parameter of that view AND its own Phase Created and Phased Demolished parameter settings. Phase graphics depend entirely on creating views for each appropriate phase and creating elements so they are assigned to the correct phase and then altered so their Phase Demolished parameters are assigned as required, if required.
    Getting to the title of this post finally, each view has a Phase Filter parameter. What follows is my take on why I'd use each of the stock Phase Filters.
    None - It's not a Phase Filter in the dialog, it's a choice in the list of Phase Filters within a view's properties. We use this when we don't want any Phase settings to affect the elements in the view. Everything is displayed according to either Object Styles or Visibility/Graphics Overrides.
    Show All = This filter can't be altered or deleted. It means show us everything WITH Phase graphic alterations applied. NEW elements are governed by Object Styles (or possibly Visibility Graphics overrides) AND it overrides Existing, Demolished and Temporary elements. Use this filter to help see everything mixed together AND altered so each Phase Status is obvious. It is NOT a typical way of producing traditional documents but it CAN help explain relationships very well.
    Show Completed = We're done! We don't want to see any graphical bias toward new or existing work, they should look the same. We don't want to see any demolished or temporary elements. We want to use this to show the finished design after construction is done. We could think of it as a view of "As Built" conditions if the model is kept current through construction.
    Show Previous and New = We want to show new construction information in context against existing features but without Demolished or Temporary elements. This is ideal for New Construction views.
    Show Previous and Demo = This is the filter to use for typical demolition documentation, existing features altered to show where demolition occurs. New work and Temporary work are not shown.
    Show New Only = This is useful when we want to give a hint of future work. We can isolate and override graphics in a view to prepare a view for overlaying over another view on a sheet. When we overlay this on top of a new construction plan we'll see how they relate to each other despite the fact that Revit has no "future" phase.
    Don't be fazed by phasing!
