Using Reporting dimensions in Revit Family
    I am working on some irregular triangle windows and would like to calculate the glazed area. However, I can not seems to use reporting dimension in the formula. This error msg keep popping up :
    A reporting parameter can be used in a formula only if its dimension references are all to host elements in family.
    I can go on do all the maths to work out the off set length. But it would be much easier if I can just use the reported length in the formula.
    Many THanks for your help!
    Lauren
