How to change the Default Scale Value
    Is there anyway to alter the default scale value of revit?
    If you have two different scale of views loaded on same sheets it will give you a default scale value of "As indicated".
    Is there anyway to change that?
    I want to change to "As Shown" rather than As indicated..
    I dont want to use shared parameters for the scale on title block coz it taking time inputting every sheets when you can use instead the auto scale parameter from the revit itself.
    Hope to hear your ideas.
    Regards,
    kiboypalaboy
    If you are against using shared parameters for this, then you are going to have to live with "as indicated" there is no user control for this.
    Jeff Hanson
    Sr. Subject Matter Expert
