AUBenchmark 2011 RESULTS (Archive)
This topic is closed.
    Please post benchmark results for Revit Architecture 2011 here. We'll keep the New AUBench thread open for discussions, so this one can be a simple archive of results.
    Thanks!
    Gordon
    Pragmatic Praxis
    AUBenchmark 2011 RESULTS (RST & RMEP)
    Please post benchmark results for Revit Structure & MEP 2011 here. We'll keep the New AUBench thread open for discussions, so this one can be a simple archive of results.
    Thanks!
    Gordon
    NOTE: The RST/RMEP benchmark does not implement the Modify Curtain Wall portion of the test. As a result the Render and Export segments of the test are working from a much simpler model and are thus not an apples to apples comparison with those numbers from the RAC benchmark. To indicate the variance these numbers and the totals are flagged with an *. Be aware of this when comparing benchmarks between RAC and RST/RMEP.
    Pragmatic Praxis
      AUBenchmark (RAC) v2.04.2011 run @ 2/5/2011 11:03:59 AM
      7, opening and loading the custom template
      10, creating the floors levels and grids
      30, creating a group of walls and doors
      59, modifying the group by adding a curtain wall
      30, creating the exterior curtain wall
      11, creating the sections
      14, changing the curtain wall panel type
      49, create 3d view and render
      41, export all views
      202, TOTAL w/o Render
      251, TOTAL
      MACHINE SPEC:
      OS: Microsoft Windows 7 Ultimate 32-bit
      CPU: Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz
      Max Clock Speed: 2.93 GHz
      Number of Processors: 1
      Number of Logical Processors: 8
      Total Physical Memory: 2.75 GB
      BANK #0: 2.00 GB @ 667 MHz
      BANK #1: 1.00 GB @ 667 MHz
      Graphics Card: Parallels Display Adapter (WDDM)
      Graphics RAM: 256 MB
      Driver version: 6.0.11992.0
      NOTE: iMac i7 with Parallels 6.0
      Pragmatic Praxis
        AUBenchmark (RAC) v2.04.2011 run @ 2/4/2011 11:01:13 PM
        8, opening and loading the custom template
        26, creating a group of walls and doors
        45, modifying the group by adding a curtain wall
        22, creating the exterior curtain wall
        11, changing the curtain wall panel type
        41, create 3d view and render
        33, export all views
        166, TOTAL w/o Render
        207, TOTAL
        MACHINE SPEC:
        Max Clock Speed: 2.93 MHz
        Total Physical Memory: 2.99 GB
        BANK 0: 2.00 GB @ 1333 MHz
        BANK 1: 2.00 GB @ 1333 MHz
        BANK 0: 4.00 GB @ 1333 MHz
        BANK 1: 4.00 GB @ 1333 MHz
        Graphics Card: ATI Radeon HD 5750
        Graphics RAM: 1.00 GB
        Driver version: 8.723.3.0
        NOTE: iMac i7 with Bootcamp
        Pragmatic Praxis
          AUBenchmark (RAC) v2.04.2011 run @ 2/7/2011 7:40:43 AM
          12, creating the floors levels and grids
          31, creating a group of walls and doors
          51, modifying the group by adding a curtain wall
          23, creating the exterior curtain wall
          13, changing the curtain wall panel type
          47, create 3d view and render
          34, export all views
          183, TOTAL w/o Render
          230, TOTAL
          MACHINE SPEC:
          OS: Microsoft Windows XP Professional x64 Edition 64-bit
          CPU: Intel(R) Pentium(R) III Xeon processor
          Max Clock Speed: 2.67 GHz
          Number of Processors: 4
          Total Physical Memory: 5.98 GB
          : 0.00 GB @ MHz
          Graphics Card: NVIDIA Quadro FX 1800
          Graphics RAM: 768 MB
          Driver version: 6.14.11.9703
          -Alex Cunningham
            AUBenchmark (RAC) v2.04.2011 run @ 2/7/2011 7:40:56 AM
            5, opening and loading the custom template
            53, modifying the group by adding a curtain wall
            12, creating the sections
            12, changing the curtain wall panel type
            42, create 3d view and render
            36, export all views
            181, TOTAL w/o Render
            223, TOTAL
            MACHINE SPEC:
            OS: Microsoft Windows 7 Enterprise 64-bit
            CPU: Intel(R) Xeon(R) CPU E5640 @ 2.67GHz
            Max Clock Speed: 2.66 GHz
            Number of Processors: 2
            Number of Logical Processors: 16
            Total Physical Memory: 47.98 GB
            : 0.00 GB @ MHz
            Graphics Card: NVIDIA Quadro FX 3800
            Driver version: 8.17.11.9703
            -Alex Cunningham
              AUBenchmark (RAC) v2.04.2011 run @ 2/7/2011 1:29:12 PM
              6, opening and loading the custom template
              8, creating the floors levels and grids
              25, creating a group of walls and doors
              44, modifying the group by adding a curtain wall
              10, creating the sections
              40, create 3d view and render
              32, export all views
              160, TOTAL w/o Render
              200, TOTAL
              MACHINE SPEC:
              OS: Microsoft Windows 7 Professional 64-bit
              CPU: Intel(R) Core(TM) i7 CPU 965 @ 3.20GHz
              Max Clock Speed: 3.20 GHz
              Total Physical Memory: 11.99 GB
              BANK0: 2.00 GB @ 1066 MHz
              BANK1: 2.00 GB @ 1066 MHz
              BANK2: 2.00 GB @ 1066 MHz
              BANK3: 2.00 GB @ 1066 MHz
              BANK4: 2.00 GB @ 1066 MHz
              BANK5: 2.00 GB @ 1066 MHz
              Graphics Card: Windows Live Display Driver
              Graphics RAM:
              Driver version: 15.5527.0.0
              Graphics Card: NVIDIA Quadro FX 580
              Graphics RAM: 512 MB
              Driver version: 8.17.12.6645
                AUBenchmark (RAC) v2.04.2011 run @ 2/7/2011 12:55:15 PM
                13, creating the floors levels and grids
                36, creating a group of walls and doors
                64, modifying the group by adding a curtain wall
                16, creating the sections
                17, changing the curtain wall panel type
                52, create 3d view and render
                45, export all views
                227, TOTAL w/o Render
                279, TOTAL
                MACHINE SPEC:
                OS: Microsoft Windows 7 Home Premium 64-bit
                CPU: Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz
                Max Clock Speed: 1.60 GHz
                Bank 0: 4.00 GB @ MHz
                Bank 1: 2.00 GB @ MHz
                Graphics Card: NVIDIA GeForce GT 330M
                Driver version: 8.17.12.5896
                Ran a batch of 3
                Juan Carlos Moreno
                Sisley Cosmetics
                  AUBenchmark (RST/RMEP) v2.04.2011 run @ 2/8/2011 2:20:13 PM
                  29, creating a group of walls and doors
                  Enters "Interactive Mode"
                  -Alex Cunningham
                    I have an install disk of XP x32 now, and RST & RMEP downloaded. Hopefully this weekend I can do some direct testing on all the different combinations of OS and Revit and see what comes of it.
                    Well, I am not testing anything on Vista. If you are running that, you have my sympathy!
                    Gordon
                    Pragmatic Praxis
