RFO Benchmark v3.1 2016 results
    Please post your RFOBenchmark V3.1 results for the 2017 products here.
    Comments and suggestions should be made in the RFOBenchmark v3.X thread. The download is there too.
    Note: To condense your results, click Go Advanced, highlight the results, then click the code button (the one with a #).
    Thanks!
    Gordon
    Pragmatic Praxis
    I'll kick things off with my final test runs.
    Code:
    RVT 2016 - Full_Simplified set - 2017.09.15 @ 15.11.25 on PX-0.txt
        RFO Benchmark v3.1 (build 01.09.2017)
        RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit 2016 R2
    _________________________________________________________________
    Model creation benchmark
        6.99   opening and loading the custom template
       15.76   creating the floors levels and grids
       28.73   creating a group of walls and doors
       48.84   modifying the group by adding a curtain wall
       17.71   creating the exterior curtain wall
       11.35   creating the sections
        5.29   changing the curtain wall panel type
       12.48   creating area plans
        1.91   creating and applying view template
      149.06   TOTAL
    Graphics
        6.61   activate View Styles view
        2.25   change view to Wireframe
        0.14   change view to Hidden
        0.59   change view to Shaded
        0.59   change view to Consistent Colors
        0.62   change view to Realistic
        1.47   refresh Wireframe Line view x10
        6.16   refresh Hidden Line view x10
        6.21   refresh Shaded view x10
        6.29   refresh Consistent Colors view x10
        7.11   refresh Realistic view x10
        0.83   activate View Cube view
       10.84   rotate view x1
       49.71   TOTAL
    Notes:
        Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
        To meaningfully compare graphics cards, test all cards in the same machine
        and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr: Apple Inc.
    Model: MacBookPro11,3
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
    Max Clock Speed: 2.501Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 16GB @ 1600 1600Mhz
    Drive Type: Network Drive
    Drive Model: Not Available
    Graphics Card: NVIDIA GeForce GT 750M
    Graphics RAM: 2GB
    Driver version: 22.21.13.8494
    Screen Resolution: 2880x1800x32bit @ 59Hz
    Pragmatic Praxis
      Revit on a lot of cores (dual xeon, 16cores 32 threads):
      Code:
      RVT 2016 - Full_Simplified set - 2017.09.17 @ 18.33.34 on DUPLAXEON.txt    RFO Benchmark v3.1 (build 01.09.2017)
          RevitForum.org
      Run on Revit 2016 FCS
          5.75   opening and loading the custom template
         22.46   creating the floors levels and grids
         40.24   creating a group of walls and doors
         69.66   modifying the group by adding a curtain wall
         26.04   creating the exterior curtain wall
         18.98   creating the sections
          8.12   changing the curtain wall panel type
         19.45   creating area plans
          2.57   creating and applying view template
        213.27   TOTAL
      Graphics
          7.95   activate View Styles view
          2.48   change view to Wireframe
          0.25   change view to Hidden
          1.02   change view to Shaded
          1.04   change view to Consistent Colors
          1.00   change view to Realistic
          2.61   refresh Wireframe Line view x10
         10.28   refresh Hidden Line view x10
         10.22   refresh Shaded view x10
          9.79   refresh Consistent Colors view x10
         11.88   refresh Realistic view x10
          1.12   activate View Cube view
          6.71   rotate view x1
         66.35   TOTAL
      Notes:
      TEST CONDITIONS:
      Mfr: ASUSTeK COMPUTER INC.
      Model: Z9PA-D8 Series
      OS: Microsoft Windows 10 Pro64 64-bit
      CPU: Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
      Max Clock Speed: Ghz
      Number of Processors: 8 8
      Number of Logical Processors: 16 16
      Total Physical Memory: 56GB @ 1333 1333 1333 1333 1333 1333 1333Mhz
      Drive Type: local Disk (NTFS)
      Drive Model: Samsung SSD 840 EVO 250GB
      Graphics Card: NVIDIA GeForce GTX 970
      Graphics RAM: 3.9990234375GB
      Driver version: 22.21.13.8541
      Graphics Card: Általános Microsoft-videokártya
      Graphics RAM: 0GB
      Driver version: 10.0.15063.0
      Screen Resolution: 1920 1920x1200 1200x32bit @ 59 59Hz
        New mobile workstation
        Code:
        RVT 2016 - Full_Simplified set - 2017.09.19 @ 23.43.56 on GB-7VY2GH2.txt    RFO Benchmark v3.1 (build 01.09.2017)
            RevitForum.org
        Run on Revit 2016 Update7 for R2
            3.80   opening and loading the custom template
           12.46   creating the floors levels and grids
           23.35   creating a group of walls and doors
           41.39   modifying the group by adding a curtain wall
           12.48   creating the exterior curtain wall
            8.22   creating the sections
            4.34   changing the curtain wall panel type
            8.50   creating area plans
            1.30   creating and applying view template
          115.84   TOTAL
        Graphics
            5.11   activate View Styles view
            1.58   change view to Wireframe
            0.13   change view to Hidden
            0.47   change view to Shaded
            0.50   change view to Consistent Colors
            0.48   change view to Realistic
            1.38   refresh Wireframe Line view x10
            5.34   refresh Hidden Line view x10
            5.27   refresh Shaded view x10
            5.17   refresh Consistent Colors view x10
            6.53   refresh Realistic view x10
            0.55   activate View Cube view
            4.14   rotate view x1
           36.65   TOTAL
        Notes:
        TEST CONDITIONS:
        Mfr: Dell Inc.
        Model: Precision 7520
        OS: Microsoft Windows 7 Enterprise 64-bit
        CPU: Intel(R) Core(TM) i7-6820HQ CPU @ 2.70GHz
        Max Clock Speed: 2.701Ghz
        Total Physical Memory: 32GB @ 2400 2400Mhz
        Drive Model: NVMe A400 NVMe SanDis SCSI Disk Device
        Graphics Card: Intel(R) HD Graphics 530
        Graphics RAM: 1GB
        Driver version: 21.20.16.4574
        Graphics Card: NVIDIA Quadro M2200
        Driver version: 21.21.13.7711
        Screen Resolution:  1920x 1080x32bit @  60Hz
          Code:
          RVT 2016 - Full_Simplified set - 2017.09.20 @ 17.22.18 on JWR.txt
              RevitForum.org
          Run on Revit 2016 Update6 for R2
              6.36   opening and loading the custom template
             13.34   creating the floors levels and grids
             28.28   creating a group of walls and doors
             54.45   modifying the group by adding a curtain wall
             16.55   creating the exterior curtain wall
             11.09   creating the sections
              5.32   changing the curtain wall panel type
             10.69   creating area plans
              1.70   creating and applying view template
            147.78   TOTAL
          Graphics
              5.66   activate View Styles view
              2.05   change view to Wireframe
              0.18   change view to Hidden
              0.73   change view to Shaded
              0.77   change view to Consistent Colors
              0.73   change view to Realistic
              1.93   refresh Wireframe Line view x10
              7.70   refresh Hidden Line view x10
              8.04   refresh Shaded view x10
              7.53   refresh Consistent Colors view x10
              9.07   refresh Realistic view x10
              0.88   activate View Cube view
              6.20   rotate view x1
             51.47   TOTAL
          Notes:
          TEST CONDITIONS:
          Mfr: System manufacturer
          Model: System Product Name
          OS: Microsoft Windows 10 Home64-bit
          CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
          Max Clock Speed: 3.401Ghz
          Total Physical Memory: 8GB @ 1333 1333Mhz
          Drive Model: OCZ-AGILITY3 ATA Device
          Graphics Card: NVIDIA GeForce GTX 560 Ti
          Graphics RAM: 1GB
          Driver version: 22.21.13.8205
          Screen Resolution: 1600x1200x32bit @ 60Hz
          Jan-Willem Roelofs
          Revit 2014-2018 Win 7 pro
          CPU E5-1630 v3, 32GB, Quadro K2200
            Code:
            RVT 2016 - Full_Expanded set - 2017.09.20 @ 17.03.45 on COM-0122-API.txt
                RevitForum.org
            Update
                7.57   update previous version file
                4.32   opening and loading the custom template
                0.01   saving the new project
               24.18   loading and arraying link
               51.97   setting links to halftone
                1.26   saving the project with links
               58.74   creating the floors levels and grids
               38.39   creating a group of walls and doors
               64.14   modifying the group by adding a curtain wall
               64.08   creating the exterior curtain wall
               38.62   creating the sections
                8.78   changing the curtain wall panel type
               35.16   creating area plans
                5.34   creating and applying view template
                1.52   saving the project with completed model
              396.51   TOTAL
            Export benchmark
             1627.70   export all views as PNGs at 300 dpi
             1016.42   export all views as DWFs
            52096.06   export all views as DWGs
            11817.28   print all views as vector *
              647.76   print all views as raster *
            Notes:
             *  Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
            Render benchmark
              147.09   render w/ nvidia mental ray
              155.41   render w/ autodesk raytracer
            Graphics - Activate first view
               38.84   activate View Styles view
            Graphics - Change view visual style from a common start
                0.96   common start: from Hidden Line to Wireframe
                0.06   common start: from Hidden Line to Shaded
                0.05   common start: from Hidden Line to Consistent Colors
                0.05   common start: from Hidden Line to Realistic
                0.05   common start: from Consistent Colors to Wireframe
                0.06   common start: from Consistent Colors to Hidden Line
                0.06   common start: from Consistent Colors to Shaded
                0.05   common start: from Consistent Colors to Realistic
                1.34   TOTAL
            Graphics - Change view visual style from a common end
                0.06   common end: from Wireframe to Hidden Line
                0.07   common end: from Shaded to Hidden Line
                0.05   common end: from Consistent Colors to Hidden Line
                0.05   common end: from Realistic to Hidden Line
                0.06   common end: from Wireframe to Consistent Colors
                0.05   common end: from Hidden Line to Consistent Colors
                0.05   common end: from Shaded to Consistent Colors
                0.05   common end: from Realistic to Consistent Colors
                0.44   TOTAL
            Graphics - Change view visual style in sequence
                0.06   in sequence: from Realistic to Wireframe
                0.06   in sequence: from Wireframe to Hidden Line
                0.05   in sequence: from Hidden Line to Shaded
                0.05   in sequence: from Shaded to Consistent Colors
                0.05   in sequence: from Consistent Colors to Realistic
                0.08   in sequence: from Realistic to Consistent Colors
                0.06   in sequence: from Consistent Colors to Shaded
                0.05   in sequence: from Shaded to Hidden Line
                0.06   in sequence: from Hidden Line to Wireframe
                0.52   TOTAL
            Graphics - Refresh views
                0.05   refresh Wireframe view x10
                0.06   refresh Hidden Line view x10
                0.05   refresh Shaded view x10
                0.05   refresh Consistent Colors view x10
                0.06   refresh Realistic view x10
                0.27   TOTAL
            Graphics - Rotate views
                0.02   activate View Cube view
               48.06   rotate view x1
                0.04   activate View Cube - Sketchy view
               56.30   rotate sketchy view x1
              104.42   TOTAL
            Notes:
                To meaningfully compare graphics cards, test all cards in the same machine.
            TEST CONDITIONS:
            Mfr: Hewlett-Packard
            Model: HP Z440 Workstation
            OS: Microsoft Windows 7 Professional 64-bit
            CPU: Intel(R) Xeon(R) CPU E5-1620 v3 @ 3.50GHz
            Max Clock Speed: 3.501Ghz
            Total Physical Memory: 32GB @ Mhz
            Drive Model: NVMe SAMSUNG MZVPW256 SCSI Disk Device
            Graphics Card: NVIDIA Quadro K2200
            Driver version: 9.18.13.3558
            Screen Resolution: 1920x1080x32bit @ 60Hz
            ______________________________________________________________________________________
            RVT 2016 - Full_Simplified set - 2017.10.16 @ 17.41.06 on COM-0122-API.txt
                RevitForum.org
                4.01   opening and loading the custom template
               12.52   creating the floors levels and grids
               25.59   creating a group of walls and doors
               45.43   modifying the group by adding a curtain wall
               14.33   creating the exterior curtain wall
               10.61   creating the sections
                5.16   changing the curtain wall panel type
               11.98   creating area plans
                1.73   creating and applying view template
              131.36   TOTAL
            Graphics
                5.68   activate View Styles view
                1.86   change view to Wireframe
                0.54   change view to Shaded
                0.52   change view to Consistent Colors
                0.55   change view to Realistic
                1.44   refresh Wireframe Line view x10
                5.63   refresh Hidden Line view x10
                5.82   refresh Shaded view x10
                5.47   refresh Consistent Colors view x10
                7.27   refresh Realistic view x10
                0.67   activate View Cube view
                5.18   rotate view x1
               40.77   TOTAL
            Notes:
            TEST CONDITIONS:
            RVT 2016 - Graphics_Acceleration set - 2017.10.16 @ 17.45.42 on COM-0122-API.txt
                RevitForum.org
            Graphics - Standard View - with Hardware Acceleration
                0.52   change view to Wireframe - hardware acceleration
                1.21   refresh Wireframe Line view x10 - hardware acceleration
                1.28   change view to Hidden - hardware acceleration
                4.39   refresh Hidden Line view x10 - hardware acceleration
                1.56   change view to Shaded - hardware acceleration
                4.97   refresh Shaded view x10 - hardware acceleration
                0.00   change view to ConsistentColors - hardware acceleration
                4.64   refresh Consistent Colors view x10 - hardware acceleration
                2.90   change view to Realistic - hardware acceleration
                5.06   refresh Realistic view x10 - hardware acceleration
                0.66   activate View Cube view - hardware acceleration
                2.67   rotate view x1 - hardware acceleration
               29.86   TOTAL
            Graphics - Sketchy View - with Hardware Acceleration
                2.68   change sketchy view to Wireframe - hardware acceleration
                2.55   refresh sketchy Wireframe Line view x10 - hardware acceleration
                1.71   change sketchy view to Hidden - hardware acceleration
                5.86   refresh sketchy Hidden Line view x10 - hardware acceleration
                2.24   change sketchy view to Shaded - hardware acceleration
                6.43   refresh sketchy Shaded view x10 - hardware acceleration
                2.18   change sketchy view to Consistent Colors - hardware acceleration
                5.94   refresh sketchy Consistent Colors view x10 - hardware acceleration
                2.17   change sketchy view to Realistic - hardware acceleration
                6.34   refresh sketchy Realistic view x10 - hardware acceleration
                0.82   activate View Cube - Sketchy view - hardware acceleration
                3.14   rotate sketchy view x1 - hardware acceleration
               42.06   TOTAL
            Notes:
                Compare these Hardware Accelerated numbers...
            Graphics - Standard View - without Hardware Acceleration
                1.28   change view to Wireframe - no hardware acceleration
                3.95   refresh Wireframe Line view x10 - no hardware acceleration
                8.97   change view to Hidden - no hardware acceleration
               65.23   refresh Hidden Line view x10 - no hardware acceleration
               16.05   change view to Shaded - no hardware acceleration
               65.85   refresh Shaded view x10 - no hardware acceleration
               15.12   change view to Consistent Colors - no hardware acceleration
               65.29   refresh Consistent Colors view x10 - no hardware acceleration
               16.12   change view to Realistic - no hardware acceleration
               65.93   refresh Realistic view x10 - no hardware acceleration
                7.32   activate View Cube view - no hardware acceleration
               22.57   rotate view x1 - no hardware acceleration
              353.68   TOTAL
            Graphics - Sketchy View - without Hardware Acceleration
               16.61   change sketchy view to Wireframe - no hardware acceleration
               48.82   refresh sketchy Wireframe Line view x10 - no hardware acceleration
               15.68   change sketchy view to Hidden - no hardware acceleration
               94.58   refresh sketchy Hidden Line view x10 - no hardware acceleration
               20.90   change sketchy view to Shaded - no hardware acceleration
               89.76   refresh sketchy Shaded view x10 - no hardware acceleration
               20.66   change sketchy view to Consistent Colors - no hardware acceleration
               89.69   refresh sketchy Consistent Colors view x10 - no hardware acceleration
               20.67   change sketchy view to Realistic - no hardware acceleration
               89.11   refresh sketchy Realistic view x10 - no hardware acceleration
               10.11   activate View Cube - Sketchy view - no hardware acceleration
               92.52   rotate sketchy view x1 - no hardware acceleration
              609.11   TOTAL
            Notes:
                ... to these without Hardware Acceleration
            TEST CONDITIONS:
            RVT 2016 - Graphics_Hammer set - 2017.10.16 @ 18.04.44 on COM-0122-API.txt
                RevitForum.org
               30.62   common start: from Hidden Line to Wireframe
               92.33   common start: from Hidden Line to Shaded
               90.23   common start: from Hidden Line to Consistent Colors
              112.01   common start: from Hidden Line to Realistic
               34.09   common start: from Consistent Colors to Wireframe
               89.77   common start: from Consistent Colors to Hidden Line
               93.23   common start: from Consistent Colors to Shaded
              114.00   common start: from Consistent Colors to Realistic
              656.28   TOTAL
               87.20   common end: from Wireframe to Hidden Line
               91.24   common end: from Shaded to Hidden Line
               96.09   common end: from Consistent Colors to Hidden Line
                0.09   common end: from Realistic to Hidden Line
                0.08   common end: from Wireframe to Consistent Colors
                0.07   common end: from Hidden Line to Consistent Colors
                0.08   common end: from Shaded to Consistent Colors
                0.07   common end: from Realistic to Consistent Colors
              274.92   TOTAL
                0.10   in sequence: from Realistic to Wireframe
                0.07   in sequence: from Wireframe to Hidden Line
                0.08   in sequence: from Hidden Line to Shaded
                0.08   in sequence: from Shaded to Consistent Colors
                0.08   in sequence: from Consistent Colors to Realistic
                0.07   in sequence: from Realistic to Consistent Colors
                0.08   in sequence: from Consistent Colors to Shaded
                0.08   in sequence: from Shaded to Hidden Line
                0.08   in sequence: from Hidden Line to Wireframe
                0.72   TOTAL
            Refresh views
                0.04   refresh Wireframe view x10
                0.05   refresh Hidden Line view x10
                0.05   refresh Realistic view x10
                0.24   TOTAL
            Rotate views
                0.03   activate View Cube view
              147.98   rotate view x1
                0.03   activate View Cube - Sketchy view
              180.31   rotate sketchy view x1
              328.35   TOTAL
            Notes:
                For thermal testing ;-)
            TEST CONDITIONS:
              Code:
              RVT 2016 - Full_Simplified set - 2017.10.22 @ 18.14.54
                  [URL="http://revitforum.org/"]RevitForum.org[/URL]
                  3.22   opening and loading the custom template
                 10.78   creating the floors levels and grids
                 20.98   creating a group of walls and doors
                 37.88   modifying the group by adding a curtain wall
                 12.66   creating the exterior curtain wall
                 10.08   creating the sections
                  4.21   changing the curtain wall panel type
                 10.54   creating area plans
                  1.53   creating and applying view template
                111.88   TOTAL
              Graphics
                  4.48   activate View Styles view
                  1.39   change view to Wireframe
                  0.12   change view to Hidden
                  0.44   change view to Shaded
                  0.45   change view to Consistent Colors
                  0.42   change view to Realistic
                  1.14   refresh Wireframe Line view x10
                  4.45   refresh Hidden Line view x10
                  4.46   refresh Shaded view x10
                  4.31   refresh Consistent Colors view x10
                  5.35   refresh Realistic view x10
                  0.51   activate View Cube view
                  3.73   rotate view x1
                 31.25   TOTAL
              Notes:
              TEST CONDITIONS:
              Mfr: HP
              Model: HP Z2 Mini G3 Workstation
              CPU: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
              Total Physical Memory: 16GB @ 2133 2133Mhz
              Graphics Card: NVIDIA Quadro M620
              Graphics RAM: 2GB
              Driver version: 21.21.13.7633
              Screen Resolution: 2560x1080x32bit @ 60Hz
                Results compared
                Code:
                [TABLE="width: 720"]
                [TR]
                [TD][/TD]
                [TD="align: right"]Les - Dell 3420 16 Gig Ram 3.5 xeon - 4 Processors
                4 Logical Processors
                256 SSD Quadro K620 2G[/TD]
                [TD="align: right"]JB - Dell 3420 16 Gig Ram 3.5 xeon - 4 Processors
                8 Logical Processors
                [/TR]
                [TR]
                [TD]Testing Benchmark software[/TD]
                [TD]2018.01.16[/TD]
                [TD]2016[/TD]
                [TD]2017.2.3[/TD]
                [TD]218.01.22[/TD]
                [/TR]
                [TR]
                [TD]Model Creation Benchmark[/TD]
                [TD][/TD]
                [TD][/TD]
                [TD][/TD]
                [TD][/TD]
                [/TR]
                [TR]
                [TD]Opening and loading the custom template[/TD]
                [TD="align: right"]5.00[/TD]
                [TD="align: right"]5.7[/TD]
                [TD="align: right"]6.12[/TD]
                [TD="align: right"]5.23[/TD]
                [/TR]
                [TR]
                [TD]Creating the floors levels and grids[/TD]
                [TD="align: right"]11.55[/TD]
                [TD="align: right"]14[/TD]
                [TD="align: right"]20.7[/TD]
                [TD="align: right"]21.16[/TD]
                [/TR]
                [TR]
                [TD]Creating a group of walls and doors[/TD]
                [TD="align: right"]18.88[/TD]
                [TD="align: right"]23[/TD]
                [TD="align: right"]26.79[/TD]
                [TD="align: right"]27.41[/TD]
                [/TR]
                [TR]
                [TD]Modifying the group by adding a curtain wall[/TD]
                [TD="align: right"]34.41[/TD]
                [TD="align: right"]41[/TD]
                [TD="align: right"]43.79[/TD]
                [TD="align: right"]44.16[/TD]
                [/TR]
                [TR]
                [TD]Creating the exterior curtain wall[/TD]
                [TD="align: right"]11.79[/TD]
                [TD="align: right"]15[/TD]
                [TD="align: right"]17.78[/TD]
                [TD="align: right"]18.32[/TD]
                [/TR]
                [TR]
                [TD]Creating the sections[/TD]
                [TD="align: right"]10.01[/TD]
                [TD="align: right"]13[/TD]
                [TD="align: right"]19.67[/TD]
                [TD="align: right"]21.59[/TD]
                [/TR]
                [TR]
                [TD]Changing the curtain wall panel type[/TD]
                [TD="align: right"]4.14[/TD]
                [TD="align: right"]5.1[/TD]
                [TD="align: right"]5.9[/TD]
                [TD="align: right"]5.89[/TD]
                [/TR]
                [TR]
                [TD]Creating area plans[/TD]
                [TD="align: right"]14.11[/TD]
                [TD="align: right"]12[/TD]
                [TD="align: right"]16.14[/TD]
                [TD="align: right"]21[/TD]
                [/TR]
                [TR]
                [TD]Creating and applying view template[/TD]
                [TD="align: right"]1.95[/TD]
                [TD="align: right"]1.9[/TD]
                [TD="align: right"]2.39[/TD]
                [TD="align: right"]3.12[/TD]
                [/TR]
                [TR]
                [TD][B]TOTAL[/B][/TD]
                [TD="align: right"][B]111.84[/B][/TD]
                [TD="align: right"][B]134[/B][/TD]
                [TD="align: right"][B]159.28[/B][/TD]
                [TD="align: right"][B]167.88[/B][/TD]
                [/TR]
                [TR]
                [TD][/TD]
                [TD][/TD]
                [TD][/TD]
                [TD][/TD]
                [TD][/TD]
                [/TR]
                [TR]
                [TD]Graphics[/TD]
                [TD][/TD]
                [TD][/TD]
                [TD][/TD]
                [TD][/TD]
                [/TR]
                [TR]
                [TD]Activate View Styles view[/TD]
                [TD="align: right"]2.97[/TD]
                [TD="align: right"]5.65[/TD]
                [TD="align: right"]6.77[/TD]
                [TD="align: right"]6.8[/TD]
                [/TR]
                [TR]
                [TD]Change view to Wireframe[/TD]
                [TD="align: right"]2.48[/TD]
                [TD="align: right"]1.66[/TD]
                [TD="align: right"]2.05[/TD]
                [TD="align: right"]2.1[/TD]
                [/TR]
                [TR]
                [TD]Change view to Hidden[/TD]
                [TD="align: right"]0.12[/TD]
                [TD="align: right"]0.14[/TD]
                [TD="align: right"]0.19[/TD]
                [TD="align: right"]0.1[/TD]
                [/TR]
                [TR]
                [TD]Change view to Shaded[/TD]
                [TD="align: right"]0.48[/TD]
                [TD="align: right"]0.5[/TD]
                [TD="align: right"]0.54[/TD]
                [/TR]
                [TR]
                [TD]Change view to Consistent Colors[/TD]
                [TD="align: right"]0.46[/TD]
                [TD="align: right"]0.59[/TD]
                [/TR]
                [TR]
                [TD]Change view to Realistic[/TD]
                [/TR]
                [TR]
                [TD]Refresh Wireframe Line view x10[/TD]
                [TD="align: right"]1.16[/TD]
                [TD="align: right"]1.3[/TD]
                [TD="align: right"]1.37[/TD]
                [/TR]
                [TR]
                [TD]Refresh Hidden Line view x10[/TD]
                [TD="align: right"]4.75[/TD]
                [TD="align: right"]4.86[/TD]
                [TD="align: right"]5.36[/TD]
                [/TR]
                [TR]
                [TD]Refresh Shaded view x10[/TD]
                [TD="align: right"]4.73[/TD]
                [TD="align: right"]4.96[/TD]
                [TD="align: right"]5.62[/TD]
                [TD="align: right"]5.2[/TD]
                [/TR]
                [TR]
                [TD]Refresh Consistent Colors view x10[/TD]
                [TD="align: right"]4.54[/TD]
                [TD="align: right"]5.34[/TD]
                [TD="align: right"]5[/TD]
                [/TR]
                [TR]
                [TD]Refresh Realistic view x10[/TD]
                [TD="align: right"]5.95[/TD]
                [TD="align: right"]5.85[/TD]
                [TD="align: right"]6.84[/TD]
                [TD="align: right"]6.2[/TD]
                [/TR]
                [TR]
                [TD]Activate View Cube view[/TD]
                [TD="align: right"]0.50[/TD]
                [TD="align: right"]0.65[/TD]
                [TD="align: right"]0.73[/TD]
                [TD="align: right"]0.7[/TD]
                [/TR]
                [TR]
                [TD]Rotate view x1[/TD]
                [TD="align: right"]5.52[/TD]
                [TD="align: right"]4.09[/TD]
                [TD="align: right"]1.85[/TD]
                [TD="align: right"]5.4[/TD]
                [/TR]
                [TR]
                [TD="align: right"][B]34.14[/B][/TD]
                [TD="align: right"][B]35.41[/B][/TD]
                [TD="align: right"][B]37.79[/B][/TD]
                [TD="align: right"][B]39[/B][/TD]
                [/TR]
                [/TABLE]
                  I started it two times, every time same
                  I thing, its to fast but why is it so fast? is it an error?
                  Code:
                  RVT 2016 - Graphics_Expanded set - 2018.08.23 @ 13.08.33 on C1006793.txt
                      RevitForum.org
                     54.14   activate View Styles view
                      0.99   common start: from Hidden Line to Wireframe
                      0.07   common start: from Hidden Line to Shaded
                      0.06   common start: from Hidden Line to Consistent Colors
                      0.06   common start: from Hidden Line to Realistic
                      0.06   common start: from Consistent Colors to Wireframe
                      0.07   common start: from Consistent Colors to Realistic
                      1.43   TOTAL
                      0.06   common end: from Consistent Colors to Hidden Line
                      0.06   common end: from Realistic to Hidden Line
                      0.07   common end: from Wireframe to Consistent Colors
                      0.06   common end: from Hidden Line to Consistent Colors
                      0.06   common end: from Shaded to Consistent Colors
                      0.06   common end: from Realistic to Consistent Colors
                      0.50   TOTAL
                      0.07   in sequence: from Realistic to Wireframe
                      0.06   in sequence: from Hidden Line to Shaded
                      0.07   in sequence: from Shaded to Consistent Colors
                      0.07   in sequence: from Consistent Colors to Realistic
                      0.06   in sequence: from Shaded to Hidden Line
                      0.07   in sequence: from Hidden Line to Wireframe
                      0.60   TOTAL
                      0.06   refresh Wireframe view x10
                      0.07   refresh Shaded view x10
                      0.06   refresh Consistent Colors view x10
                      0.31   TOTAL
                      0.04   activate View Cube view
                     64.64   rotate view x1
                     76.18   rotate sketchy view x1
                    140.90   TOTAL
                  Notes:
                  TEST CONDITIONS:
                  Mfr: Dell Inc.
                  Model: Precision T5610
                  CPU: Intel(R) Xeon(R) CPU E5-2637 v2 @ 3.50GHz
                  Total Physical Memory: 64GB @ Mhz
                  Drive Model: ATA Micron_M550_2.5" SCSI Disk Device
                  Graphics Card: NVIDIA Quadro K4000
                  Graphics RAM: 3GB
                  Driver version: 23.21.13.9189
                  Screen Resolution: 1024x768x32bit @ 60Hz
                    Code:
                    RVT 2016 - Full_Simplified set - 2018.08.29 @ 12.24.47
                        RevitForum.org
                    Run on Revit 2016.1.8
                        4.13   opening and loading the custom template
                       13.11   creating the floors levels and grids
                       27.19   creating a group of walls and doors
                       50.45   modifying the group by adding a curtain wall
                       15.91   creating the exterior curtain wall
                       10.62   creating the sections
                        5.28   changing the curtain wall panel type
                       10.73   creating area plans
                        1.51   creating and applying view template
                      138.93   TOTAL
                    Graphics
                        5.63   activate View Styles view
                        1.84   change view to Wireframe
                        0.16   change view to Hidden
                        0.63   change view to Consistent Colors
                        0.71   change view to Realistic
                        1.52   refresh Wireframe Line view x10
                        6.17   refresh Hidden Line view x10
                        6.50   refresh Shaded view x10
                        6.15   refresh Consistent Colors view x10
                        8.01   refresh Realistic view x10
                        5.07   rotate view x1
                       43.60   TOTAL
                    Notes:
                    TEST CONDITIONS:
                    Mfr: Dell Inc.
                    Model: Precision Tower 5810
                    Graphics Card: AMD FirePro W5000
                    Graphics RAM: 2GB
                    Driver version: 22.19.161.2561
                    Screen Resolution: 1280x1024x32bit @ 60Hz
