RFO Benchmark v3.1 2017 results
    Please post your RFOBenchmark V3.1 results for the 2017 products here.
    Comments and suggestions should be made in the RFOBenchmark v3.X thread. The download is there too.
    Note: To condense your results, click Go Advanced, highlight the results, then click the code button (the one with a #).
    Thanks!
    Gordon
    Pragmatic Praxis
    I'll kick things off with my final test runs.
    Code:
    RVT 2017 - Full_Simplified set - 2017.09.15 @ 15.05.30 on PX-0.txt
        RFO Benchmark v3.1 (build 01.09.2017)
        RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit 2017.2
    _________________________________________________________________
    Model creation benchmark
        7.17   opening and loading the custom template
       16.29   creating the floors levels and grids
       29.68   creating a group of walls and doors
       48.22   modifying the group by adding a curtain wall
       16.50   creating the exterior curtain wall
       11.42   creating the sections
        5.46   changing the curtain wall panel type
       13.90   creating area plans
        1.97   creating and applying view template
      150.61   TOTAL
    Graphics
        7.24   activate View Styles view
        2.54   change view to Wireframe
        0.13   change view to Hidden
        0.55   change view to Shaded
        0.65   change view to Consistent Colors
        0.57   change view to Realistic
        1.47   refresh Wireframe Line view x10
        6.24   refresh Hidden Line view x10
        6.43   refresh Shaded view x10
        6.09   refresh Consistent Colors view x10
        7.60   refresh Realistic view x10
        0.66   activate View Cube view
       10.29   rotate view x1
       50.46   TOTAL
    Notes:
        Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
        To meaningfully compare graphics cards, test all cards in the same machine
        and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr: Apple Inc.
    Model: MacBookPro11,3
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
    Max Clock Speed: 2.501Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 16GB @ 1600 1600Mhz
    Drive Type: Network Drive
    Drive Model: Not Available
    Graphics Card: NVIDIA GeForce GT 750M
    Graphics RAM: 2GB
    Driver version: 22.21.13.8494
    Screen Resolution: 2880x1800x32bit @ 59Hz
    Pragmatic Praxis
      Thanks Gordon, this benckmark is great to have again. I think I found one slight issue (maybe a Y2K type of thing)... when the graphics card has a double digit number for memory it drops the first number.
      Sorry, I don't know how to enclose the results in a "Code" window like Gordon did in the previous post. Here is my first test:
      Code:
      RVT 2017 - Full_Simplified set - 2017.09.16 @ 08.57.10 on DLHVRBOX.txt
          RevitForum.org
      Run on Revit 2017.2.1
          2.77   opening and loading the custom template
          9.69   creating the floors levels and grids
         19.45   creating a group of walls and doors
         37.39   modifying the group by adding a curtain wall
         11.34   creating the exterior curtain wall
          7.80   creating the sections
          4.01   changing the curtain wall panel type
          9.13   creating area plans
          1.31   creating and applying view template
        102.89   TOTAL
      Graphics
          4.10   activate View Styles view
          1.50   change view to Wireframe
          0.12   change view to Hidden
          0.46   change view to Shaded
          0.48   change view to Consistent Colors
          0.46   change view to Realistic
          1.26   refresh Wireframe Line view x10
          4.89   refresh Hidden Line view x10
          5.06   refresh Shaded view x10
          4.85   refresh Consistent Colors view x10
          6.04   refresh Realistic view x10
          0.53   activate View Cube view
          3.41   rotate view x1
         33.16   TOTAL
      Notes:
      TEST CONDITIONS:
      Mfr: Dell Inc.
      Model: Precision Tower 5810
      CPU: Intel(R) Xeon(R) CPU E5-1630 v3 @ 3.70GHz
      Max Clock Speed: 3.701Ghz
      Number of Logical Processors: 4
      Total Physical Memory: 16GB @ 2133 2133 2133 2133Mhz
      Drive Type: local Disk (NTFS)
      Drive Model: NVMe SM951 NVMe SAMSU
      Graphics Card: NVIDIA Quadro P6000
      Graphics RAM: 3.9990234375GB
      Driver version: 22.21.13.8205
      Screen Resolution: 1920x1200x32bit @ 59Hz
        Hello
        Code:
        RVT 2017 - Full_Simplified set - 2017.09.18 @ 15.23.03 on N052454.txt
            RevitForum.org
            5.73   opening and loading the custom template
           16.53   creating the floors levels and grids
           27.48   creating a group of walls and doors
           46.66   modifying the group by adding a curtain wall
           15.11   creating the exterior curtain wall
           11.62   creating the sections
            4.98   changing the curtain wall panel type
           13.73   creating area plans
            1.71   creating and applying view template
          143.55   TOTAL
        Graphics
            7.23   activate View Styles view
            1.73   change view to Wireframe
            0.51   change view to Shaded
            0.52   change view to Consistent Colors
            0.51   change view to Realistic
            1.30   refresh Wireframe Line view x10
            5.51   refresh Hidden Line view x10
            5.60   refresh Shaded view x10
            5.25   refresh Consistent Colors view x10
            6.66   refresh Realistic view x10
            0.61   activate View Cube view
            4.22   rotate view x1
           39.78   TOTAL
        Notes:
        TEST CONDITIONS:
        Mfr: Hewlett-Packard
        Model: HP Z440 Workstation
        OS: Майкрософт Windows 10 Pro (Registered Trademark)64-bit
        CPU: Intel(R) Xeon(R) CPU E5-1650 v3 @ 3.50GHz
        Max Clock Speed: 3.501Ghz
        Number of Processors: 6
        Number of Logical Processors: 12
        Total Physical Memory: 32GB @ 2133 2133 2133 2133Mhz
        Drive Model: WDC WD10EZEX-60WN4A0
        Graphics Card: NVIDIA Quadro M4000
        Driver version: 21.21.13.7295
        Screen Resolution: 1920x1080x32bit @ 60Hz
          This is great. Seems like the new mobile workstation I got at work today should cope nicely
          Code:
          RVT 2017 - Full_Simplified set - 2017.09.20 @ 00.14.40 on GB-7VY2GH2.txt    RFO Benchmark v3.1 (build 01.09.2017)
              RevitForum.org
              5.36   opening and loading the custom template
             12.06   creating the floors levels and grids
             22.34   creating a group of walls and doors
             40.07   modifying the group by adding a curtain wall
             12.21   creating the exterior curtain wall
              8.07   creating the sections
              4.12   changing the curtain wall panel type
              9.49   creating area plans
              1.41   creating and applying view template
            115.13   TOTAL
          Graphics
              4.83   activate View Styles view
              1.68   change view to Wireframe
              0.14   change view to Hidden
              0.50   change view to Consistent Colors
              0.53   change view to Realistic
              1.37   refresh Wireframe Line view x10
              5.42   refresh Hidden Line view x10
              5.58   refresh Shaded view x10
              5.20   refresh Consistent Colors view x10
              6.56   refresh Realistic view x10
              0.55   activate View Cube view
              3.72   rotate view x1
             36.59   TOTAL
          Notes:
          TEST CONDITIONS:
          Mfr: Dell Inc.
          Model: Precision 7520
          OS: Microsoft Windows 7 Enterprise 64-bit
          CPU: Intel(R) Core(TM) i7-6820HQ CPU @ 2.70GHz
          Max Clock Speed: 2.701Ghz
          Total Physical Memory: 32GB @ 2400 2400Mhz
          Drive Model: NVMe A400 NVMe SanDis SCSI Disk Device
          Graphics Card: Intel(R) HD Graphics 530
          Graphics RAM: 1GB
          Driver version: 21.20.16.4574
          Graphics Card: NVIDIA Quadro M2200
          Driver version: 21.21.13.7711
          Screen Resolution:  1920x 1080x32bit @  60Hz
            Code:
            RVT 2017 - Full_Standard set - 2017.09.20 @ 17.07.53 on PC1.txt
                RevitForum.org
            Run on Revit 2017 FCS
            Update
                7.28   update previous version file
                2.91   opening and loading the custom template
               12.46   creating the floors levels and grids
               19.26   creating a group of walls and doors
               32.84   modifying the group by adding a curtain wall
               11.37   creating the exterior curtain wall
                8.99   creating the sections
                3.79   changing the curtain wall panel type
               10.36   creating area plans
                1.35   creating and applying view template
              103.33   TOTAL
            Export benchmark
               64.16   export all views as PNGs at 300 dpi
               87.15   export all views as DWFs
              137.50   export all views as DWGs
               65.01   print all views as vector *
              101.80   print all views as raster *
            Notes:
             *  Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
            Render benchmark
              114.33   render
            Graphics - Standard View
                4.79   activate View Styles view
                0.57   change view to Wireframe
                1.23   change view to Hidden
                1.56   change view to Shaded
                1.49   change view to Consistent Colors
                2.18   change view to Realistic
                1.02   refresh Wireframe Line view x10
                4.17   refresh Hidden Line view x10
                4.75   refresh Shaded view x10
                4.36   refresh Consistent Colors view x10
                6.46   refresh Realistic view x10
                1.00   activate View Cube view
                5.33   rotate view x1
               38.91   TOTAL
            Graphics - Sketchy View
                0.81   activate View Styles - Sketchy view
                2.30   change sketchy view to Wireframe
                1.49   change sketchy view to Hidden
                1.82   change sketchy view to Shaded
                1.84   change sketchy view to Consistent Colors
                1.67   change sketchy view to Realistic
                1.77   refresh sketchy Wireframe Line view x10
                4.96   refresh sketchy Hidden Line view x10
                5.56   refresh sketchy Shaded view x10
                5.14   refresh sketchy Consistent Colors view x10
                7.21   refresh sketchy Realistic view x10
                1.09   activate View Cube - Sketchy view
                7.07   rotate sketchy view x1
               42.73   TOTAL
            Notes:
            TEST CONDITIONS:
            Mfr: MSI
            Model: MS-7A70
            CPU: Intel(R) Core(TM) i5-7600 CPU @ 3.50GHz
            Max Clock Speed: 3.504Ghz
            Total Physical Memory: 16GB @ 2133 2133Mhz
            Drive Model: ADATA SX8000NP
            Graphics Card: Intel(R) HD Graphics 630
            Graphics RAM: 1GB
            Driver version: 21.20.16.4534
              Originally posted by bobivg View Post
              Code:
              Graphics RAM: 1GB
              Bob, do you not have a dedicated video card on your machine? If you do, check to make sure that it is setup as default in the display settings
              Link is for Infraworks, but it works for all programs when you select Global Settings. https://knowledge.autodesk.com/suppo...nfraWorks.html
              Check that and see if that improves your benchmark some.
                I do not have a video card. My computer is for Autocad and studying the Revit.
                  First time posting here.
                  This is my setup that I ran with the benchmark test:
                  Code:
                  RVT 2017 - Full_Standard set - 2017.09.20 @ 10.38.14 on SEA-DROONEY-L.txt    RFO Benchmark v3.1 (build 01.09.2017)
                      RevitForum.org
                  Run on Revit 2017.2.2
                  Update
                      8.74   update previous version file
                      3.45   opening and loading the custom template
                     14.04   creating the floors levels and grids
                     24.49   creating a group of walls and doors
                     43.01   modifying the group by adding a curtain wall
                     15.08   creating the exterior curtain wall
                     10.73   creating the sections
                      5.23   changing the curtain wall panel type
                     12.88   creating area plans
                      1.84   creating and applying view template
                    130.75   TOTAL
                  Export benchmark
                     70.99   export all views as PNGs at 300 dpi
                     55.81   export all views as DWFs
                    102.66   export all views as DWGs
                     63.41   print all views as vector *
                    104.73   print all views as raster *
                  Notes:
                  Render benchmark
                     97.66   render
                      4.88   activate View Styles view
                      0.51   change view to Wireframe
                      1.01   change view to Hidden
                      1.33   change view to Shaded
                      1.38   change view to Consistent Colors
                      2.16   change view to Realistic
                      1.12   refresh Wireframe Line view x10
                      4.25   refresh Hidden Line view x10
                      4.59   refresh Shaded view x10
                      4.38   refresh Consistent Colors view x10
                      4.70   refresh Realistic view x10
                      0.57   activate View Cube view
                      4.34   rotate view x1
                     35.22   TOTAL
                      0.65   activate View Styles - Sketchy view
                      2.55   change sketchy view to Wireframe
                      1.45   change sketchy view to Hidden
                      1.64   change sketchy view to Realistic
                      2.02   refresh sketchy Wireframe Line view x10
                      5.23   refresh sketchy Hidden Line view x10
                      5.39   refresh sketchy Shaded view x10
                      5.22   refresh sketchy Consistent Colors view x10
                      5.63   refresh sketchy Realistic view x10
                      0.69   activate View Cube - Sketchy view
                     14.46   rotate sketchy view x1
                     48.59   TOTAL
                  Notes:
                  TEST CONDITIONS:
                  Mfr: HP
                  Model: HP ZBook 17 G4
                  OS: Microsoft Windows 10 Enterprise64-bit
                  CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
                  Max Clock Speed: 2.904Ghz
                  Drive Model: THNSN5512GPU7 TOSHIBA
                  Graphics Card: NVIDIA Quadro P5000
                  Driver version: 22.21.13.8541
                  Graphics RAM: 1GB
                  Driver version: 21.20.16.4590
                  Screen Resolution: 2560 1920x1440 1080x32bit @ 59 60Hz
                  RAW DATA:
                      9.059    9.059    8.094   update previous version file
                      3.445    3.562    3.336   opening and loading the custom template
                     13.863   14.094   14.152   creating the floors levels and grids
                     23.098   25.777   24.582   creating a group of walls and doors
                     43.012   45.305   40.699   modifying the group by adding a curtain wall
                     14.801   15.555   14.891   creating the exterior curtain wall
                     10.211   11.219   10.758   creating the sections
                      4.969    5.613    5.102   changing the curtain wall panel type
                     11.770   14.414   12.461   creating area plans
                      1.824    1.832    1.859   creating and applying view template
                     70.156   74.668   68.152   export all views as PNGs at 300 dpi
                     56.711   56.199   54.531   export all views as DWFs
                    105.023  102.457  100.500   export all views as DWGs
                     64.371   63.422   62.445   print all views as vector
                    105.527  104.531  104.133   print all views as raster
                    101.383   95.879   95.719   render
                      4.832    4.934    4.871   activate View Styles view
                      0.500    0.516    0.504   change view to Wireframe
                      0.969    1.035    1.012   change view to Hidden
                      1.363    1.336    1.293   change view to Shaded
                      1.438    1.293    1.414   change view to Consistent Colors
                      2.266    2.062    2.141   change view to Realistic
                      1.129    1.121    1.117   refresh Wireframe Line view x10
                      4.273    4.254    4.234   refresh Hidden Line view x10
                      4.875    4.477    4.422   refresh Shaded view x10
                      4.629    4.246    4.266   refresh Consistent Colors view x10
                      4.863    4.613    4.625   refresh Realistic view x10
                      0.559    0.609    0.547   activate View Cube view
                      4.484    4.305    4.230   rotate view x1
                      0.656    0.668    0.625   activate View Styles - Sketchy view
                      2.559    2.574    2.516   change sketchy view to Wireframe
                      1.539    1.387    1.430   change sketchy view to Hidden
                      1.898    1.773    1.785   change sketchy view to Shaded
                      1.918    1.809    1.805   change sketchy view to Consistent Colors
                      1.766    1.586    1.555   change sketchy view to Realistic
                      2.129    1.973    1.965   refresh sketchy Wireframe Line view x10
                      5.551    5.074    5.062   refresh sketchy Hidden Line view x10
                      5.586    5.309    5.262   refresh sketchy Shaded view x10
                      5.418    5.137    5.117   refresh sketchy Consistent Colors view x10
                      5.742    5.551    5.598   refresh sketchy Realistic view x10
                      0.758    0.656    0.656   activate View Cube - Sketchy view
                     15.035   14.289   14.066   rotate sketchy view x1
                    Code:
                    RVT 2017 - Full_Standard set - 2017.09.21 @ 10.18.56 on LAP16321.txt
                        RevitForum.org
                    Run on Revit 2017.0.3
                    Update
                       10.17   update previous version file
                        6.17   opening and loading the custom template
                       23.27   creating the floors levels and grids
                       34.90   creating a group of walls and doors
                       51.17   modifying the group by adding a curtain wall
                       19.91   creating the exterior curtain wall
                       16.91   creating the sections
                        5.66   changing the curtain wall panel type
                       16.67   creating area plans
                        2.54   creating and applying view template
                      177.20   TOTAL
                    Export benchmark
                       95.79   export all views as PNGs at 300 dpi
                      130.62   export all views as DWFs
                      204.26   export all views as DWGs
                      106.68   print all views as vector *
                      133.02   print all views as raster *
                    Notes:
                    Render benchmark
                      154.47   render
                        9.19   activate View Styles view
                        0.61   change view to Wireframe
                        1.28   change view to Hidden
                        1.71   change view to Shaded
                        1.74   change view to Consistent Colors
                        2.48   change view to Realistic
                        1.29   refresh Wireframe Line view x10
                        5.06   refresh Hidden Line view x10
                        5.52   refresh Shaded view x10
                        5.05   refresh Consistent Colors view x10
                        5.70   refresh Realistic view x10
                        0.85   activate View Cube view
                       10.64   rotate view x1
                       51.12   TOTAL
                        1.72   activate View Styles - Sketchy view
                        2.60   change sketchy view to Wireframe
                        1.23   change sketchy view to Hidden
                        1.45   change sketchy view to Shaded
                        1.39   change sketchy view to Consistent Colors
                        1.29   change sketchy view to Realistic
                        1.51   refresh sketchy Wireframe Line view x10
                        4.04   refresh sketchy Hidden Line view x10
                        4.26   refresh sketchy Shaded view x10
                        4.06   refresh sketchy Consistent Colors view x10
                        4.71   refresh sketchy Realistic view x10
                        0.79   activate View Cube - Sketchy view
                       19.30   rotate sketchy view x1
                       48.35   TOTAL
                    Notes:
                    TEST CONDITIONS:
                    Mfr: HP
                    Model: HP ZBook Studio G3
                    CPU: Intel(R) Xeon(R) CPU E3-1505M v5 @ 2.80GHz
                    Max Clock Speed: 2.808Ghz
                    Total Physical Memory: 32GB @ 2133 2133Mhz
                    Drive Model: TS1TMTS800
                    Graphics Card: Intel(R) HD Graphics P530
                    Graphics RAM: 1GB
                    Graphics Card: NVIDIA Quadro M1000M
                    Driver version: 21.21.13.7748
                    Screen Resolution: 3840 x2160 x32bit @ 59 Hz
                    RAW DATA:
                       11.180    9.711    9.609   update previous version file
                        6.852    5.992    5.652   opening and loading the custom template
                       24.398   22.465   22.957   creating the floors levels and grids
                       34.230   31.172   39.301   creating a group of walls and doors
                       50.637   49.672   53.188   modifying the group by adding a curtain wall
                       19.606   18.309   21.809   creating the exterior curtain wall
                       17.094   16.754   16.891   creating the sections
                        5.969    5.344    5.668   changing the curtain wall panel type
                       16.840   16.195   16.977   creating area plans
                        2.461    2.488    2.664   creating and applying view template
                       93.168   95.641   98.570   export all views as PNGs at 300 dpi
                      121.805  139.664  130.394   export all views as DWFs
                      188.109  205.633  219.023   export all views as DWGs
                      101.566  101.012  117.477   print all views as vector
                      131.449  135.215  132.410   print all views as raster
                      144.672  146.820  171.930   render
                        8.926    9.352    9.301   activate View Styles view
                        0.535    0.684    0.598   change view to Wireframe
                        1.305    1.250    1.285   change view to Hidden
                        1.965    1.629    1.539   change view to Shaded
                        1.852    1.664    1.695   change view to Consistent Colors
                        2.492    2.473    2.461   change view to Realistic
                        1.227    1.324    1.309   refresh Wireframe Line view x10
                        5.129    5.062    4.977   refresh Hidden Line view x10
                        5.660    5.410    5.504   refresh Shaded view x10
                        5.043    5.027    5.066   refresh Consistent Colors view x10
                        5.609    5.426    6.059   refresh Realistic view x10
                        0.856    0.816    0.891   activate View Cube view
                       10.106   10.465   11.340   rotate view x1
                        1.484    2.230    1.449   activate View Styles - Sketchy view
                        3.496    3.578    0.738   change sketchy view to Wireframe
                        1.891    1.738    0.047   change sketchy view to Hidden
                        2.121    2.184    0.047   change sketchy view to Shaded
                        2.055    2.055    0.047   change sketchy view to Consistent Colors
                        1.891    1.930    0.047   change sketchy view to Realistic
                        2.211    2.195    0.137   refresh sketchy Wireframe Line view x10
                        5.961    6.000    0.156   refresh sketchy Hidden Line view x10
                        6.301    6.148    0.332   refresh sketchy Shaded view x10
                        6.020    6.016    0.152   refresh sketchy Consistent Colors view x10
                        6.523    7.457    0.144   refresh sketchy Realistic view x10
                        0.988    1.246    0.144   activate View Cube - Sketchy view
                       25.617   29.945    2.324   rotate sketchy view x1
