RFO Benchmark v3.1 2018 results
    Please post your RFOBenchmark V3.1 results for the 2018 products here.
    Comments and suggestions should be made in the RFOBenchmark v3.X thread. The download is there too.
    Note: To condense your results, click Go Advanced, highlight the results, then click the code button (the one with a #).
    Thanks!
    Gordon
    Pragmatic Praxis
    I'll kick things off with my final test runs. Note that, as is often the case, the newest version of Revit is not the fastest. But if you look at the 2016 & 2017 results I posted, you see that 2017 is now basically as fast as 2016, though that wasn't initially the case either. Revit updates over time can dramatically affect performance as well as address bugs. All the more reason for the improved build reporting in RFO Benchmark 3.1.
    Code:
    RVT 2018 - Full_Simplified set - 2017.09.15 @ 14.59.35 on PX-0.txt
        RFO Benchmark v3.1 (build 01.09.2017)
        RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit 2018.1
    _________________________________________________________________
    Model creation benchmark
        5.90   opening and loading the custom template
       20.39   creating the floors levels and grids
       35.05   creating a group of walls and doors
       53.09   modifying the group by adding a curtain wall
       22.30   creating the exterior curtain wall
       15.97   creating the sections
        5.74   changing the curtain wall panel type
       20.50   creating area plans
        2.45   creating and applying view template
      181.39   TOTAL
    Graphics
        5.56   activate View Styles view
        2.52   change view to Wireframe
        0.13   change view to Hidden
        0.64   change view to Shaded
        0.67   change view to Consistent Colors
        0.64   change view to Realistic
        1.43   refresh Wireframe Line view x10
        7.01   refresh Hidden Line view x10
        7.05   refresh Shaded view x10
        6.80   refresh Consistent Colors view x10
        8.43   refresh Realistic view x10
        0.76   activate View Cube view
       10.31   rotate view x1
       51.95   TOTAL
    Notes:
        Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
        To meaningfully compare graphics cards, test all cards in the same machine
        and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr: Apple Inc.
    Model: MacBookPro11,3
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
    Max Clock Speed: 2.501Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 16GB @ 1600 1600Mhz
    Drive Type: Network Drive
    Drive Model: Not Available
    Graphics Card: NVIDIA GeForce GT 750M
    Graphics RAM: 2GB
    Driver version: 22.21.13.8494
    Screen Resolution: 2880x1800x32bit @ 59Hz
    Pragmatic Praxis
      Results of Graphics_Expanded set on a Surface Book with discrete graphics card
      Code:
      RVT 2018 - Graphics_Expanded set - 2017.09.15 @ 14.10.19
      Graphics - Activate first view
         80.20   activate View Styles view
      Graphics - Change view visual style from a common start
         38.34   common start: from Hidden Line to Wireframe
         68.49   common start: from Hidden Line to Shaded
         67.86   common start: from Hidden Line to Consistent Colors
         72.08   common start: from Hidden Line to Realistic
         21.62   common start: from Consistent Colors to Wireframe
         68.93   common start: from Consistent Colors to Hidden Line
         62.26   common start: from Consistent Colors to Shaded
         60.31   common start: from Consistent Colors to Realistic
        459.89   TOTAL
      Graphics - Change view visual style from a common end
         56.14   common end: from Wireframe to Hidden Line
         55.54   common end: from Shaded to Hidden Line
         71.98   common end: from Consistent Colors to Hidden Line
         65.45   common end: from Realistic to Hidden Line
         58.24   common end: from Wireframe to Consistent Colors
         60.14   common end: from Hidden Line to Consistent Colors
         58.40   common end: from Shaded to Consistent Colors
         59.10   common end: from Realistic to Consistent Colors
        484.99   TOTAL
      Graphics - Change view visual style in sequence
         24.13   in sequence: from Realistic to Wireframe
         68.41   in sequence: from Wireframe to Hidden Line
         63.82   in sequence: from Hidden Line to Shaded
         58.30   in sequence: from Shaded to Consistent Colors
         70.89   in sequence: from Consistent Colors to Realistic
         67.67   in sequence: from Realistic to Consistent Colors
         64.04   in sequence: from Consistent Colors to Shaded
         70.29   in sequence: from Shaded to Hidden Line
         22.11   in sequence: from Hidden Line to Wireframe
        509.66   TOTAL
      Graphics - Refresh views
         77.39   refresh Wireframe view x10
        167.52   refresh Hidden Line view x10
        188.49   refresh Shaded view x10
        184.06   refresh Consistent Colors view x10
        222.63   refresh Realistic view x10
        840.09   TOTAL
      Graphics - Rotate views
         19.89   activate View Cube view
        185.31   rotate view x1
         19.41   activate View Cube - Sketchy view
        266.92   rotate sketchy view x1
        491.53   TOTAL
      TEST CONDITIONS:
      Mfr: Microsoft Corporation
      Model: Surface Book
      CPU: Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz
      Max Clock Speed: 2.808Ghz
      Number of Processors: 2
      Number of Logical Processors: 4
      Total Physical Memory: 16GB @ 1867 1867Mhz
      Graphics Card: NVIDIA GeForce GPU
      Graphics RAM: 1GB
      Driver version: 21.21.13.7667
      Graphics Card: Intel(R) HD Graphics 520
      Graphics RAM: 1GB
      Driver version: 20.19.15.4463
      Screen Resolution:  1920x 1200x32bit @  60Hz
      Troy Gates - Director of Design Technology
      KTGY Group, Inc - http://twitter.com/troygates
        This is my results. Revit still doesn't really use multiple cores (dual xeon, 16cores 32 threads).
        Code:
        RVT 2018 - Full_Simplified set - 2017.09.17 @ 18.01.00 on DUPLAXEON.txt
            RevitForum.org
        Run on Revit 2018.1
            4.89   opening and loading the custom template
           21.16   creating the floors levels and grids
           37.50   creating a group of walls and doors
           69.18   modifying the group by adding a curtain wall
           24.25   creating the exterior curtain wall
           21.13   creating the sections
            7.93   changing the curtain wall panel type
           27.58   creating area plans
            3.25   creating and applying view template
          216.87   TOTAL
        Graphics
            7.25   activate View Styles view
            2.61   change view to Wireframe
            0.25   change view to Hidden
            0.97   change view to Shaded
            1.07   change view to Consistent Colors
            1.00   change view to Realistic
            2.41   refresh Wireframe Line view x10
           10.13   refresh Hidden Line view x10
           10.38   refresh Shaded view x10
            9.79   refresh Consistent Colors view x10
           11.99   refresh Realistic view x10
            1.11   activate View Cube view
            6.70   rotate view x1
           65.66   TOTAL
        Notes:
        TEST CONDITIONS:
        Mfr: ASUSTeK COMPUTER INC.
        Model: Z9PA-D8 Series
        OS: Microsoft Windows 10 Pro64 64-bit
        CPU: Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
        Max Clock Speed: Ghz
        Number of Processors: 8 8
        Number of Logical Processors: 16 16
        Total Physical Memory: 56GB @ 1333 1333 1333 1333 1333 1333 1333Mhz
        Drive Type: local Disk (NTFS)
        Drive Model: Samsung SSD 840 EVO 250GB
        Graphics Card: NVIDIA GeForce GTX 970
        Graphics RAM: 3.9990234375GB
        Driver version: 22.21.13.8541
        Graphics Card: Általános Microsoft-videokártya
        Graphics RAM: 0GB
        Driver version: 10.0.15063.0
        Screen Resolution: 1920 1920x1200 1200x32bit @ 59 59Hz
          Quite impressive numbers on a HP Z240 Workstation with a SSD disk:
          Code:
          RVT 2018 - Full_Standard set - 2017.09.18 @ 15.15.23 on PC-CADstudio.txt
              RevitForum.org
          Run on Revit 2018.1.1
          Update
              7.52   update previous version file
              2.77   opening and loading the custom template
             10.04   creating the floors levels and grids
             18.04   creating a group of walls and doors
             33.70   modifying the group by adding a curtain wall
             10.63   creating the exterior curtain wall
              9.06   creating the sections
              3.70   changing the curtain wall panel type
             12.35   creating area plans
              1.69   creating and applying view template
            101.98   TOTAL
          Export benchmark
             63.42   export all views as PNGs at 300 dpi
             48.64   export all views as DWFs
             99.85   export all views as DWGs
             57.69   print all views as vector *
             92.80   print all views as raster *
          Notes:
           *  Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
          Render benchmark
             78.74   render
          Graphics - Standard View
              3.95   activate View Styles view
              0.49   change view to Wireframe
              0.96   change view to Hidden
              1.14   change view to Shaded
              1.13   change view to Consistent Colors
              1.89   change view to Realistic
              0.95   refresh Wireframe Line view x10
              3.65   refresh Hidden Line view x10
              3.89   refresh Shaded view x10
              3.75   refresh Consistent Colors view x10
              4.12   refresh Realistic view x10
              0.56   activate View Cube view
              5.83   rotate view x1
             32.31   TOTAL
          Graphics - Sketchy View
              0.78   activate View Styles - Sketchy view
              2.38   change sketchy view to Wireframe
              1.35   change sketchy view to Hidden
              1.59   change sketchy view to Shaded
              1.58   change sketchy view to Consistent Colors
              1.39   change sketchy view to Realistic
              1.74   refresh sketchy Wireframe Line view x10
              4.46   refresh sketchy Hidden Line view x10
              4.68   refresh sketchy Shaded view x10
              4.51   refresh sketchy Consistent Colors view x10
              4.86   refresh sketchy Realistic view x10
              0.62   activate View Cube - Sketchy view
             12.81   rotate sketchy view x1
             42.75   TOTAL
          Notes:
          TEST CONDITIONS:
          Mfr: HP
          Model: HP Z240 Tower Workstation
          CPU: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
          Max Clock Speed: 3.401Ghz
          Total Physical Memory: 32GB @ 2133 2133Mhz
          Drive Model: MTFDDAK512TBN-1AR1ZABHA
          Graphics Card: NVIDIA Quadro K620
          Graphics RAM: 2GB
          Driver version: 22.21.13.8248
          Screen Resolution: 1920x1200x32bit @ 59Hz
            I ran it on my small core m notebook. not bad from a 4.5W chip.
            Code:
            RVT 2018 - Full_Simplified set - 2017.09.24 @ 17.22.44 on YOGA3PRO.txt
                RevitForum.org
            Run on Revit 2018.1
                5.31   opening and loading the custom template
               23.74   creating the floors levels and grids
               41.76   creating a group of walls and doors
               67.02   modifying the group by adding a curtain wall
               24.74   creating the exterior curtain wall
               22.17   creating the sections
                8.84   changing the curtain wall panel type
               32.10   creating area plans
                3.78   creating and applying view template
              229.46   TOTAL
            Graphics
                8.02   activate View Styles view
                4.88   change view to Wireframe
                0.35   change view to Hidden
                1.37   change view to Shaded
                1.45   change view to Consistent Colors
                1.39   change view to Realistic
                4.14   refresh Wireframe Line view x10
               16.05   refresh Hidden Line view x10
               16.06   refresh Shaded view x10
               15.19   refresh Consistent Colors view x10
               18.89   refresh Realistic view x10
                1.73   activate View Cube view
               13.36   rotate view x1
              102.88   TOTAL
            Notes:
            TEST CONDITIONS:
            Mfr: LENOVO
            Model: 80HE
            CPU: Intel(R) Processor 5Y70 CPU @ 1.10GHz
            Max Clock Speed: 1.301Ghz
            Total Physical Memory: 8GB @ 1600 1600Mhz
            Drive Model: SAMSUNG MZNTE256HMHP-000L2
            Graphics Card: Intel(R) HD Graphics 5300
            Graphics RAM: 1GB
            Driver version: 20.19.15.4642
            Screen Resolution: 1600x900x32bit @ 59Hz
              I7-7700, 32 GB ram, 960 Pro, 1080 TI - My results
              Code:
              RVT 2018 - Full_Standard set - 2017.10.04 @ 17.20.50 on TW.txt
                  RevitForum.org
              Run on Revit 2018.1
              Update
                  7.25   update previous version file
                  2.76   opening and loading the custom template
                  9.74   creating the floors levels and grids
                 16.76   creating a group of walls and doors
                 29.67   modifying the group by adding a curtain wall
                  9.80   creating the exterior curtain wall
                  8.59   creating the sections
                  3.47   changing the curtain wall panel type
                 11.35   creating area plans
                  1.59   creating and applying view template
                 93.73   TOTAL
              Export benchmark
                 50.50   export all views as PNGs at 300 dpi
                 41.13   export all views as DWFs
                 81.83   export all views as DWGs
                 48.56   print all views as vector *
                 70.41   print all views as raster *
              Notes:
              Render benchmark
                 67.76   render
                  3.54   activate View Styles view
                  0.41   change view to Wireframe
                  0.87   change view to Hidden
                  1.08   change view to Shaded
                  1.05   change view to Consistent Colors
                  1.67   change view to Realistic
                  0.86   refresh Wireframe Line view x10
                  3.58   refresh Hidden Line view x10
                  3.74   refresh Shaded view x10
                  3.60   refresh Consistent Colors view x10
                  3.85   refresh Realistic view x10
                  0.47   activate View Cube view
                  3.72   rotate view x1
                 28.44   TOTAL
                  0.49   activate View Styles - Sketchy view
                  1.89   change sketchy view to Wireframe
                  1.18   change sketchy view to Hidden
                  1.42   change sketchy view to Shaded
                  1.45   change sketchy view to Consistent Colors
                  1.28   change sketchy view to Realistic
                  1.54   refresh sketchy Wireframe Line view x10
                  4.23   refresh sketchy Hidden Line view x10
                  4.40   refresh sketchy Shaded view x10
                  4.26   refresh sketchy Consistent Colors view x10
                  4.52   refresh sketchy Realistic view x10
                  0.53   activate View Cube - Sketchy view
                 16.52   rotate sketchy view x1
                 43.71   TOTAL
              Notes:
              TEST CONDITIONS:
              Mfr: System manufacturer
              Model: System Product Name
              CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
              Max Clock Speed: 4.201Ghz
              Total Physical Memory: 32GB @ 1333 1333 1333 1333Mhz
              Drive Model: Samsung SSD 960 PRO 1TB
              Graphics Card: NVIDIA GeForce GTX 1080 Ti
              Driver version: 22.21.13.8205
              Screen Resolution: 2560x1600x32bit @ 59Hz
              RAW DATA:
                  8.008    6.891    6.852   update previous version file
                  2.844    2.750    2.695   opening and loading the custom template
                  9.711    9.812    9.699   creating the floors levels and grids
                 16.305   17.500   16.484   creating a group of walls and doors
                 29.438   30.180   29.398   modifying the group by adding a curtain wall
                  9.805    9.758    9.840   creating the exterior curtain wall
                  8.469    8.578    8.734   creating the sections
                  3.508    3.445    3.453   changing the curtain wall panel type
                 11.238   11.348   11.477   creating area plans
                  1.562    1.574    1.621   creating and applying view template
                 50.781   50.223   50.500   export all views as PNGs at 300 dpi
                 41.164   41.164   41.047   export all views as DWFs
                 82.047   82.106   81.332   export all views as DWGs
                 48.906   48.266   48.504   print all views as vector
                 70.578   69.980   70.664   print all views as raster
                 67.977   67.582   67.715   render
                  3.500    3.582    3.527   activate View Styles view
                  0.410    0.418    0.406   change view to Wireframe
                  0.852    0.844    0.902   change view to Hidden
                  1.059    1.086    1.090   change view to Shaded
                  1.035    1.051    1.051   change view to Consistent Colors
                  1.691    1.672    1.648   change view to Realistic
                  0.859    0.852    0.883   refresh Wireframe Line view x10
                  3.555    3.613    3.574   refresh Hidden Line view x10
                  3.723    3.727    3.766   refresh Shaded view x10
                  3.594    3.590    3.609   refresh Consistent Colors view x10
                  3.832    3.856    3.867   refresh Realistic view x10
                  0.488    0.461    0.457   activate View Cube view
                  3.844    3.621    3.703   rotate view x1
                  0.492    0.508    0.477   activate View Styles - Sketchy view
                  1.844    1.875    1.938   change sketchy view to Wireframe
                  1.164    1.180    1.184   change sketchy view to Hidden
                  1.402    1.453    1.402   change sketchy view to Shaded
                  1.414    1.434    1.492   change sketchy view to Consistent Colors
                  1.277    1.266    1.293   change sketchy view to Realistic
                  1.527    1.520    1.574   refresh sketchy Wireframe Line view x10
                  4.207    4.242    4.254   refresh sketchy Hidden Line view x10
                  4.379    4.398    4.418   refresh sketchy Shaded view x10
                  4.262    4.270    4.258   refresh sketchy Consistent Colors view x10
                  4.516    4.523    4.516   refresh sketchy Realistic view x10
                  0.531    0.535    0.527   activate View Cube - Sketchy view
                 16.461   16.609   16.477   rotate sketchy view x1
                Welcome to the forum Trey! :thumbsup:
                  Never actually ran the benchmark. But going to drink a Beer with Gordon tomorrow, so I feel obligated to do so .
                  Machine runs OK for the size of the projects I do, but am looking to buy a new one depending on what the financial numbers are at the end of the year
                  Code:
                  RVT 2018 - Full_Standard set - 2017.10.20 @ 21.48.40 on WORKSTATION.txt
                  RevitForum.org
                  Run on Revit 2018.2
                  Update
                     11.96   update previous version file
                      4.67   opening and loading the custom template
                     15.50   creating the floors levels and grids
                     29.75   creating a group of walls and doors
                     56.33   modifying the group by adding a curtain wall
                     17.53   creating the exterior curtain wall
                     13.81   creating the sections
                      6.30   changing the curtain wall panel type
                     19.31   creating area plans
                      2.64   creating and applying view template
                    165.84   TOTAL
                  Export benchmark
                     84.85   export all views as PNGs at 300 dpi
                     84.10   export all views as DWFs
                    163.34   export all views as DWGs
                  80142.63   print all views as vector *
                  80142.64   print all views as raster *
                  Notes:
                  Render benchmark
                    207.41   render
                      7.21   activate View Styles view
                      0.87   change view to Wireframe
                      1.76   change view to Hidden
                      2.31   change view to Shaded
                      2.34   change view to Consistent Colors
                      3.30   change view to Realistic
                      2.13   refresh Wireframe Line view x10
                      7.22   refresh Hidden Line view x10
                      7.86   refresh Shaded view x10
                      7.44   refresh Consistent Colors view x10
                      8.16   refresh Realistic view x10
                      1.06   activate View Cube view
                      5.55   rotate view x1
                     57.21   TOTAL
                      0.71   activate View Styles - Sketchy view
                      3.67   change sketchy view to Wireframe
                      2.30   change sketchy view to Hidden
                      2.87   change sketchy view to Shaded
                      2.95   change sketchy view to Consistent Colors
                      2.72   change sketchy view to Realistic
                      3.18   refresh sketchy Wireframe Line view x10
                      8.54   refresh sketchy Hidden Line view x10
                      8.97   refresh sketchy Shaded view x10
                      8.74   refresh sketchy Consistent Colors view x10
                      9.40   refresh sketchy Realistic view x10
                      1.14   activate View Cube - Sketchy view
                      6.56   rotate sketchy view x1
                     61.75   TOTAL
                  Notes:
                  TEST CONDITIONS:
                  Mfr: MSI
                  Model: MS-7673
                  CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
                  Max Clock Speed: 3.301Ghz
                  Total Physical Memory: 8GB @ 1333 1333 1333 1333Mhz
                  Drive Model: Samsung SSD 850 PRO 256GB ATA Device
                  Graphics Card: NVIDIA GeForce GTX 770
                  Graphics RAM: 2GB
                  Driver version: 23.21.13.8792
                  Screen Resolution: 1920x1080x32bit @ 60Hz
                  RAW DATA:
                     12.203   11.852   11.828   update previous version file
                      3.727    6.477    3.812   opening and loading the custom template
                     15.156   15.219   16.117   creating the floors levels and grids
                     29.500   30.094   29.656   creating a group of walls and doors
                     55.438   56.922   56.625   modifying the group by adding a curtain wall
                     17.352   17.766   17.477   creating the exterior curtain wall
                     13.984   13.773   13.672   creating the sections
                      6.273    6.445    6.180   changing the curtain wall panel type
                     19.047   20.031   18.844   creating area plans
                      2.727    2.578    2.602   creating and applying view template
                     84.219   86.898   83.430   export all views as PNGs at 300 dpi
                     84.656   85.133   82.516   export all views as DWFs
                    161.234  169.734  159.039   export all views as DWGs
                  79152.21080139.76081135.930   print all views as vector
                  79152.21080139.77081135.930   print all views as raster
                    205.523  228.094  188.617   render
                      7.320    7.156    7.148   activate View Styles view
                      0.781    0.836    0.992   change view to Wireframe
                      1.719    1.750    1.820   change view to Hidden
                      2.211    2.492    2.227   change view to Shaded
                      2.422    2.281    2.305   change view to Consistent Colors
                      3.414    3.453    3.023   change view to Realistic
                      2.172    2.242    1.977   refresh Wireframe Line view x10
                      7.117    7.367    7.172   refresh Hidden Line view x10
                      7.844    8.102    7.648   refresh Shaded view x10
                      7.258    7.766    7.297   refresh Consistent Colors view x10
                      8.188    8.398    7.891   refresh Realistic view x10
                      1.055    1.109    1.008   activate View Cube view
                      5.555    5.758    5.328   rotate view x1
                      0.570    0.797    0.758   activate View Styles - Sketchy view
                      3.703    3.695    3.617   change sketchy view to Wireframe
                      2.438    2.164    2.289   change sketchy view to Hidden
                      2.703    2.992    2.906   change sketchy view to Shaded
                      2.828    3.094    2.914   change sketchy view to Consistent Colors
                      2.641    2.922    2.594   change sketchy view to Realistic
                      3.219    3.258    3.070   refresh sketchy Wireframe Line view x10
                      8.430    8.836    8.367   refresh sketchy Hidden Line view x10
                      9.000    9.141    8.781   refresh sketchy Shaded view x10
                      8.531    9.102    8.578   refresh sketchy Consistent Colors view x10
                      9.305    9.688    9.211   refresh sketchy Realistic view x10
                      1.133    1.148    1.148   activate View Cube - Sketchy view
                      6.680    6.750    6.258   rotate sketchy view x1
                    Here are my 2018 results using custom built desktops running i7-7700k 4.2 stock and Turbo is set to 4.8 all cores and RAM is two 16GB sticks dual channel at 2900MHz with Nvidia GTX 1050.
                    Code:
                    RVT 2018 - Full_Standard set - 2017.10.31 @ 15.59.54 on ENGR115.txt
                        RevitForum.org
                    Run on Revit 2018.2
                    Update
                        6.18   update previous version file
                        2.44   opening and loading the custom template
                        7.51   creating the floors levels and grids
                       14.34   creating a group of walls and doors
                       27.29   modifying the group by adding a curtain wall
                        8.45   creating the exterior curtain wall
                        7.19   creating the sections
                        3.01   changing the curtain wall panel type
                        9.37   creating area plans
                        1.30   creating and applying view template
                       80.90   TOTAL
                    Export benchmark
                       49.10   export all views as PNGs at 300 dpi
                       37.52   export all views as DWFs
                       75.94   export all views as DWGs
                       43.27   print all views as vector *
                       71.24   print all views as raster *
                    Notes:
                    Render benchmark
                       63.89   render
                        3.19   activate View Styles view
                        0.42   change view to Wireframe
                        0.69   change view to Hidden
                        0.90   change view to Shaded
                        0.89   change view to Consistent Colors
                        1.45   change view to Realistic
                        0.72   refresh Wireframe Line view x10
                        2.86   refresh Hidden Line view x10
                        2.98   refresh Shaded view x10
                        2.86   refresh Consistent Colors view x10
                        3.14   refresh Realistic view x10
                        0.37   activate View Cube view
                        2.57   rotate view x1
                       23.04   TOTAL
                        0.34   activate View Styles - Sketchy view
                        1.59   change sketchy view to Wireframe
                        1.00   change sketchy view to Hidden
                        1.20   change sketchy view to Shaded
                        1.22   change sketchy view to Consistent Colors
                        1.09   change sketchy view to Realistic
                        1.35   refresh sketchy Wireframe Line view x10
                        3.47   refresh sketchy Hidden Line view x10
                        3.64   refresh sketchy Shaded view x10
                        3.49   refresh sketchy Consistent Colors view x10
                        3.76   refresh sketchy Realistic view x10
                        0.45   activate View Cube - Sketchy view
                        4.49   rotate sketchy view x1
                       27.09   TOTAL
                    Notes:
                    TEST CONDITIONS:
                    Max Turbo All Cores: 4.8GHz
                    Total Physical Memory: 32GB @ 2900 2900Mhz
                    Drive Model: Samsung SSD 850 EVO 500GB
                    Graphics Card: NVIDIA GeForce GTX 1050
                    Graphics RAM: 2GB
