RFO Benchmark v3.#
This is a sticky topic.
    RFO Benchmark v3.#
    It's finally here. RFO Benchmark 2022 is finally available. My apologies again for the late upload. The combination of dealing with the new builds for my work and the benchmark has gotten more and more challenging, the last two years especially.
    Also, I should note that I was not able to include the new PDF Output as part of the benchmark, try as I might. Neither of the approaches that I have used in other export tests to redirect output would work. Not a relative path from the journal location, and not a variable with a calculated path. The only option I had was to accept the default location, which would potentially leave output behind because I wouldn't know where to look to clean up, which I don't want to do. Perhaps if someone from Autodesk has the secret sauce I am missing that allows for this? I assume there must be some way, otherwise how would ADSK do regression testing on the new feature with multiple output locations?
    Also, thanks a TON Munkholm and Robin Deurloo , for the support getting the new download approach set up. 👏
    Anyway, enjoy!
    Please post your results in:
    RFO Benchmark v3 2022 results
    RFO Benchmark v3 2021 results
    RFO Benchmark v3 2020 results
    RFO Benchmark v3 2019 results
    RFO Benchmark v3 2018 results
    RFO Benchmark v3 2017 results
    RFO Benchmark v3 2016 results
    Version 3.3 for 2022, 2021, 2020 & 2019 has a few bug fixes.
    1. The main fix is the VERY long pause between individual tests. This is a very odd interaction between Revit and the Start-Process cmdlet in PowerShell, specifically PowerShell 5.1, which is what is included by default in Windows 10. The way Wait is handled has been changed to mitigate this.
    2. Functionality of the -showStatus switch has been repaired. This is required by another change in the way PowerShell in Windows 10 works.
    3. DPI scale warning functionality has been repaired.
    4. -foregroundMonitors switch added, to bring CPU-Z, GPU-Z, Task Manager & Resource Monitor to the foreground after Revit launches for each test, to facilitate monitoring resource use during the test. Note that Task Manager & Resource Monitor only work if the OS language is English due to the OS renaming these programs as the language changes.
    5. Miscellaneous small bug fixes and refactoring.
    6. PowerShell 5.1 is now required. This is the default version of PowerShell in Windows 10, which is where the vast majority of us are now. For Windows 7 users, you can download Windows Management Foundation 5.1 to upgrade your PowerShell. Hopefully not many are still in Windows 7. And of course Windows 8/8.1 isn't even supported for Revit any more. As far as actual benchmarks, they have not changed.
    Version 3.2 for 2019 has a few changes compared to previous versions. I am leaving this here for reference. Version 3.3 for 2019-2021 is, from a Tests standpoint, the same as v3.2.
    1. The Squiggly Lines graphics test has been removed from the Full_Standard set
    2. A new Graphics_Comparison set compares standard graphics views, squiggled views and now 3D levels views.
    3. If your DPI Scaling is above 150% you will get a warning, but the benchmark will proceed. If it crashes, especially in the middle of Model Creation, try setting your DPI Scaling lower. It seems there is a problem with high DPI scaling and journal playback. More detail on that in a separate post.
    4. DPI Scale is now included in the report, so we can try to grok what settings and what hardware actually works.
    This v3.1 benchmark changes a few things you should be aware of.
    1. Additional GPU testing options now allow detailed heavy/large model testing.
    2. The Standard & Expanded GPU tests now compare Sketchy and non-Sketchy views for both the regen and view cube tests. The Simplified test does only includes standard views.
    3. Graphics without Hardware Acceleration has been moved to a standalone GPU only test.
    4. Improved reporting of Revit build information.
    5. Test resources are now copied to a dedicated folder for processing, so multiple machines can be benchmarked from a network RFO benchmark folder. This facilitates benchmarking en mass.
    6. Various performance issues have been addressed, mostly related to how long the benchmark takes to run, not the actual Revit processing performance.
    7. The bug related to unzipping with 7ZIP has been addressed, however, the best unarchiving approach remains simply right clicking the ZIP file and choosing Extract All, thus using the built in Windows UnZIP capability.
    It's worth the reminder, while comparisons of results reported here at RFO are interesting, and often entertaining, this is not appropriate data for purchasing decisions. To use RFO Benchmark for meaningful comparisons you need to ensure consistent test conditions with no extra software running, identical screen sizes, etc.
    Downloads:
    RFOBenchmark_v3.1_2016 (right click and choose 'Save link as')
    RFOBenchmark_v3.1_2017 (right click and choose 'Save link as')
    RFOBenchmark_v3.1_2018 (right click and choose 'Save link as')
    RFOBenchmark_v3.3_2019 (right click and choose 'Save link as')
    RFOBenchmark_v3.3_2020 (right click and choose 'Save link as')
    RFOBenchmark_v3.3_2021 (right click and choose 'Save link as')
    RFOBenchmark_v3.3_2022 (right click and choose 'Save link as')
    Pragmatic Praxis
    So, I finally made time to finish this beast up. Sorry for the big delay. There was a LOT of under the hood fixes/changes this year, in both the PowerShell code and the Journal files, and this summer has been the busiest I have had in 10 years (woot to that!). I am making a promise to myself and everyone else now, there will NOT be so much change next year. My hope is that the journal files are now very stable, and next year we can simply add a 2019 suite and be done. time will tell.
    Thanks for your patience!
    Gordon
    Pragmatic Praxis
      "Could not load module" error
      Great tool. Going to be busy benchmarking at work!
      Just a quick tip for those who are getting the "Could not load module" error: Navigate to the Resources folder, right-click on the file "RFOBenchmark.psm1" and select Properties. Then click on Unblock and the script should run. (This applies to all versions).
        VERY good point esk0r. Thanks for the heads up for everyone.
        Also, you can unblock the ZIP file prior to unzipping, and all contents will also be unblocked.
        Gordon
        Pragmatic Praxis
          Hi, I am new. I did a google search for Revit Benchmarking that lead me here. I am not a Revit Ninja. I literally install it and patch it. I am using a Dell R730 running XenServer with some Nvidia cards and a issci back end tied to my SAN. The Revit Ninja's connect remotely via Citrix .ica. I want to test Revit 2016 and separately 2017 between SSDs on the server versus my SAN. Is there a benchmarking "profile" that I can use for this type of setup?
            Hello - new to the group so here goes. Run my first test this morning and these are the results. Not real sure how to read this - How does it look? what test should I run next? If I would save this folder on my network drive would the test still work? (this would be where we save all our Central Revit files.)
            Thank you.
            Code:
            RVT 2017 - Full_Standard set - 2017.10.19 @ 05.32.05 on IC-JOSHGBIM.txt
            RFO Benchmark v3.1 (build 01.09.2017)
            RevitForum.org
            All times are in seconds, lower is better.
            Run on Revit 2017.2.2
            __________________________________________________ _______________
            Update
            7.29 update previous version file
            Model creation benchmark
            3.17 opening and loading the custom template
            11.86 creating the floors levels and grids
            20.47 creating a group of walls and doors
            37.03 modifying the group by adding a curtain wall
            12.88 creating the exterior curtain wall
            8.52 creating the sections
            4.06 changing the curtain wall panel type
            9.84 creating area plans
            1.46 creating and applying view template
            109.29 TOTAL
            Export benchmark
            62.17 export all views as PNGs at 300 dpi
            47.63 export all views as DWFs
            102.41 export all views as DWGs
            69.99 print all views as vector *
            104.58 print all views as raster *
            Notes:
            * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
            Render benchmark
            66.05 render
            Graphics - Standard View
            4.97 activate View Styles view
            0.42 change view to Wireframe
            1.14 change view to Hidden
            1.19 change view to Shaded
            1.14 change view to Consistent Colors
            1.92 change view to Realistic
            0.94 refresh Wireframe Line view x10
            3.95 refresh Hidden Line view x10
            4.18 refresh Shaded view x10
            3.93 refresh Consistent Colors view x10
            4.32 refresh Realistic view x10
            0.52 activate View Cube view
            3.58 rotate view x1
            32.20 TOTAL
            Graphics - Sketchy View
            0.56 activate View Styles - Sketchy view
            2.16 change sketchy view to Wireframe
            1.26 change sketchy view to Hidden
            1.64 change sketchy view to Shaded
            1.66 change sketchy view to Consistent Colors
            1.41 change sketchy view to Realistic
            1.83 refresh sketchy Wireframe Line view x10
            4.82 refresh sketchy Hidden Line view x10
            5.09 refresh sketchy Shaded view x10
            4.85 refresh sketchy Consistent Colors view x10
            5.22 refresh sketchy Realistic view x10
            0.63 activate View Cube - Sketchy view
            13.42 rotate sketchy view x1
            44.55 TOTAL
            Notes:
            Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
            To meaningfully compare graphics cards, test all cards in the same machine
            and use the 'Graphics - expanded' benchmark.
            TEST CONDITIONS:
            Mfr: To Be Filled By O.E.M.
            Model: To Be Filled By O.E.M.
            OS: Microsoft Windows 10 Pro64-bit
            CPU: Intel(R) Core(TM) i7-6850K CPU @ 3.60GHz
            Max Clock Speed: 3.601Ghz
            Number of Processors: 6
            Number of Logical Processors: 12
            Total Physical Memory: 64GB @ 3200 3200 3200 3200Mhz
            Drive Type: local Disk (NTFS)
            Drive Model: Samsung SSD 960 EVO 500GB
            Graphics Card: NVIDIA GeForce GTX 1080
            Graphics RAM: 3.9990234375GB
            Driver version: 22.21.13.8253
            Screen Resolution: 2560x1440x32bit @ 59Hz
            RAW DATA:
            7.357 7.225 7.273 update previous version file
            3.150 3.191 3.166 opening and loading the custom template
            11.633 12.012 11.945 creating the floors levels and grids
            20.785 20.445 20.166 creating a group of walls and doors
            37.393 36.760 36.928 modifying the group by adding a curtain wall
            12.621 12.594 13.424 creating the exterior curtain wall
            8.367 8.328 8.879 creating the sections
            4.020 3.982 4.180 changing the curtain wall panel type
            9.564 9.738 10.209 creating area plans
            1.428 1.432 1.516 creating and applying view template
            62.002 61.516 62.992 export all views as PNGs at 300 dpi
            47.965 46.832 48.098 export all views as DWFs
            99.111 107.002 101.129 export all views as DWGs
            66.797 75.045 68.121 print all views as vector
            94.207 112.434 107.104 print all views as raster
            64.600 65.135 68.418 render
            5.006 4.938 4.957 activate View Styles view
            0.414 0.418 0.434 change view to Wireframe
            1.119 1.141 1.156 change view to Hidden
            1.148 1.156 1.256 change view to Shaded
            1.113 1.146 1.156 change view to Consistent Colors
            1.898 1.883 1.980 change view to Realistic
            0.926 0.934 0.955 refresh Wireframe Line view x10
            3.896 3.924 4.022 refresh Hidden Line view x10
            4.143 4.203 4.205 refresh Shaded view x10
            3.875 3.879 4.037 refresh Consistent Colors view x10
            4.254 4.281 4.424 refresh Realistic view x10
            0.508 0.529 0.525 activate View Cube view
            3.527 3.541 3.666 rotate view x1
            0.547 0.555 0.570 activate View Styles - Sketchy view
            2.121 2.172 2.178 change sketchy view to Wireframe
            1.246 1.266 1.277 change sketchy view to Hidden
            1.600 1.643 1.672 change sketchy view to Shaded
            1.639 1.604 1.734 change sketchy view to Consistent Colors
            1.398 1.385 1.445 change sketchy view to Realistic
            1.812 1.818 1.857 refresh sketchy Wireframe Line view x10
            4.736 4.789 4.926 refresh sketchy Hidden Line view x10
            5.066 4.967 5.244 refresh sketchy Shaded view x10
            4.777 4.748 5.014 refresh sketchy Consistent Colors view x10
            5.156 5.115 5.398 refresh sketchy Realistic view x10
            0.611 0.633 0.633 activate View Cube - Sketchy view
            13.369 13.279 13.625 rotate sketchy view x1
              Code:
              RVT 2017 - Full_Standard set - 2017.10.20 @ 19.34.56 on ZEBBE.txt
              RevitForum.org
              Run on Revit 2017 FCS
              Update
              6.16 update previous version file
              2.63 opening and loading the custom template
              8.04 creating the floors levels and grids
              15.25 creating a group of walls and doors
              28.98 modifying the group by adding a curtain wall
              9.48 creating the exterior curtain wall
              6.49 creating the sections
              3.31 changing the curtain wall panel type
              7.85 creating area plans
              1.09 creating and applying view template
              83.12 TOTAL
              Export benchmark
              51.14 export all views as PNGs at 300 dpi
              71.72 export all views as DWFs
              118.19 export all views as DWGs
              58.88 print all views as vector *
              81.38 print all views as raster *
              Notes:
              Render benchmark
              75.05 render
              3.83 activate View Styles view
              0.38 change view to Wireframe
              0.77 change view to Hidden
              1.00 change view to Shaded
              0.99 change view to Consistent Colors
              1.60 change view to Realistic
              0.78 refresh Wireframe Line view x10
              3.01 refresh Hidden Line view x10
              3.18 refresh Shaded view x10
              3.04 refresh Consistent Colors view x10
              3.37 refresh Realistic view x10
              0.39 activate View Cube view
              2.89 rotate view x1
              25.23 TOTAL
              0.38 activate View Styles - Sketchy view
              1.80 change sketchy view to Wireframe
              1.07 change sketchy view to Hidden
              1.34 change sketchy view to Shaded
              1.35 change sketchy view to Consistent Colors
              1.23 change sketchy view to Realistic
              1.45 refresh sketchy Wireframe Line view x10
              3.70 refresh sketchy Hidden Line view x10
              3.85 refresh sketchy Shaded view x10
              3.73 refresh sketchy Consistent Colors view x10
              4.01 refresh sketchy Realistic view x10
              0.47 activate View Cube - Sketchy view
              6.28 rotate sketchy view x1
              30.66 TOTAL
              Notes:
              TEST CONDITIONS:
              Mfr: ASUS
              Model: All Series
              CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
              Max Clock Speed: 4.001Ghz
              Number of Processors: 4
              Number of Logical Processors: 8
              Total Physical Memory: 16GB @ 1600 1600Mhz
              Drive Model: Samsung SSD 850 PRO 256GB
              Graphics Card: NVIDIA GeForce GTX 970
              Driver version: 22.21.13.8541
              Screen Resolution: 1920x1080x32bit @ 143Hz
              RAW DATA:
              6.180 6.133 6.164 update previous version file
              2.617 2.617 2.656 opening and loading the custom template
              8.008 8.148 7.961 creating the floors levels and grids
              15.352 15.211 15.195 creating a group of walls and doors
              28.930 29.109 28.891 modifying the group by adding a curtain wall
              9.336 9.742 9.352 creating the exterior curtain wall
              6.586 6.617 6.281 creating the sections
              3.344 3.305 3.273 changing the curtain wall panel type
              7.742 7.992 7.820 creating area plans
              1.062 1.117 1.086 creating and applying view template
              51.836 50.711 50.859 export all views as PNGs at 300 dpi
              71.586 71.125 72.453 export all views as DWFs
              119.227 117.641 117.695 export all views as DWGs
              58.352 58.461 59.820 print all views as vector
              81.430 79.609 83.102 print all views as raster
              70.695 81.617 72.828 render
              4.031 3.812 3.648 activate View Styles view
              0.375 0.367 0.383 change view to Wireframe
              0.766 0.773 0.766 change view to Hidden
              0.977 0.984 1.031 change view to Shaded
              0.969 0.992 1.023 change view to Consistent Colors
              1.609 1.586 1.594 change view to Realistic
              0.781 0.781 0.789 refresh Wireframe Line view x10
              3.016 3.000 3.016 refresh Hidden Line view x10
              3.180 3.164 3.195 refresh Shaded view x10
              3.047 3.031 3.055 refresh Consistent Colors view x10
              3.344 3.359 3.414 refresh Realistic view x10
              0.391 0.391 0.398 activate View Cube view
              2.852 2.867 2.938 rotate view x1
              0.375 0.367 0.406 activate View Styles - Sketchy view
              1.789 1.805 1.797 change sketchy view to Wireframe
              1.055 1.086 1.070 change sketchy view to Hidden
              1.336 1.328 1.367 change sketchy view to Shaded
              1.359 1.344 1.352 change sketchy view to Consistent Colors
              1.211 1.219 1.250 change sketchy view to Realistic
              1.461 1.445 1.453 refresh sketchy Wireframe Line view x10
              3.680 3.711 3.719 refresh sketchy Hidden Line view x10
              3.836 3.836 3.867 refresh sketchy Shaded view x10
              3.734 3.719 3.742 refresh sketchy Consistent Colors view x10
              3.984 3.992 4.047 refresh sketchy Realistic view x10
              0.477 0.469 0.469 activate View Cube - Sketchy view
              6.383 6.141 6.320 rotate sketchy view x1
                Code:
                RVT 2017 - Full_Standard set - 2017.10.31 @ 10.40.26 on DBS-C016.txt
                RevitForum.org
                Run on Revit 2017.2.1
                Update
                10.64 update previous version file
                3.81 opening and loading the custom template
                12.24 creating the floors levels and grids
                27.39 creating a group of walls and doors
                52.10 modifying the group by adding a curtain wall
                15.40 creating the exterior curtain wall
                10.15 creating the sections
                5.49 changing the curtain wall panel type
                11.45 creating area plans
                1.64 creating and applying view template
                139.67 TOTAL
                Export benchmark
                68.24 export all views as PNGs at 300 dpi
                69.42 export all views as DWFs
                131.43 export all views as DWGs
                78.73 print all views as vector *
                107.53 print all views as raster *
                Notes:
                Render benchmark
                85.86 render
                6.26 activate View Styles view
                0.55 change view to Wireframe
                1.58 change view to Hidden
                1.74 change view to Shaded
                1.75 change view to Consistent Colors
                2.62 change view to Realistic
                1.56 refresh Wireframe Line view x10
                6.10 refresh Hidden Line view x10
                6.56 refresh Shaded view x10
                6.19 refresh Consistent Colors view x10
                6.84 refresh Realistic view x10
                0.80 activate View Cube view
                4.49 rotate view x1
                47.04 TOTAL
                0.62 activate View Styles - Sketchy view
                2.89 change sketchy view to Wireframe
                1.73 change sketchy view to Hidden
                2.31 change sketchy view to Shaded
                2.30 change sketchy view to Consistent Colors
                2.08 change sketchy view to Realistic
                2.59 refresh sketchy Wireframe Line view x10
                7.16 refresh sketchy Hidden Line view x10
                7.65 refresh sketchy Shaded view x10
                7.27 refresh sketchy Consistent Colors view x10
                7.93 refresh sketchy Realistic view x10
                0.91 activate View Cube - Sketchy view
                7.76 rotate sketchy view x1
                53.20 TOTAL
                Notes:
                TEST CONDITIONS:
                Mfr: Hewlett-Packard
                Model: HP Z420 Workstation
                OS: Microsoft Windows 8.1 Pro64-bit
                CPU: Intel(R) Xeon(R) CPU E5-1650 v2 @ 3.50GHz
                Max Clock Speed: 3.501Ghz
                Total Physical Memory: 16GB @ 1866 1600 1600 1866Mhz
                Drive Model: Crucial_CT480M500SSD1
                Graphics Card: NVIDIA Quadro M4000
                Driver version: 21.21.13.7633
                Screen Resolution: 1920x1080x32bit @ 60Hz
                RAW DATA:
                10.730 10.598 10.602 update previous version file
                3.785 3.805 3.832 opening and loading the custom template
                11.844 12.668 12.203 creating the floors levels and grids
                27.383 27.500 27.277 creating a group of walls and doors
                51.797 52.391 52.125 modifying the group by adding a curtain wall
                15.344 15.594 15.262 creating the exterior curtain wall
                10.000 10.348 10.117 creating the sections
                5.508 5.477 5.477 changing the curtain wall panel type
                11.578 11.625 11.148 creating area plans
                1.625 1.668 1.625 creating and applying view template
                68.074 68.430 68.215 export all views as PNGs at 300 dpi
                69.266 69.402 69.586 export all views as DWFs
                131.535 130.875 131.871 export all views as DWGs
                78.879 78.258 79.039 print all views as vector
                108.469 105.215 108.910 print all views as raster
                85.305 86.394 85.879 render
                6.254 6.301 6.227 activate View Styles view
                0.539 0.555 0.555 change view to Wireframe
                1.551 1.570 1.621 change view to Hidden
                1.742 1.727 1.754 change view to Shaded
                1.754 1.738 1.762 change view to Consistent Colors
                2.606 2.621 2.633 change view to Realistic
                1.570 1.547 1.562 refresh Wireframe Line view x10
                6.070 6.102 6.133 refresh Hidden Line view x10
                6.559 6.527 6.598 refresh Shaded view x10
                6.172 6.168 6.230 refresh Consistent Colors view x10
                6.824 6.828 6.863 refresh Realistic view x10
                0.797 0.793 0.801 activate View Cube view
                4.496 4.465 4.520 rotate view x1
                0.613 0.613 0.625 activate View Styles - Sketchy view
                2.871 2.887 2.914 change sketchy view to Wireframe
                1.711 1.734 1.750 change sketchy view to Hidden
                2.301 2.305 2.332 change sketchy view to Shaded
                2.305 2.273 2.328 change sketchy view to Consistent Colors
                2.078 2.066 2.109 change sketchy view to Realistic
                2.594 2.582 2.598 refresh sketchy Wireframe Line view x10
                7.156 7.129 7.188 refresh sketchy Hidden Line view x10
                7.641 7.617 7.695 refresh sketchy Shaded view x10
                7.254 7.234 7.320 refresh sketchy Consistent Colors view x10
                7.914 7.887 8.004 refresh sketchy Realistic view x10
                0.914 0.910 0.914 activate View Cube - Sketchy view
                7.730 7.750 7.793 rotate sketchy view x1
                  Quick question. I have a non-standard install, in that the root program is loaded on my D: drive and my libraries are on an E: drive. I tried running the 2017 and 2018 versions, and I get an error saying Revit 2018 (or 2017) can't be found. I checked out the .ini found and changed the line weight path to the D: drive but still nothing.
                  Any suggestions?
                    I have the same instalation. You will need to go into the RFOBenchmar_YYYY.ps1 edit the windows power shell to change the lines of the code that reference C:\ and replace with D:\ . This is the same with the RFOBenchmark_YYY.xml document and Revit_YYYY.ini files.
                    Any suggestions?
