New Surface Pro with Revit 2017 Issue
    I got new surface pro recently with i7 8G SSD256GB. But when i using chrome and revit 2017 in the same time, sometime when i issue more than 5 pages of PDF, it shows low memory..... It doesn't happen to my old computer with same configurations. Also i noticed, revit 2017 on new surface pro is "slowness" such as when i select objects, you can feel a little bit delay, it makes me feel not comfortable to use revit on surface pro..... Anyone got the same issues or it just my personal feel? I am going to try reinstall windows 10 and reinstall revit 2017 with recent revit update, maybe its windows 10 default setting using too much memories on the background....
    How much hard drive space do you have left? 256gb isn't much....neither is 8gb of ram.
      Pretty certain it's the Integrated GPU choking.
      My friend can run FC3 on her SP4 (okay, w/ vfx turned down, but still a mighty impressive feat) but the second anything else kicks in, it dies - and, to draw a similar comparison, here at work we've lowly K2200 - that can run Enscape 1080p on Ultra fine and dandy UNTIL you ask the computer to do anything else.
        So you're trying to run Revit with hardware acceleration on this chipset? <below> Last I checked this is the only i7 that was available in that configuration for the SP4.
        • 6th Gen 2.2-GHz Intel Core i7-6650U processor with Intel Iris graphics 540
        Its a dual-core. 2C/4T
        Intel® Core™ i7-6650U Processor (4M Cache, up to 3.40 GHz) Product Specifications
        4Mb cache...? I had that in 2008 and Revit dragged...
        Also, any nvidia dedicated graphics card would have been Maxwell at that point. At best a 1Gb card, but at least running DDR5 at more than a base clock of 300Mhz like the Iris 520.
        In other words, a lot of bottle necks. You are experiencing what a lot of people are facing on SP4. We all want it to run 150Mb Revit models, plus rendering, plus bluebeam, but it just can't on 15watts of processor performance limits just yet. It'll operate, but not at the efficiency you've come to expect from a true laptop.
        RB Cameron, AIA, LEED AP, EDAC, NCARB
        Architect - Parametric Designer - Visualization Instructor
        Download Healthcare Revit Models
        Download Revit+3dsMax Models
          What did you end up figuring out? I work for a government agency and we are going to all surface pros to replace the desktops. I'm the only architect in the district so I'm the odd one out. Trying to see how to make this set up work for me. I don't model whole buildings. I do interior renovations, so at most a model is a small suite of rooms. Usually, just one room.
          Pamela, Architect
            Just prepare for the worst. Get latest Gen i7, GTX graphics chip with +1GB VRAM, SSD 512GB min, & most importantly a min of 16GB RAM but 24GB is sweet spot. Kinda hard to get that much RAM in an SP, so you'll have to change your RAM "paging" settings to the max allowable, which by simply having a SSD will help exponentially.
              Thank you!
              Pamela, Architect
