switch licenses between 2 machines
    we have 2 BDSU licenses (version 2013), one is network, one is stand-alone, is it possible to switch w/o uninstall/reinstall on each machine? thanks
    You might be able to do it through the registry, but as far as I know you can't do what you're asking without an uninstall/reinstall.
      thanks need4mospd, too risky to mess w/ registry, time to do uninstall/reinstall.
        See if you can use the license transfer utility to remove the stand-alone license and then activate it using the network license.
        chad
          I believe they removed this capability in 2012
          Sent from my Transformer Prime TF201 using Tapatalk 2
