RFOBenchmark 2011 results
    Please post your RFOBenchmark results for the 2011 products here.
    Comments and suggestions should be made in the RFOBenchmark thread.
    Thanks!
    Gordon
    Pragmatic Praxis
    RFO Benchmark v03.20.2011 (RST 2011) run at 3/23/2011 5:18:07 PM
    RevitForum.org
    Model creation and view export benchmark
    8.00 opening and loading the custom template
    10.00 creating the floors levels and grids
    29.00 creating a group of walls and doors
    51.00 modifying the group by adding a curtain wall
    23.00 creating the exterior curtain wall
    11.00 creating the sections
    12.00 changing the curtain wall panel type
    42.00 export all views as PNGs
    62.00 export some views as DWGs
    248.00 Total
    Render benchmark
    436.00 render
    GPU benchmark
    8.00 refresh Hidden Line view - with hardware acceleration
    5.00 refresh Consistent Colors view - with hardware acceleration
    5.00 refresh Realistic view - with hardware acceleration
    9.00 rotate view - with hardware acceleration
    59.00 refresh Hidden Line view - without hardware acceleration
    6.00 refresh Consistent Colors view - without hardware acceleration
    58.00 refresh Realistic view - without hardware acceleration
    105.00 rotate view - without hardware acceleration
    MACHINE SPEC:
    OS: Microsoft Windows XP Professional x64 Edition 64-bit
    CPU: Intel(R) Pentium(R) III Xeon processor
    Max Clock Speed: 2.67 GHz
    Number of Processors: 8
    Number of Logical Processors:
    Total Physical Memory: 7.98 GB
    : 2.00 GB @ 1333 MHz
    : 0.00 GB @ MHz
    Graphics Card: NVIDIA Quadro FX 1800
    Graphics RAM: 768 MB
    Driver version: 6.14.11.9703
    -Alex Cunningham
      Our "New" spec machines
      RFO Benchmark v03.20.2011 (RAC 2011) run at 3/22/2011 6:13:21 PM
      RevitForum.org
      5.00 opening and loading the custom template
      8.00 creating the floors levels and grids
      25.00 creating a group of walls and doors
      42.00 modifying the group by adding a curtain wall
      20.00 creating the exterior curtain wall
      9.00 creating the sections
      10.00 changing the curtain wall panel type
      39.00 export all views as PNGs
      45.00 export some views as DWGs
      203.00 Total
      Render benchmark
      317.00 render
      GPU benchmark
      7.00 refresh Hidden Line view - with hardware acceleration
      4.00 refresh Consistent Colors view - with hardware acceleration
      8.00 rotate view - with hardware acceleration
      48.00 refresh Hidden Line view - without hardware acceleration
      5.00 refresh Consistent Colors view - without hardware acceleration
      48.00 refresh Realistic view - without hardware acceleration
      78.00 rotate view - without hardware acceleration
      MACHINE SPEC:
      OS: Microsoft Windows 7 Professional 64-bit
      CPU: Intel(R) Core(TM) i7 CPU K 875 @ 2.93GHz
      Max Clock Speed: 2.93 GHz
      Number of Processors: 1
      Number of Logical Processors: 8
      Total Physical Memory: 7.93 GB
      CHANNEL A-DIMM 0: 4.00 GB @ 1333 MHz
      CHANNEL B-DIMM 0: 4.00 GB @ 1333 MHz
      Graphics Card: NVIDIA GeForce GTX 470
      Graphics RAM: 1.25 GB
      Driver version: 8.17.12.5896
      Pragmatic Praxis
        RFO Benchmark v03.20.2011 (RAC 2011) run at 24-03-2011 21:35:32
        RevitForum.org
        6,00 opening and loading the custom template
        11,00 creating the floors levels and grids
        26,00 creating a group of walls and doors
        40,00 modifying the group by adding a curtain wall
        23,00 creating the exterior curtain wall
        12,00 creating the sections
        12,00 changing the curtain wall panel type
        39,00 export all views as PNGs
        49,00 export some views as DWGs
        218,00 Total
        Render benchmark
        315,00 render
        GPU benchmark
        7,00 refresh Hidden Line view - with hardware acceleration
        4,00 refresh Consistent Colors view - with hardware acceleration
        5,00 refresh Realistic view - with hardware acceleration
        8,00 rotate view - with hardware acceleration
        55,00 refresh Hidden Line view - without hardware acceleration
        6,00 refresh Consistent Colors view - without hardware acceleration
        52,00 refresh Realistic view - without hardware acceleration
        141,00 rotate view - without hardware acceleration
        MACHINE SPEC:
        CPU: AMD Phenom(tm) II X6 1090T Processor
        Max Clock Speed: 3,20 GHz
        Number of Logical Processors: 6
        Total Physical Memory: 16,00 GB
        Bank0/1: 4,00 GB @ 1333 MHz
        Bank2/3: 4,00 GB @ 1333 MHz
        Bank4/5: 4,00 GB @ 1333 MHz
        Bank6/7: 4,00 GB @ 1333 MHz
        Graphics Card: ATI Radeon HD 5700 Series
        Graphics RAM: 1,00 GB
        Driver version: 8.782.0.0
          RFO Benchmark v03.20.2011 (RAC 2011) run at 3/23/2011 6:44:04 PM
          RevitForum.org
          27.00 creating a group of walls and doors
          52.00 modifying the group by adding a curtain wall
          17.00 creating the exterior curtain wall
          8.00 changing the curtain wall panel type
          43.00 export all views as PNGs
          53.00 export some views as DWGs
          222.00 Total
          Render benchmark
          328.00 render
          GPU benchmark
          0.00 refresh Hidden Line view - with hardware acceleration
          0.00 refresh Consistent Colors view - with hardware acceleration
          0.00 refresh Realistic view - with hardware acceleration
          62.00 rotate view - with hardware acceleration
          0.00 refresh Hidden Line view - without hardware acceleration
          0.00 refresh Consistent Colors view - without hardware acceleration
          0.00 refresh Realistic view - without hardware acceleration
          62.00 rotate view - without hardware acceleration
          MACHINE SPEC:
          OS: Microsoft Windows 7 Enterprise 64-bit
          CPU: Intel(R) Xeon(R) CPU E5640 @ 2.67GHz
          Max Clock Speed: 2.66 GHz
          Number of Processors: 2
          Number of Logical Processors: 16
          Total Physical Memory: 47.98 GB
          : 0.00 GB @ MHz
          Graphics Card: NVIDIA Quadro 4000
          Graphics RAM: -2,048 MB
          Driver version: 8.17.12.6570
          Last edited by Alex Cunningham; March 24, 2011, 11:16 PM. Reason: this was run from a RDC connection over a LAN
          -Alex Cunningham
            Current Workstation:
            RFO Benchmark v03.20.2011 (RST 2011) run at 23/03/2011 1:07:37 PM
            RevitForum.org
            30.00 creating a group of walls and doors
            49.00 modifying the group by adding a curtain wall
            24.00 creating the exterior curtain wall
            12.00 creating the sections
            60.00 export some views as DWGs
            247.00 Total
            Render benchmark
            429.00 render
            GPU benchmark
            6.00 refresh Realistic view - with hardware acceleration
            56.00 refresh Hidden Line view - without hardware acceleration
            55.00 refresh Realistic view - without hardware acceleration
            97.00 rotate view - without hardware acceleration
            MACHINE SPEC:
            CPU: Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
            Max Clock Speed: 2.80 GHz
            Number of Logical Processors: 4
            Total Physical Memory: 12.00 GB
            Graphics Card: NVIDIA Quadro FX 580
            Graphics RAM: 512 MB
            Driver version: 8.16.11.9175
            Revit BLOGGAGE
            http://www.revic.org.au
              HP EliteBook 8540w
              RFO Benchmark v03.20.2011 (RME 2011) run at 3/24/2011 5:00:32 PM
              RevitForum.org
              12.00 opening and loading the custom template
              13.00 creating the floors levels and grids
              33.00 creating a group of walls and doors
              50.00 modifying the group by adding a curtain wall
              25.00 creating the exterior curtain wall
              13.00 creating the sections
              13.00 changing the curtain wall panel type
              41.00 export all views as PNGs
              55.00 export some views as DWGs
              255.00 Total
              Render benchmark
              627.00 render
              GPU benchmark
              7.00 rotate view - with hardware acceleration
              52.00 refresh Hidden Line view - without hardware acceleration
              52.00 refresh Realistic view - without hardware acceleration
              66.00 rotate view - without hardware acceleration
              MACHINE SPEC:
              CPU: Intel(R) Core(TM) i7 CPU M 640 @ 2.80GHz
              Total Physical Memory: 7.86 GB
              BANK 0: 4.00 GB @ 1333 MHz
              BANK 2: 4.00 GB @ 1333 MHz
              Graphics Card: NVIDIA Quadro FX 880M
              Graphics RAM: 1.00 GB
              Driver version: 8.17.12.6658
              Troy Gates - Director of Design Technology
              KTGY Group, Inc - http://twitter.com/troygates
                RFO Benchmark v03.20.2011 (RAC 2011) run at 3/28/2011 10:11:52 PM
                RevitForum.org
                11.00 creating the floors levels and grids
                32.00 creating a group of walls and doors
                29.00 creating the exterior curtain wall
                15.00 creating the sections
                14.00 changing the curtain wall panel type
                51.00 export all views as PNGs
                73.00 export some views as DWGs
                285.00 Total
                Render benchmark
                507.00 render
                GPU benchmark
                9.00 refresh Hidden Line view - with hardware acceleration
                7.00 refresh Realistic view - with hardware acceleration
                10.00 rotate view - with hardware acceleration
                63.00 refresh Hidden Line view - without hardware acceleration
                7.00 refresh Consistent Colors view - without hardware acceleration
                62.00 refresh Realistic view - without hardware acceleration
                81.00 rotate view - without hardware acceleration
                MACHINE SPEC:
                CPU: Intel(R) Core(TM) i7 CPU Q 820 @ 1.73GHz
                Max Clock Speed: 1.73 GHz
                Graphics Card: NVIDIA Quadro FX 3800M
                Driver version: 8.16.11.8921
                Dan
                  RFO Benchmark v03.20.2011 (RST 2011) run at 3/29/2011 12:24:26 PM
                  RevitForum.org
                  12.00 creating the floors levels and grids
                  40.00 creating a group of walls and doors
                  73.00 modifying the group by adding a curtain wall
                  31.00 creating the exterior curtain wall
                  17.00 changing the curtain wall panel type
                  62.00 export all views as PNGs
                  88.00 export some views as DWGs
                  348.00 Total
                  Render benchmark
                  1,113.00 render
                  GPU benchmark
                  4.00 refresh Hidden Line view - with hardware acceleration
                  1.00 refresh Consistent Colors view - with hardware acceleration
                  3.00 refresh Realistic view - with hardware acceleration
                  11.00 rotate view - with hardware acceleration
                  32.00 refresh Hidden Line view - without hardware acceleration
                  1.00 refresh Consistent Colors view - without hardware acceleration
                  32.00 refresh Realistic view - without hardware acceleration
                  59.00 rotate view - without hardware acceleration
                  MACHINE SPEC:
                  OS: Microsoft Windows XP Professional 32-bit
                  CPU: Intel(R) Core(TM)2 Duo CPU E6550 @ 2.33GHz
                  Max Clock Speed: 2.33 GHz
                  Number of Logical Processors: 2
                  Total Physical Memory: 2.00 GB
                  Bank0/1: 1.00 GB @ 667 MHz
                  Bank2/3: 1.00 GB @ 667 MHz
                  Graphics Card: ATI Radeon X1300/X1550 Series
                  Driver version: 6.14.10.6925
                  Graphics Card: ATI Radeon X1300/X1550 Series Secondary
                  Revit Architecture 2013 Certified Professional
                    RFO Benchmark v03.20.2011 (RAC 2011) run at 3/30/2011 3:22:44 PM
                    RevitForum.org
                    47.00 modifying the group by adding a curtain wall
                    52.00 export some views as DWGs
                    233.00 Total
                    Render benchmark
                    432.00 render
                    GPU benchmark
                    3.00 refresh Consistent Colors view - with hardware acceleration
                    53.00 refresh Hidden Line view - without hardware acceleration
                    108.00 rotate view - without hardware acceleration
                    MACHINE SPEC:
                    CPU: Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz
                    Total Physical Memory: 16.00 GB
                    BANK0: 4.00 GB @ 1333 MHz
                    BANK1: 4.00 GB @ 1333 MHz
                    BANK2: 4.00 GB @ 1333 MHz
                    BANK3: 4.00 GB @ 1333 MHz
                    Graphics Card: ATI Radeon HD 5800 Series
                    Driver version: 8.771.0.0
                    Travis Vaughan, AIA, NCARB, LEED AP
                    LinkedIn Profile | Twitter: @TravisUsesRevit
