Our New Home (take 2)
    Ok. With the domain reassigned and the dns sorted, we can now see how the new home stacks up.
    For me, somewhat better.
    Traceroute now direct to ServInt servers. DNS has reached Oz. w00t!!
    $ traceroute Revit Forum - Revit, BIM, Architecture & Engineering.
    traceroute to revitforum.org (216.38.52.175), 30 hops max, 38 byte packets
    1 mas4-vl300.gw.optusnet.com.au (211.29.132.2) 0.328 ms 0.205 ms 0.235 ms
    2 mas1-ge9-0.gw.optusnet.com.au (211.29.129.33) 0.238 ms 0.225 ms 0.236 ms
    3 mas3-ge2-0.gw.optusnet.com.au (211.29.125.237) 0.361 ms 0.355 ms 0.239 ms
    4 203.208.192.97 (203.208.192.97) 159.803 ms 193.714 ms 159.764 ms
    5 ge9-10.br01.lax05.pccwbtn.net (63.218.73.101) 160.005 ms ge9-11.br01.lax05.pccwbtn.net (63.218.73.105) 160.374 ms ge9-10.br01.lax05.pccwbtn.net (63.218.73.101) 160.253 ms
    6 servint.tenge10-3.br01.rst01.pccwbtn.net (63.218.125.22) 227.954 ms 228.453 ms 228.089 ms
    7 sc-smv1168.servint.net (209.50.237.80) 227.217 ms 227.562 ms 227.215 ms
    8 server.revitforum.org (216.38.52.175) 229.719 ms 229.565 ms 229.464 ms
    14
    Noticeably Better - Yay
    21.43%
    3
    A Little Better
    21.43%
    3
    No Noticeable difference
    14.29%
    2
    A Little Worse
    28.57%
    4
    Noticeably Worse - Damm
    14.29%
    2
    Ian Kidston
    http://allextensions.com.au
    Hold it for a second.... could still be 20 hours before the DNS have resolved everywhere... So if you vote in the above poll, within the next 20 hours, please ping revitforum.org and make sure that you´re getting in contact with the new server: IP = 216.38.52.175
    :beer:
      pinged. hitting the new server at an average of 78ms, from Los Angeles, CA
      Scott D Davis
      Sr. AEC Technical Specialist
      Autodesk, Inc.
      http://bit.ly/aboutsdd
        Around 100ms, Holland area.
        Edit/add-on: just noticed I still can't use the file upload manager. Well, I can, but after a few seconds trying to upload an image that circling icon stalls, to leave me behind with no new upload. Tried in IE, FF and Chrome. By the way, looks like RFO loads fastest in Chrome.
        ikinks
        Senior Member
        Arjan Ikink, BIM-engineer at PHB Deventer
        LinkedIn
          66ms average in Dallas. Hitting the new server.
          Dan
            I'm at home looking at this from ForunRunner and it's much faster now
            Rick Moore, AIA
            Barnes Gromatzky Kosarek Architects
              Ping has started ...
              PING revitforum.org (216.38.52.175): 56 data bytes
              64 bytes from 216.38.52.175: icmp_seq=0 ttl=51 time=86.757 ms
              64 bytes from 216.38.52.175: icmp_seq=1 ttl=51 time=87.614 ms
              64 bytes from 216.38.52.175: icmp_seq=2 ttl=51 time=85.754 ms
              64 bytes from 216.38.52.175: icmp_seq=3 ttl=51 time=86.164 ms
              64 bytes from 216.38.52.175: icmp_seq=4 ttl=51 time=85.707 ms
              64 bytes from 216.38.52.175: icmp_seq=5 ttl=51 time=85.464 ms
              64 bytes from 216.38.52.175: icmp_seq=6 ttl=51 time=87.638 ms
              64 bytes from 216.38.52.175: icmp_seq=7 ttl=51 time=85.727 ms
              64 bytes from 216.38.52.175: icmp_seq=8 ttl=51 time=85.318 ms
              64 bytes from 216.38.52.175: icmp_seq=9 ttl=51 time=87.892 ms
              --- revitforum.org ping statistics ---
              10 packets transmitted, 10 packets received, 0% packet loss
              round-trip min/avg/max/stddev = 85.318/86.404/87.892/0.939 ms
              :thumbsup:
              -Alex Cunningham
                Pinging 216.38.52.175 with 32 bytes of data:
                Reply from 216.38.52.175: bytes=32 time=62ms TTL=55
                Reply from 216.38.52.175: bytes=32 time=43ms TTL=55
                Reply from 216.38.52.175: bytes=32 time=44ms TTL=55
                Reply from 216.38.52.175: bytes=32 time=45ms TTL=55
                Reply from 216.38.52.175: bytes=32 time=61ms TTL=55
                Reply from 216.38.52.175: bytes=32 time=65ms TTL=55
                Reply from 216.38.52.175: bytes=32 time=46ms TTL=55
                Reply from 216.38.52.175: bytes=32 time=64ms TTL=55
                Reply from 216.38.52.175: bytes=32 time=47ms TTL=55
                Ping statistics for 216.38.52.175:
                Packets: Sent = 21, Received = 21, Lost = 0 (0% loss),
                Approximate round trip times in milli-seconds:
                Minimum = 43ms, Maximum = 65ms, Average = 49ms
                Juan Carlos Moreno
                Sisley Cosmetics
                  New servers, averaged about 100ms...
                  2,5 times better than last week but still noticeably slower then before...
                    We've received a bunch of optimization suggestions from the official vBulletin Support (Upgrading and tweaking mySQL, PHP, installing Xcache, etc.), after filing a optimization request. (The new host is really great, but servers are not optimized for vB, as with the last host)
                    ServInt is, as I write this, upgrading various systems, and tweaking a lot of settings, based on the optimization suggestions from vB Support! We are not expecting any downtime during this process, but should the forum "go down" for a couple of minutes, then rest assured that it's not a "break down".
