Subdirectories in Dynamo
    Hi guys,
    which node do I need to use so that Dynamo searches for the subdirectories too, instead of only the main directory?
    I know Clockwork had the Directory.Contents+ node. But I'm unavailable to find that one.
    Thanks!
    Infinite | Revit enthusiast | BIM | Virtual Reality | Architecture | My gallery
    Instead of working through the Clockwork package, you could simply work with the OOTB nodes that comes with Dynamo. :beer:
      What are you trying to do with the information?
      You can get subdirectories using Lightning, Orchid, or OOTB nodes.
      chad
        Nice, how do you get the list under it? I always use the "watch" node, which is always too small. What does OOTB mean btw?
        Edit: i found the PIN
        Infinite
          Great tip!
          I'm trying to upgrade all families to the newer version of Revit, but they are located in subcategories/subdirectories.
          I don't want to select every folder seperatly, so I needed to find each folder under a rootfolder.
          I just see you can include the subdirectories lol. Thanks Chad.
          Infinite
            Great tip!
            OOTB = Out Of The Box i.e. the default nodes that ship with Dynamo.
            Glad you got it sorted!
            chad
              Great tip!
              do you know that there is a long available .bat file that upgrades Revit families and does so in folders and that folders subfolders? Do a Google search for Upgrade_RFA.bat.
                Thanks Dave. No I was not aware of that. When I do a google search and find that bat file, I read comments like 'not working' and 'very slow'. A dynamo script works fast and effective, so I'll keep working with that. I use a bat file however, to clear all the backup files (.001 etc).
                  I haven't upgraded with Dynamo so I can't compare speed, but the BAT file does work. It is also great for doing things like pushing object styles into families.
                  chad
                    well, while the speed of the .bat process would definitely be slower than a proposed Dynamo method, my thought is: you only, in theory, do this once a year. I can run the .bat on my 1000s (19,878 actual current count) of Revit families and as I recall the process only takes about 20 to 30 minutes. That given no errors are encountered which requires a start over from the point of error.
                    Edit: PS, if you need the files, advise and I'll upload them
