Checking rooms setted parameters values in Revit by Dynamo
    Hello,
    I worked on dynamo to integrate the program requirements on spaces into Revit (using "Element.SetParamerterValueByName").
    I am trying now to check them.
    I started with the simplest requirements which are the program area and the contiguity between two spaces.
    1/ I already checked the model rooms area with the program area. Now, how can I display in Red rooms in Revit which does not satisfy this requirement?
    2/ For the contiguity requirement, the rule is to check if the space in question has a wall in common with one of the spaces of the mentioned space Sub-Type in the program (find the program Excel file attached).
    I could only get the rooms having this requirement from Revit parameters and the bounding walls of all rooms of the model. But I don’t know how I can check them!
    Can someone help me please?
