Create rooms by name and number
    Hello,
    I am a beginner in Dynamo and I have a simple question.
    I am working with Revit 2017 and dynamo 1.3.2 and using Lunch Box package to create rooms by name and number.
    But, the list of new rooms in Revit does not match the return value in dynamo! There are also as duplicated rooms as runnings.
    Have you looked at the lacing?
    chad
      With only the screenshots to look at, it seems you left the Boolean Toggle on True while testing/rewiring your script. (and thus destroying the element binding) Do you get the same result in a blank Revit file if you just let the script run once?
      Why are you not cleaning the "null" values from your name and number lists? With only 14 actual values there are now 16 Rooms created, resulting in all the None Rooms.
      Can't really tell anything else without the .dyn/.rvt (and maybe excel file?)
        Yes indeed, I forgot the Boolean Toggle on true!
        It's ok now, I've also removed the null values
        Thank you so much.
        • Get Rooms not Working
          Hi all,
          I am playing around with Dynamo and thought i would try something really simple. I have created a simple script to pick up all...
          May 25, 2016, 07:11 AM
        • Creating rooms from a list
          How would I go about creating rooms using dynamo? The built in "Room.ByLocation" node initially complained about me feeding it arrays. ...
          April 21, 2017, 12:31 AM
        • Revit OpEd: Revit 2016 - Place Rooms Automatically
          If you've seen a demo of Revit MEP and Spaces or if you have used Spaces yourself then you may already be familiar with the new Rooms version of Place...
          April 15, 2015, 05:15 PM
        • Pushing data to rooms from Excel
          I think the list.map node is what i want for the situation outlined below, i'm just having trouble getting my head wrapped around it and was looking to...
          August 19, 2017, 10:57 PM
        • Creating rooms using an excel file
          hi
          a long time revit user that have just discovered dynamo :-)
          i wonder i anyone knows of a tutorial that shows how to create...
          March 25, 2016, 10:39 AM
