Bulk Upgrade Families
    Hi fellow Reviteers:
    I've created a simple dynamo script for batch upgrading your families.....
    you will need the Rythym and clockwork packages.
    Note that this DOES NOT create a copy of your files, so you should have them copied into a new aptly named directory
    Be very careful and use at own risk.
    Comments welcome
    Alex Page
    RevitWorks Ltd
    Nice job man! The only feedback I have is, in newer versions of Rhythm the open nodes have changed, so they will need replaced, unfortunately.
    Here are the replacement nodes names/locations.
    John Pierson
    Creator of Rhythm, Monocle, Bang! and Lots of Other Okay Stuff.
    Twitter - @60secondrevit | Email - [email protected] | Blog - sixtysecondrevit.com | Work - parallaxteam.com
      Thanks for that: Hmmm - I seem to have both within my dynamo - using Rhythm 2017.9.17
      Alex Page
      RevitWorks Ltd
        Yeah, both have stayed present for a bit. I am retiring the python versions on next release.
        John Pierson
          Ok - updated version attached: Changes as follows:
          1. Newer Rhythm nodes used as suggested by John
          2. Ive added count nodes at the end, so you know how many families have been processed
          Alex Page
          RevitWorks Ltd
            The rhythm package now has a node specifically for this.
            https://dynamonodes.com/2017/11/06/b...gradefamilies/
              Niceone... I should have waited!
              Alex Page
              RevitWorks Ltd
                I tried it out. upgraded 300+ families in about 20 minutes.
                  Hi Alex
                  This is exactly the tool I am looking for. I'm a complete Dynamo newbie but a pretty competent Revit user.
                  I've downloaded the Dynamo script but there's errors around the "Application.OpenDocumentFile". Makes me summise that the Rhythm thingy fixes this issue. My problem is that I have no idea how to use the Rhythm input to write that script!
                  Tips and tricks welcome.
                  thanks
                  B
                    The most recent iteration of this is the single node under "Tools".
                    John Pierson
                    • Dynamo 2.0 stability
                      Dynamo 2.0 has not been stable for me. Often I cannot open graphs I have previously worked on (crashes entire application). What gotchas am I missing?...
                      August 28, 2018, 08:49 PM
                    • Lunchbox issues
                      Hi guys, do you know why lunchbox is being red? I have it in my Dynamo but for this script it doesnt work.. What can I replace it for?
                      June 18, 2020, 07:51 PM
                    • Compatible packages
                      I know this is still a 0.9 release, but I'm having a really hard time figuring out which version of a package I need to install to match the version of...
                      January 28, 2016, 09:47 PM
                    • Clockwork Nodes Are amamzing.....but
                      all of the sudden I do not know what is going on....
                      My clockwork nodes are returning NULL...
                      element.location is the first...
                      January 18, 2017, 05:08 AM
                    • Dynamo for MEP
                      Hello!
                      I'm a mechanical designer just starting to try and use Dynamo with my projects if possible. I am running into issues though.
                      October 31, 2018, 04:21 PM
