Adding User Selected Revisions to User Selected Sheets
    A few months ago I included a graph that would pull the last revision and add the revision based on selecting the sheets. I've used it many times with success. I had a project that had multiple bid packages, long story short, I needed to select which revision (not necessarily the last one) was going to go to which set of sheets. I think this is an improvement over the old one giving more flexibility found here.
    Dynamo: 1.2.1.3038
    Packages needed: Spring Nodes and Archi-lab.net
    Setting the Boolean to False and running the graph will reset the selections. Switch to true and reselect the sheets, then run.
    There is also a node called "Remove Revision from Sheet". Just had to use it because I got a little revision happy :laugh:
