"disallow join" via dynamo
    Hello,
    It seems to be so simple...!
    I would like to put all my start and endpoints of my walls to "disallow Join"
    How the hell get I fixed that? It is easy to select the walls. How can I catch the properties via dynamo to change it.
    Manually it is just a right-click to a menu...
    ...how can I catch it with dynamo?
    I am glad about any advise, or a small .dyn script
    KR
    Andreas
    Hello Andreas,
    The following graph will do what you require
    They Python code is as follows:
    [Allow Joins]
    [Disallow Joins]
    Sol Amour
      Errors
      Hello,
      Thank you very much! for this straigt help!
      In spite of that, I have still some trouble:
      I rebuilt your Tree and the pyton script, but I get errors
      Script:
      import
      clr
      clr.AddReference('RevitServices')
      import RevitServices
      from RevitServices.Persistence import DocumentManager
      from RevitServices.Transactions import TransactionManager
      clr.AddReference('RevitAPI')
      from Autodesk.Revit.DB import WallUtils
      doc = DocumentManager.Instance.CurrentDBDocument
      Walls = UnwrapElement(IN[0])
      success, failure = [],[]
      for wall in walls:
      try:
      TransactionManager.Instance.EnsureInTransaction(do c)
      WallUtils.AllowWallJoinAtEnd(wall,0)
      WallUtils.AllowWallJoinAtEnd(wall,1)
      TransactionManager.Instance.TransactuinTaskDone()
      success.append(wall)
      except:
      Failure.append("Failure: Element category" +str
      (wall.Category.Name))
      OUT = (Success,failure)
        Use 'l' (The letter), not '1' (The number) in the Count
        When you are doing the code, you need to pay a lot of attention to Capitalisation and indentation.
        The error is because you have capitalised one 'Walls' and not the one in the following line:
        for wall in walls:
        If you go back and uncapitalise one - or capitalise the other - it should work. Please go over my code line by line and it should be fine!
        Sol Amour
          it worked
          Thank you! So it worked!
          in both directions
            API list
            Is there a list of all API utils
            Can I import everthing f.e. floor.utils ... door.utils...
            Is there a forum for API programming?
            Is there maybe literature?
            I did just the "Code Academy" regarding Python
            KR
            Andreas
              Not that I've found yet sorry, but you can use
              revitapidocs.com
              and search for things If you simply use the keyword 'utils' it should pop up things.
              Download the Revit SDK (Software Development Kit) and use that in conjunction with the website above.
              There is a Revit API forum, but I don't really use it (As my focus is upon Dynamo right now), so I use a lot of the Developers section of the Dynamo Forums.
              Sol Amour
                Further Q:
                Hello,
                Thank you for your scripts.
                I notice that the function only works when there is a corner. What I want is to turn off the "wall" join status using Dynamo, so that I can draw separated walls continuously following a line.
                Thanks,
                Kemp
                  Hi amoursol,
                  i have tried the scrip but i got the following warning:
                  import clr
                  walls = UnwrapElement(IN[0])
                  success,failure = [],[]
                  for wall in walls:
                  try:
                  TransactionManager.Instance.EnsureInTransaction(doc)
                  WallUtils.DisallowWallJoinAtEnd(wall,0)
                  WallUtils.DisallowWallJoinAtEnd(wall,1)
                  TransactionManager.Instance.TransactionTaskDone()
                  except:
                  failure.append("Failure: Element category" +str
                  OUT = (success,failure)
                    Hello Mjkayali,
                    Please go over my post higher up in the graph - indentation matters a lot in Python, so double check the code inside your node matches mine
                    Sol Amour
