Dynamo & Python changes?
    Previously the Dynamo installer would include a version of IronPython in the install, and I think the Dynamo web site also provided links directly to the current Python installer. But those links are no longer on the Dynamo web site, and so far as I can tell Python is not installed by Dynamo at all, I think going back to Dynamo 1.0.
    Can anyone verify, is this a change and IronPython is no longer needed at all?
    Or perhaps it's only needed in certain situations, and now has to be installed separately?
    I can't find anything at the Dynamo web site specifically saying it's no longer needed, but the fact that it seems not to be included in the installer any more seems odd.
    Gordon
    Pragmatic Praxis
    All I can help with is that I've just installed the latest (downloadable) build in our office and didn't need to fetch anything else (to let me play with some Python in code blocks).
    But then:
    a. The IronPython to which you refer might be a different breed of Serpentes than the boggo "inbuilt-Dynamo-Python"?
    b. We may have an IronPython install for some other reason from previous installs.
      So, what I have found is this.
      If you use the standalone installers from the Dynamo web site, you get IronPython 2.7.3.
      However, if you are on subscription, and maintaining your Dynamo using the post 2017.1 updates, then you don't get IronPython in the installer. For most people this might not be an issue, because Revit 2017 deployments include IronPython 2.7.3 along with (outdated on ship!!!) Dynamo 0.9.1. So, you are only screwed if you removed that old **** from your deployment. I swear Autodesk is about the same with Dynamo installs as Trump is with cabinet picks. 50 different ways to **** it up, and not a right answer in sight.
      Pragmatic Praxis
      • Dynamo says "Update Available" but nothing happens + Dynamo versions?
        When I click on Manage > Dynamo, version 1.2.1.3083 opens (it says Dynamo Core and Dynamo Revit are 1.2.1.3083). Shortly after it opens, the little...
        August 1, 2017, 04:10 PM
      • Dynamo Install Order ?
        I'm trying to cleanup my deployments and have been having some minor issues with Dynamo, especially since there are several versions to deal with at the...
        September 5, 2019, 04:00 PM
      • Qualitymanagement with Dynamo and CO
        Hello Dynos,
        How about quality Management with Dynamo and Python?
        What is your expierence? What can i prove...
        October 20, 2018, 01:19 PM
      • Dynamo
        hi I'm completely new to hear a word Dynamo.
        Can anybody explain what is dynamo. What can be done using Dynamo?
        Why we need to use Dynamo?...
        June 2, 2017, 07:19 AM
      • Orchid for dynamo
        I am trying to install Orchid package for dynamo, another colleague installed it no problem and I followed the same procedure he did and yet it will not...
        August 25, 2021, 09:17 AM
