key-values
    key-values
    any easy way to process 2 lists into 1 key-values list just like dictionary in C#?
    list 1 is like {a, b, a, c, b, a}
    list 2 is like {1, 2, 3, 4, 5, 6}
    result list is like {{a, 1, 3, 6}, {b, 2, 5}, {c,4}}
    edit: or result list like {{a, b, c}, {1, 3, 6}, {2, 5}, {4}}
    Hello Ning,
    There are a couple of Dictionary nodes created. Showcased as below:
    Sol Amour
      thanks Sol.
      see attached image for the desired results, perhaps OOTB List.Map can solve this issue, isn't it? i'm not quite familiar w/ that OOTB node, maybe Python Script is the only way out?
        managed to get one of the desired results, still try to figure out another one, using OOTB nodes only
          managed to get another desired result using python script, must be a way to use OOTB node only like List.Map, anyone?
            If you can use Python, feel free too! I would simply do my method with an 'Add Item to Front' as you have done.
            Sol Amour
              last try:
              seems the very simple question, just "merge" 2 list using OOTB nodes only, code block node is OK, but cannot use python script node, anyone?
                just figured out thanks to Sol and Marcello.
                  This way is faster!
                  What it's doing is as follows: List.AddItemToFront is taking the item at Level 1 (3x objects), and adding those objects in to the listat Level. So the 3x objects from the unique keys slot in at the correct tier structure.
                  Sol Amour
                    list level option is absolutely beautiful! no need to figure out List.Map anymore for sure, again, Less Is More!
