Clockwork Nodes Are amamzing.....but
    all of the sudden I do not know what is going on....
    My clockwork nodes are returning NULL...
    element.location is the first one that was broken.. but there are others too.
    I tried uninstalling all of my packages, then reinstalling starting with clockwork first... the test run... no bueno.
    ahhhhhh
    Anyone else out there see these same problems?
    Regards,
    Emmett Cruey
    ConnectedBIM.Design
    925-695-6000
    What version of Clockwork are you using and what version of Dynamo? Andreas' has multiple iterations dependent on the Dynamo version out there.
    Sol Amour
      Yeah I had this problem too...
      I believe it is because the clockwork packages make a lot of use of the 'Return List or Single Item' node, inside the other nodes. This node was failing in lots of nodes after I upgraded to Dynamo 1.2 and just un-re-installing the clockwork package didnt fix the problem, because that node was not being overwritten and/or couldnt be found.
      I fixed it with a total reinstall from nothing, but some packages still havent been updated so just go for the ones that actually say Dynamo 1.2+
      While its great that Dynamo is being developed so quickly, the unreliability this causes is a real problem if you want to distribute your solutions within a company. So now I just insist everyone has the stable 1.2 version that comes with revit and doesnt update. I cut and paste the code out of the custom code blocks into 'python by string' nodes wherever possible too (Also a good way to fix old nodes), so people dont actually need the packages.
        Originally posted by josephpeel View Post
        ...it is because the clockwork packages make a lot of use of the 'Return List or Single Item' node, inside the other nodes. This node was failing in lots of nodes ...
        +1
        I fixed it for pre-1.2 by looking up the 'Return List or Single Item' node and replaced it with my own version. Basically, if you use a list.Create and then List.Flatten by 1 tier. Does exactly the same thing.
        Or do what Andreas did in 1.2
        There must be a better way...
        Ekko Nap
          total re-install of Revit from nothing?
          Regards,
          Emmett Cruey
          ConnectedBIM.Design
          925-695-6000
            total re-install of revit? or just Dynamo....
            Regards,
            Emmett Cruey
            ConnectedBIM.Design
            925-695-6000
              Just reinstall clockwork!
              Ekko Nap
                Yeah..tried that twice already... did not work.
                Regards,
                Emmett Cruey
                ConnectedBIM.Design
                925-695-6000
                  Strange. Anyway, you can also track down where the 'turn into list' Node is stored and replace the python bit with the examples above. I found one installed here, for example. C:\Users\ena\AppData\Roaming\Dynamo\Dynamo Revit\1.2\packages\Clockwork for Dynamo 0.9.x\dyf
                  Edit: suddenly confused which one was malfunctioning again, 'Return List or Single Item' or 'turn into list', or if the one was nested into the other. I am sure I only replaced 'turn into list' with my own version though.
                  Ekko Nap
                  • Where is the Problem? in the script
                    Hello! Dynos,
                    I have a beautiful script, and it runs on my Dynamo! on my Laptop! But when I run the script, on a other Laptop it is...
                    January 22, 2018, 08:13 AM
                  • Subdirectories in Dynamo
                    Hi guys,
                    which node do I need to use so that Dynamo searches for the subdirectories too, instead of only the main directory?
                    I know...
                    February 3, 2020, 07:41 AM
                  • Spring Package Interference Check node does not work
                    hey all ,
                    the node in the spring package does not work in revit 2020
                    does anyone has any idea why it is not working?
                    and...
                    June 13, 2019, 06:58 AM
                  • If Else Statement
                    Dear Dynamo Experts,
                    I have a simple question on if statement. How to implement something like if true do A things, else do B things in dynamo?...
                    May 25, 2017, 07:19 AM
                  • Equivalent node
                    Hey guys,
                    I am having an issue, I am following a course and it requires the Documents.Builtincategories from clockwork. I can,t find the node AT...
                    October 22, 2020, 01:19 PM
