Changing Modeling Method with Dynamo
    Hello all,
    Thank you all for sharing your knowledge and helping people with your expertise.
    In my current model, the slab/floors are cutting the beams, hence the concrete volume of the beam is reduced.
    Kindly see the image which I uploaded.
    Question:
    Is it possible to change from "Current Situation" to "Desired Situation" for all the beams and slabs in the entire project at one go, using Dynamo.
    Hint; Revit command to be used: "Join Geometry" and "Switch Join Order"
    Thank you.
    Hello ZoLaDo,
    Short answer: Yes.
    Long answer: It will require a little work.
    This functionality, to my knowledge, doesn't reside in the OOTB Dynamo nodes at present.
    You can have a look at the following post on the DynamoBIM forums if you want to try re-create the Python node.
    https://forum.dynamobim.com/t/automa...n-revit/1836/9
    Post back here when you've had a try
    Sol Amour
    • Qualitymanagement with Dynamo and CO
      Hello Dynos,
      How about quality Management with Dynamo and Python?
      What is your expierence? What can i prove...
      October 20, 2018, 01:19 PM
    • Basics in dynamo
      Hello dynamoits,
      I want just make a square out of cycles! It doesn´t work!
      Where is the mistake?
      BR
      Andreas...
      June 22, 2017, 10:05 AM
    • Subdirectories in Dynamo
      Hi guys,
      which node do I need to use so that Dynamo searches for the subdirectories too, instead of only the main directory?
      I know...
      February 3, 2020, 07:41 AM
    • Compatible packages
      I know this is still a 0.9 release, but I'm having a really hard time figuring out which version of a package I need to install to match the version of...
      January 28, 2016, 09:47 PM
    • Families occasionally deleted by Dynamo
      In an effort to learn Dynamo I'm creating a graph which simply places cube shaped families on the faces of existing cube shaped families....
      February 4, 2016, 07:39 AM
