IFC export the whole model instead of current view
    "Disables switching to 3D view if current view only is set when exporting to IFC"
    This is part of the enhancements of the update 2 of Revit 2012
    Even though I installed that update I still have that exact same bug :
    We usually filter our exports by hiding worksets in the visibility/graphic.
    Exporting IFC with current view only activated doesn't work as it exports the whole model
    Navisworks exports export properly.
    Has anyone experienced it as well ? I thought first that the problem was not coming from Autodesk as they said they just fixed it. After trying it on different computers with different files, I might say I am not so confident anymore that they actually did fix that issue.
    same here for me, whether the workset is not visible or closed; IFC file contains everything.
    Julien
    P. DAC
      We did contact Autodesk regarding that issue. The answer we got from them wasn't the one expected :
      The problem might be solved for the next release
      No more filtered IFC exports before 2014 !
        2013 release I guess. May 2012.....a few months to go.
        Julien
        P. DAC
          It was actually even quicker ! Thanks Autodesk !
          To get "Current View only" exports working properly :
          Go to https://sourceforge.net/projects/ifcexporter/files/ and download the latest IFC Exporter there
