Design Review Mobile App File Types
    Does the Autodesk Design Review Mobile App (for iPad) accpet ".DWFx" filetypes to be viewed or is the only accepted file type ".DWF"?
    .dwfx works.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      Thanks Cliff for the expedient response. I'm working with only 1gb storage on the cloud and have a lot of sheets that need to be uploaded, so I guess my real question would be "would using .dwf file type be better for me since the file sizes would be smaller?"
        I have never tested the file size difference, so i can't comment. Try taking a complex view from Revit and export it out as both types and see if there is a big difference.
        FWIW, If you are an Adesk subscription member you should have 3GB of storage on the Adsk Cloud.
        Edit: I just did a quick test from a fairly simple Revit model, and exported a 3D dwf and dwfx file.
        The dwf was 4 kb smaller than the dwfx. Not a huge difference; but on huge Revit projects I suppose
        it could add up?
        cliff collins
        BIM there, done that
        Cliff B. Collins
