DWG Check for Revit origin
    For those you ocassionally work with with mix of DWG / RVT data. Using the filter option in AutoCAD you can see if DWG content was created in (or used in) Revit. This way one can filter hatches (converted fill patterns) and Nested blocks (converted Families) more effectively. I made this little demo.
    https://youtu.be/xs1L8pY87ZA
