I've been working on creating a workflow for generating a navisworks composit model and have been going though the navisworks settings for element parameters and properties. When exporting to nwc, I get a progress dialog that says 100% but in the status window shows the export is still work on generating graphics for multiple levels from different view categories increasing the completion time to export another 200%. I read a post that points to grids and levels / copy monitor being the culprit. This is not really an option unless I change the work flow for creating and managing grids and levels anyone have a solution?
NWCOUT - Performance
Do column grids auto-export with the NWC Export Utility? I went to the Navisworks Settings on the export prompt and can't find anything that allows you...
Channel: Coordination Tools
January 18, 2014, 02:06 PM -
Hey all,
I received a POS model from another firm that I am having to do major clean up on in order for the G.C. to do his clash detection. ...-
Channel: MEP - General
November 7, 2019, 05:22 PM -
All,
I have a model with Structure, MEP and Second Arch Revit model linked.
Each model has their own grids and levels.
therefore,...October 17, 2012, 02:01 PM -
Just getting into using Navis for Clash detection and I'm hearing mixed preferences.
Is it better to set up separate 3D Views/View Templates in...-
May 30, 2013, 08:57 PM -
I've inherited some MEP models. I'm trying to set up a plan view that has a range of several levels, i.e. the associated level is Roof 1 and I want the...December 8, 2016, 11:56 AM
Monumetric Footer In-screen
