Aligning views between Navisworks & Revit
    This is embarrassing. I know, despite Navisworks having "Presenter" and despite it being more a "viewer" application than a "modelling" one, that it is not a program I should be caring (much) about appearances - I get that - but, because I am tasked with an exercise to show how our work transitions through different mediums & packages, it would be nice to...
    (Q: How to ) Setup a view in Navisworks, identical (or thereabouts) to one from Revit.
    I have the view imported, via the .nwc, but it looks completely different - much more "widescreen" than the Revit view (which was easy to align to the reference photo using transparency overrides and stacked views on a sheet) - and my adjustments (thus far) with the FOV (in Navisworks) have so far only screwed the view more.
    I don't plan on spending much more time on this, but thought I'd ask in case someone's found a trick.
    Could you send 2 pics that would show what you mean? Thanks
      Snowy, look for the thread of Munk about setting POV in Revit. This may help to set your POV in Navis.
      Julien
      P. DAC
