Results 1 to 3 of 3
Thread: Problem lifting out instance param and setting into shared param
    March 28, 2019
    1
    02:34 PM
    Question Problem lifting out instance param and setting into shared param
    Greetings
    First of all, I love this community!
    I have already set up a desired shared parameter named “Volym”. My issue lies in understanding how to lift out the object instance specific “Volume” and type it into my shared “Volym”. Please see attached image.
    I just can't get it to work. Somehow I don't reach these values with my ordinary super simple get-->set nodes.
    Any and all guidance is vastly appreciated! Cheers!
    Problem lifting out instance param and setting into shared param-dynamo-2.jpg
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    224
    10:34 AM
    I don't know if you working in the family editor environment, but this is what I've been using to convert our families to a new shared parameter standard. As you can see all the nodes are orchid so if this doesn't work I would look in that package.
    Problem lifting out instance param and setting into shared param-transfer-parameter-values.png
  3.    #3
    Junior Member kraftwerk's Avatar
    November 1, 2012
    St. Louis, MO
    42
    09:34 AM
    It is fairly simple to call the Parameter name as shown in this example below where we can take the Volume in Cubic Feet from the element and change it to a string object. Note the need to convert from an Integer to a String.
  1. Height Param: Ref Level v Ref Plane?
    By snodaisy in forum Architecture - Family Creation
    Last Post: September 22nd, 2015, 06:25 PM
  2. Detail Item Family Label Param
    By ecraider in forum Architecture and General Revit Questions
    Last Post: March 5th, 2015, 02:04 AM
  3. Reporting shared param
    By assem in forum Architecture and General Revit Questions
    Last Post: October 13th, 2014, 09:58 AM
  4. Linking Profile Param to family
    By lallanji in forum Architecture - Family Creation
    Last Post: July 13th, 2014, 06:09 PM
  5. Replies: 8
    Last Post: May 9th, 2014, 02:30 PM
