Results 1 to 2 of 2
Like Tree3Likes
  • 3 Post By elton williams
Thread: Revision exists on sheet
    Gold Coast
    2,609
    06:55 AM
    Hi All,
    Was asked today to pdf some sheets that have a specific revision on them, but hadn't yet been issued (or printed).
    My first thought was, a Revit schedule (sheet list) can only display/filter by "Current Revision..." data. But what if later revisions have been added to any of those sheets? And, without opening 200 sheets 1 at a time and scanning every revision schedule, how would I find the sheets with that specific revision, regardless of when it was added to the sheet?
    10 minutes later I have a working Dynamo script which does exactly that and also saves a View/Sheet Set for easier printing so I thought I'd share it here.
    Made in Dynamo 2.0.2 and uses archilab and Orchid packages.
    edit- you could probably quite easily extend this to do the plotting/printing for you as well.
    Attached Files Attached Files
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,124
    04:55 PM
    Nice one! I have an similar version of that graph that selects by date, rather than the actual revision, and it uses python... I think yours is better Attached .dyn is in Dynamo 2.0
    Attached Thumbnails Attached Thumbnails Revision exists on sheet-revisionbydate-python.png   Revision exists on sheet-revisionbydate.png
  1. Replies: 4
    Last Post: May 3rd, 2018, 11:02 PM
  2. Sheet Revison and revision clouds in the sheet
    By quocviet0327 in forum Tutorials, Tips & Tricks
    Last Post: July 28th, 2015, 03:04 AM
  3. Revision Tag in Sheet View
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: July 11th, 2013, 08:25 PM
  4. Latest revision per sheet only!
    By fergie008 in forum MEP - General
    Last Post: September 2nd, 2012, 08:21 PM
