Results 1 to 8 of 8
Thread: How to update??? Help :(
    April 3, 2014
    44
    01:04 AM
    I seem to not be able to use packages properly. When I try to download this information shows up:
    The following packages use a newer version of Dynamo than you are currently using
    I tried to download newest version from dynamobim.org but I get a folder of files with which I don't know what do do with. Theres InstallUpdate.exe file, but it won't run...
    Help!
    Attached Thumbnails Attached Thumbnails How to update??? Help :(-przechwytywanie.jpg   How to update??? Help :(-przechwytywanie.jpg
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,453
    07:04 PM
    What version of Dynamo are you using? For example, if the package was built for Dynamo 2.0, and you are using 1.3, then you need to specifically choose an older version of the package (if it exists) and install that.
    April 3, 2014
    44
    01:04 AM
    I'm not sure... how can I check that?
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,453
    07:04 PM
    In Dynamo (and most programs) go to "Help" and choose "About" from the dropdown list.
    To install an older version of a package you select the package and choose an older version from that list, rather than using the download button to the left of the package. You may have to do some research to find which package you need to use with your version of Revit.
    Of course you could update Dynamo, but that depends on your Revit version, who and what you are working with, and if you are using existing scripts.
    April 3, 2014
    44
    01:04 AM
    Ah thank you
    Dynamo seems to think it's up-tp-date:
    we use Revit 2019 nad we have subscription so we should be able to have the newest versions of everything.
    Should I keep trying to get newer version od Dynamo?
    Gold Coast
    2,631
    11:04 AM
    Quote Originally Posted by constrainmenot View Post
    Ah thank you
    I'm guessing that's the most up to date version of 1.3.
    You can download the latest 2.0 from the dynamo forum.
    April 3, 2014
    44
    01:04 AM
    Do you mean https://dynamobim.org/download/? Because that kind of circles back to the original question
    April 3, 2014
    44
    01:04 AM
    Just realized I was downloading sandbox version instead of Revit Dynamo <facepalm>... Sorry for trouble everyone and thanks for help!
  1. Replies: 0
    Last Post: February 28th, 2018, 11:15 PM
  2. What Revit Wants: Autodesk 360 update - Live Update 1
    By luke.johnson in forum Blog Feeds
    Last Post: May 14th, 2013, 11:45 PM
  3. Revit OpEd: Elevation Update Update
    Last Post: January 5th, 2012, 05:46 AM
  4. Revit OpEd: Elevation Update Update Updated
    Last Post: October 18th, 2011, 06:45 AM
  5. Revit OpEd: Elevation Update Update
    Last Post: October 13th, 2011, 03:45 PM
