Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree2Likes
Thread: List.ContainsItem
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    03:41 PM
    List.ContainsItem
    Dynamo 1.3 had a node named List.ContainsItem
    It could compare two lists and tell you which items were in both lists.
    2.0 does not have this node. 2.0 has one named List.Contains, but it does not work the same.
    1.3 List.ContainsItem gave me a list that I could then use in a Boolean Mask.
    When I run the same graph in 2.0, the List.Contains only returns one True or False value.
    I've tried using Levels, but a.) Both lists only have one Level and b.) it doesn't make any difference in the results.
    Is there a 2.0 equivalent to List.ContainsItem ?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    04:41 PM
    There is a List.Contains node OOTB in 2.0.2
    January 10, 2011
    St Paul, MN
    2,980
    03:41 PM
    Yes, indeed, it does.
    I should have mentioned, I am on 2.0.2
    January 10, 2011
    St Paul, MN
    2,980
    03:41 PM
    Ahah!
    Seems like an unusual method, but I had to explicitly tell it to use Level 1 to get it to return the same thing that List.ContainsItem did in 1.3
    Attachment 36257
    Gold Coast
    2,617
    06:41 AM
    Ahah!
    Attachment 36257
    "Invalid attachment specified"
    January 10, 2011
    St Paul, MN
    2,980
    03:41 PM
    Weird, it opened for me. It's just a screen shot
    Been that kind of a day
    Gold Coast
    2,617
    06:41 AM
    that was last night on my ipad, this is today on my work PC
    I can see your new screenshot now though.
    It was awhile back, but there were are a few differences I stumbled over when I moved to 2.0 and I had seen the list level behavior you describe. The AUTO lacing function is very handy but you still need to change it a lot, just not as much as before.
    In my 2.0 scripts at least, I have found that Materials need to be collected from Element Types>All Elements of Type, where previously in 1.3 they were collected by Categories>All Elements of Category.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    319
    10:41 PM
    Just an alternative:
    I really like using these 2 Nodes for figuring out the common items/missing items between 2 lists:
    @Elton: So funny, I just 5 minutes ago made this quick purge in Dynamo 2.0.2
    josephpeel likes this.
    August 9, 2011
    Louisville, KY
    6,140
    04:41 PM
    Quote Originally Posted by Bjorn_K View Post
    Why does the input order matter on the SetDifference node? The difference between the lists is the same either way...
    April 8, 2011
    319
    10:41 PM
    The Difference in that Node is defined as the items in list 1 that are not present in list 2.
    cellophane likes this.
  1. List Clean on Another List
    By ScubaMan in forum Dynamo BIM
    Last Post: October 2nd, 2017, 09:19 PM
  2. List of Views from List of View Names?
    By ryntau in forum Dynamo BIM
    Last Post: September 18th, 2017, 02:16 AM
  3. Detail item list not show full list (2017)
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: November 18th, 2016, 02:41 PM
  4. RTC: Hot List!
    By RTC in forum Blog Feeds
    Last Post: September 20th, 2016, 05:15 AM
  5. Replies: 0
    Last Post: March 12th, 2015, 06:16 AM
