Results 1 to 3 of 3
Thread: Dynamo Player cofiguration
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,965
    05:54 AM
    Anybody know where the Recent Files are stored for the Dynamo Player?
    When I install Dynamo/Player, I'd like to push out a config so people are already pointing at the folder we have our graphs saved.
    Dynamo itself has a config file:
    C:\Users\username\AppData\Roaming\Dynamo\Dynamo Revit\2.0\DynamoSettings.xml
    But I don't see anything like that for the player.
    Is it a registry setting, maybe?
    Here's to consistency!
    10,124
    05:54 AM
    It's neither.
    You have to push the entire clowny Playerinstance1 folder, or whatever it's called, I'm appdata. And no... You can't find a folder in there that you can customize.
    Thanks development team.
    January 10, 2011
    St Paul, MN
    2,965
    05:54 AM
    Oh, THAT'S a fun folder.
    None of the files under Playerinstance 1 (which is under my dynamoplayer-2 folder) have extensions.
    Guess it's going to be a manual, per-user, post-installation configuration.
  1. Revit 2019.1 Dynamo Player Not Opening
    By ecraider in forum Dynamo BIM
    Last Post: September 29th, 2018, 03:59 PM
  2. Replies: 0
    Last Post: August 26th, 2018, 08:15 PM
  3. Dynamo Player
    By snowyweston in forum Dynamo BIM
    Last Post: April 3rd, 2018, 02:19 PM
  4. Alphabetize the Scripts in the Player?
    By safoulkes in forum Dynamo BIM
    Last Post: January 29th, 2018, 06:34 PM
  5. Replies: 0
    Last Post: February 28th, 2012, 11:15 PM
