Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Like Tree4Likes
Thread: Can Dynamo write directly to a parameter in a nested Revit family?
  1. #11
    10,280
    09:23 AM
    I see what's going on. It's going to sound totally backwards:
    Take the parameters OUT of the family.
    Add them to the PROJECT as PROJECT PARAMETERS (shared) that apply to the correct category. Then Dynamo will work.
  2. #12
    April 10, 2014
    73
    10:23 AM
    Aaron, I've been investigating what you've said. In the family, I have formulas that refer to the to-be-deleted parameters. If I delete the parameters, the formulas disappear, Some re-typing, I suppose. But then how do I enter parameters into the family? The family can't see the project parameters. It can see the same parameters from the shared parameters. Is this a matter of entering them into the Project Parameters then restarting Revit?
  3. #13
    10,280
    09:23 AM
    Quote Originally Posted by Rex Wave View Post
    No. If you need formulas based on those parameters, then I don't know that Dynamo will succeed.
    SetParameterByName works on shared nested families, without going through the parent, but I've only seen it work with the SP's (instance) added as project parameters. The type parameters should work fine either way, I would think.
  4. #14
    April 10, 2014
    73
    10:23 AM
    I have added some of the parameters to the project parameters. They are shared and instance. I restarted Revit (in the past, this has worked to fix some things). I would expect the nodes that can write the data to succeed and the others to fail. No love - they all fail to write. You say that this node works on shared nested families without going through the parent. Is there an example available that I can emulate? Very frustrating. Everything works except this last step...
  5. #15
    10,280
    09:23 AM
    I do it every day, for writing field layout data to families. But the parameters CANT be in the families.
    So for what you want to do, my.sigfedrion won't be the solution.
    When I wrote that, i didnt know you had formulas dependant on it.
  6. #16
    April 10, 2014
    73
    10:23 AM
    Thanks for digging into it. I have partly succeeded at writing to the parent families. The problem is how to parse the data coming into Dynamo to sort itself to the correct families. Dynamo seems to hate multiple family references in the same graph. I get a picture of a program with a bandage on its head complaining that the virtual machine has blown up.
  7. #17
    10,280
    09:23 AM
    Did you post the graph and I missed it?
  8. #18
    April 10, 2014
    73
    10:23 AM
    MacKinnon Interface from Excel to Revit via Dynamo assume DB access.dyn
    Graph is attached. I have previously posted snips of its behaviour in this thread. It populates the parameter names and provides data. Only the last step fails.
  9. #19
    April 10, 2014
    73
    10:23 AM
    Quote Originally Posted by jmk View Post
    ... Clockwork has a good node to get the nested subcomponents....
    The problem is writing to Revit, not getting. I wrote a separate graph to get info out of Revit,
    which works well. Excel does the calcs, which I have gotten into Dynamo. The lists look good. Clockwork looks interesting, but I can't determine from the list of nodes what might help me..
  10. #20
    10,280
    09:23 AM
    I honestly don't think you are going to get the instances to work, WITH formulas, in a nested family, through Dynamo.
    Because the INSTANCE is married to the parent family.
    The way GTP (now APL) handles this is for every nested family parameter it needs to access, it makes (or used to make) a redundant parameter in the host family. Which is.... Yuck.
    That's why I was so glad to discover the project parameters work. But the only way to make the project parameters work for you is to embed the formulas in go Dynamo instead of in the family.
    You keep trying to solve a node or graph problem, but there isn't one. REVIT won't let you do what you're after. Mark and Comments are the only instance parameters that get unlocked in a shared nested family, from the host family. Won't matter WHAT node you use.
  1. Depth of Nested Family for Family Type Parameter
    By GMcDowellJr in forum Architecture and General Revit Questions
    Last Post: November 18th, 2016, 04:18 PM
  2. Replies: 0
    Last Post: March 1st, 2016, 09:45 PM
  3. Nested Family with YES/NO Parameter
    By Andres Franco in forum Architecture and General Revit Questions
    Last Post: November 12th, 2015, 08:07 AM
  4. Replies: 0
    Last Post: August 31st, 2015, 02:15 AM
  5. Nested Family Parameter not working in Parent Family
    By makaz22 in forum Architecture - Family Creation
    Last Post: April 14th, 2014, 06:13 PM
