Results 1 to 6 of 6
Thread: create area-bounding-line from dwg-line, but how
    November 18, 2013
    Germany
    103
    04:17 PM
    Exclamation create area-bounding-line from dwg-line, but how
    Hello Dynos,
    I don t find a solution:
    I want just convert a Layer from a linked dwg to an area-seperation-line.
    I am able to collect the lines(.dwg)!
    I can put them on a plane!
    but i can`t generate area-bounding-lines
    I choose the correct View and Layer
    Can anybody help me?
    KR
    Andreas
    Attached Thumbnails Attached Thumbnails create area-bounding-line from dwg-line, but how-2019-02-27_15h53_27.png
    Attached Files Attached Files
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    313
    06:17 PM
    An Area Seperation line exists in a view only. So the plane that is asked in the AreaSeperator.FromCurve Node is not the Plane from the Level but the Plane from your Area Plan View.
    I ran into this trying to place detail components in Sales Brochure Drawings, Needed the Plane from that particular view, ended up solving it with the View.Plane node from Clockwork.You will probably also need the Curve.PullOntoPlane Node to get the curve from the CAD line pulled onto the placement plane.
    So, don't start the bottom half off your script by selecting a level, start by selecting your Area Plan View, into View.Plane into PullOntoPlane and feed that into the AreaBoundary Node (That also needs to be connected to the Area Plan View, something that is missing in your screenshot)
    November 18, 2013
    Germany
    103
    04:17 PM
    it works with a small error
    Attached Thumbnails Attached Thumbnails create area-bounding-line from dwg-line, but how-2019-03-01_09h27_40.png   create area-bounding-line from dwg-line, but how-2019-03-01_09h33_39.png
    Gold Coast
    2,602
    02:17 AM
    I don't know how that warning translates into English but I'm guessing it's line is too short, which unfortunately is normal with tiny lines in revit.
    November 18, 2013
    Germany
    103
    04:17 PM
    Exclamation AreaSeparator
    It works! it calls endposioning is not correct. I will continue, thats a big step forward!
    Next challange is to make this with 60 floors. I would like to repeat that for each floor and not using active view.
    KR
    Andreas
    Gold Coast
    2,602
    02:17 AM
    Quote Originally Posted by andreasdraxl View Post
    KR
    Andreas
    so you can feed it a list of the specified views
  1. Replies: 3
    Last Post: March 1st, 2018, 10:23 AM
  2. How do you create custom Line Types
    By Tiffanydh8 in forum Architecture and General Revit Questions
    Last Post: October 18th, 2017, 02:35 PM
  3. Area Boundary Line .ini fix
    By mark b in forum Architecture and General Revit Questions
    Last Post: June 9th, 2017, 01:52 PM
  4. Export Line Styles, Line Weights, and Line Patterns
    By MrBIMtastic in forum Third party Add-Ins, API and R&D
    Last Post: May 23rd, 2013, 05:36 AM
  5. Masked area not hiding line end in vector printing.
    By RMRamirez in forum Architecture and General Revit Questions
    Last Post: November 21st, 2012, 01:52 PM
Tags for this Thread
