Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By cellophane
Thread: Extract Family Locations
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    07:23 AM
    Is there a way through Dynamo to extract family save-as locations? What I'm looking for is an output similar to what is obtained using CTC Family Loader that reports the save-as path for all loaded families, similar to the attached image. I've found a number of nodes to pull document (project) location information but nothing that I can find that will get the family information. End goal for this is to dump the information into Excel for processing.
    Attached Thumbnails Attached Thumbnails Extract Family Locations-familylocation-all.png
    JWR likes this.
    Junior Member kraftwerk's Avatar
    November 1, 2012
    St. Louis, MO
    42
    06:23 AM
    Are you wanting to batch run this on a list of families in a project or template? If not, then wouldn't the CTCFL be just as fast?
    August 9, 2011
    Louisville, KY
    6,140
    07:23 AM
    I'm trying to add it into a series of model health graphs and hoping to click once (or twice) and have everything output, rather than running the dynamo, then running the CTC tool, then running some other tool, then trying to combine data from several excel files, and so-on.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    319
    01:23 PM
    https://forum.dynamobim.com/t/get-fi...-families/4014
    The Python snippet here seems to do what you're after?
    November 1, 2012
    St. Louis, MO
    42
    06:23 AM
    Sorry for not replying. The previous post seems to be what you are after. For batch processing project files, there is a way with DynamoAutomation package. I've also had my eye on this utility from BVN: https://github.com/bvn-architecture/RevitBatchProcessor
    August 9, 2011
    Louisville, KY
    6,140
    07:23 AM
    Nice one! (Bjorn & kraftwerk) I'll take a look and see what I can figure out.
    August 9, 2011
    Louisville, KY
    6,140
    07:23 AM
    Is there a good way to filter system families out of my selection other than collecting categories?
    edit: also the stupid family constraint warning...
    edit2: python script works, other than the previously mentioned system family issue and the stupid family constraint thing...
    Attached Thumbnails Attached Thumbnails Extract Family Locations-getfamilypythonerror.png   Extract Family Locations-getfamilyconstraints.png
    Gold Coast
    2,617
    09:23 PM
    I think if you select Family Symbol from an element types node it will only return loaded families. Can't be sure atm because I'm eating lunch *nom nom nom*
    August 9, 2011
    Louisville, KY
    6,140
    07:23 AM
    I couldn't figure out the Family Symbol part but I did manage to get something working. Although I'm wondering if the issue had to do with a family name more than System / Loaded families. More testing!
    edit: the last List.GetItemAtIndex node was there just to cut the list down a bit for testing so I wasn't waiting for it to process 500 families It can be removed long term.
    Attached Thumbnails Attached Thumbnails Extract Family Locations-familylocation.png
    November 1, 2012
    St. Louis, MO
    42
    06:23 AM
    You might want something like in the attached image. This is getting just the instances placed in the document and reporting back the family file path location. There is also a node that would work more with what you have that is FamilyType.Family which will return the Family of the given Family Type, which is what you are gathering in the very first node.
    While it is good that you are documenting as you go, a word of warning that the more custom nodes that you add to the graph, the more likely it is that the graph becomes corrupt (as nodes are upgraded, no longer work with the Dynamo application, etc.).
    Attached Thumbnails Attached Thumbnails Extract Family Locations-2019-03-01_12-57-44.png
  1. Titleblock Locations
    By cellophane in forum Dynamo BIM
    Last Post: June 26th, 2018, 01:54 PM
  2. Replies: 3
    Last Post: September 1st, 2016, 09:59 PM
  3. Family Locations
    By ESD ltd in forum Architecture and General Revit Questions
    Last Post: November 14th, 2014, 04:26 PM
  4. Locations of Equipment
    By domsib in forum MEP - General
    Last Post: April 12th, 2013, 03:27 PM
  5. Replies: 0
    Last Post: November 28th, 2012, 11:49 AM
