Results 1 to 4 of 4
Thread: Placing Views on Sheet From Excel List
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,164
    03:59 AM
    I'm missing something simple here I think...
    I have a spreadsheet with a bunch of drafting views names & sheet numbers (typical campus details) and I need to create the views in each building file (easy enough) and would like to then place the views on the sheets they go on to make placing callouts easier.
    I have filtered the document view list by the excel list and have the views grouped by key (sheet number), but when I go to put them on sheets the node places the first view in the list and then returns a bunch of nulls. I've tried with both of the SteamNodes and the Viewport.Create Rhythm node. The Rhythm node is the only one I've had any success with - I've tried Auto, Longest, and Cross Product lacing. I'm sure it is something dumb that I'm overlooking but I figure all morning is too long to stay stumped on something like this. Long story short - how can I get the views onto the sheets they belong on (i.e. where did I screw up)?
    Attached Thumbnails Attached Thumbnails Placing Views on Sheet From Excel List-placedraftingviewsonsheets.png
    Attached Files Attached Files
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    3,010
    02:59 AM
    I struggled with the same thing for a while.
    Dug into my Dynamo graph & tried all kinds of tricks.
    Then I realized that Revit won't let you put an empty View on a Sheet
    So if Revit won't let you do it, neither will Dynamo.
    Just make sure there's something - anything - visible in the View.
    Draw a line or something & it should work.
    August 9, 2011
    Louisville, KY
    6,164
    03:59 AM
    In the other graph that adds the views I have it adding a detail component to every view using FamilyInstance.ByViewAndPoint. Or it did at one point... I just looked and it isn't currently placing it everywhere
    August 9, 2011
    Louisville, KY
    6,164
    03:59 AM
    And I'm an idiot... At one point I was placing a DC in all of the views and apparently broke that functionality at some point. Rechecked that part and everything works fine now.
  1. List of Views from List of View Names?
    By ryntau in forum Dynamo BIM
    Last Post: September 18th, 2017, 02:16 AM
  2. Create Sheet Set from Sheet list
    By DMapes in forum Dynamo BIM
    Last Post: September 3rd, 2015, 05:19 PM
  3. Sheet list - How can I add a circle or dot parameter relating sheet names to phases?
    By yral87 in forum Architecture and General Revit Questions
    Last Post: May 18th, 2015, 07:48 PM
  4. Sheet Scale in Sheet List
    By irneb in forum Architecture and General Revit Questions
    Last Post: November 19th, 2013, 06:42 AM
  5. Sheet just became a Detail View, but still listed in Sheet List
    By LeanneZ in forum Architecture and General Revit Questions
    Last Post: February 25th, 2011, 09:25 PM
