Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By DaveP
Thread: Dynamo
    February 13, 2019
    1
    04:55 AM
    Lightbulb Dynamo
    Hii,
    I would like to know is it possible in dynamo to change the old revit model parameter in new model like if i want to change a Tank volume of 500KL to 1000 KL, So is it possible to change the volume. And what type of script is needed for that.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,949
    11:55 PM
    Volume is a calculated field, so you can't change that. Not in Dynamo, not in Revit.
    What you can do is use Dynamo to change the diameter or height parameters, which would then change the volume.
    But you have to have built your family with the proper parameters.
    Basically, Dynamo can programatically change any values you can change manually.
    cganiere likes this.
  1. Replies: 3
    Last Post: January 23rd, 2019, 07:52 AM
  2. Replies: 0
    Last Post: August 26th, 2018, 08:15 PM
  3. Replies: 0
    Last Post: October 20th, 2017, 01:15 PM
  4. Replies: 0
    Last Post: November 19th, 2014, 12:45 PM
  5. Replies: 0
    Last Post: August 26th, 2013, 07:45 AM
