Results 1 to 2 of 2
Thread: Installation Dynamo 1.3.2. for Revit 2016
    November 18, 2013
    Germany
    99
    04:54 PM
    Exclamation Installation Dynamo 1.3.2. for Revit 2016
    Hello Dynos,
    I have a Problem: I can't install Dynamo over 0.9. for Revit 2016 Why? I would like to have the core of 1.3.2.
    Right now I have Revit 2016,17,18,19 and Dynamo 2.0.2. on my Laptop
    I have also Dynamo studio with 1.3.4.!
    What should i do ? I already deinstalled all dynamos an reinstall from low to new version - it didn`t work?
    I am glad about any advice
    KR
    Andreas
    Attached Thumbnails Attached Thumbnails Installation Dynamo 1.3.2. for Revit 2016-2019-01-23_12h44_40.png   Installation Dynamo 1.3.2. for Revit 2016-2019-01-23_12h43_34.png
    April 30, 2015
    Michigan
    174
    11:54 AM
    Dynamo only officially support 3 versions of revit at a time so 2016 is out. This link talks about the versions and the headache with dealing with older version of Revit.
    It's possible that you might have thing hanging around from 1.3.3 and 2.0.2. Try a registry repair tool. I had fixit utility by Microsoft recommended to me recently and it worked with removing 1.3.3 core (totally 2.0.2 now). The tool might need the program installed to actually remove everything so you might have to reinstall 1.3.3 and run to tool to uninstall it cleanly.
  1. Dynamo for Rebar installation problem
    By Minsc in forum Dynamo BIM
    Last Post: January 3rd, 2017, 11:08 PM
  2. Revit 2016 Server Installation Question
    By jongesiconsult in forum MEP - General
    Last Post: September 16th, 2016, 08:21 PM
  3. Replies: 0
    Last Post: May 23rd, 2016, 10:15 AM
  4. Replies: 0
    Last Post: March 25th, 2016, 12:15 AM
  5. New Member - Server installation of Revit 2016
    By cmrevit92 in forum Architecture and General Revit Questions
    Last Post: January 7th, 2016, 04:24 PM
