Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Like Tree8Likes
Thread: Get the parameter "Workset"
  1. #11
    May 3, 2012
    1,401
    02:49 AM
    Not near Dynamo, but something similar last week - try:
    Find your elements (by category), use GetParameterValue ("Workset") then filter results using StringContains, push that value into an SP (so you can maintain models on the fly) and set your filters in your VT to look at your hammy-workaround SP instead (forever) - rather than have Dynamo do the colouring in.
    Exactly. Filter visibility by parameter not Workset.
    Also, I dont see how it would cost any more time/effort to select the elements you wish to 'Demo' and change the parameter instead of the workset. A parameter can also be used/managed/checked in Schedules while a workset cant.
    The only situation where I would use a filter by workset is to change the colour of a linked model, as that is pretty much the only way to do it reliably without filtering elements in your own model too.
  2. #12
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    224
    08:49 PM
    Quote Originally Posted by josephpeel View Post
    I was using worksets so that other projects could turn off the workset. This wont work with everyone becuase some disciplines like electrical need to see mechanical equipment demo. Another advantage is that you can set it to be not visible by default which reduces the amount of filters you need in working views. Filters have been a sticking point in my firm. I'm trying to convince people that they should normally be the first option for visibility and removing the need to add one for demo in almost every view would help.
  3. #13
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    319
    02:49 AM
    @Snowy: Here's my quick test .dyn
    Don't think there's a Package Node in there.
    Attached Files Attached Files
    CRapai likes this.
  4. #14
    December 21, 2010
    C.LONDON
    4,382
    01:49 AM
    Quote Originally Posted by CRapai View Post
    What .dyf? Are you looking for a node? I'm confused.
    I'm not after anything - just trying to promote the whole
    "hey y'all, cheers for the help, got it working, and here it is for those who might want to do the same... this place rocks!" vibe.
    Quote Originally Posted by Bjorn_K View Post
    ^ Like this!
    CRapai and elton williams like this.
  5. #15
    April 30, 2015
    Michigan
    224
    08:49 PM
    ^ Like this!
    Oh, I thought it was clear from the screenshot. I guess I was confused by the .dyf instead of .dyn. I'll do you one better than a test. Here is my project startup so far.
    snowyweston likes this.
  6. #16
    December 21, 2010
    C.LONDON
    4,382
    01:49 AM
    Yeah my slapdashery didn't help!
  1. how do i change a component on workset "View XXXX" to another one (its greyed out)
    By shanetuai in forum Architecture and General Revit Questions
    Last Post: February 5th, 2014, 02:52 PM
  2. "caused deletion of non-editable workset..."
    By mfrietze in forum Architecture and General Revit Questions
    Last Post: December 13th, 2013, 09:53 PM
  3. Family Shared Parameter "Group Parameter Under" in a Project
    By Aretap in forum Architecture and General Revit Questions
    Last Post: August 10th, 2012, 10:18 PM
  4. MEP Elements on Workset "Project Info"
    By troygates in forum Worksharing, Revit Server & C4R
    Last Post: June 14th, 2012, 10:26 PM
  5. "Title on Sheet" parameter field" ?
    Last Post: October 17th, 2011, 12:17 AM
