Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Bjorn_K
Thread: New pile numbering
    Member mjajansen's Avatar
    December 26, 2011
    The Netherlands
    168
    06:07 PM
    New pile numbering
    Last week i made my first real Dynamo script to read information from an excel file (which i extracted from Autocad) and it worked perfectly.
    I imported the coordinates and modelled the piles on those spots automatically with the correct coordinates and numbering.
    Now i need to add 2 piles in the middle of the grid and change the numbering of the other piles.
    I want to extract the coordinates again to excel and then renumber the piles in excel, and then import them again to update the numbers on the piles.
    Is this a good though, or do you guys think of better ways to do it.
    I also see some tutorials on numbering with a spline but i don't really want to do that since its 775 piles, but if that's the fastest way i will.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    302
    06:07 PM
    Quote Originally Posted by mjajansen View Post
    Your idea is solid, unless adding the 2 piles causes the renumbering to be systematic, then it might be easier to read the numbers from the piles, seperate into need-to-change, don't-need-to-change, add 2 to all the need-to-change ones and set the parameter values accordingly.
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    401
    10:07 AM
    How did you extract the info from Autocad?
    April 8, 2011
    302
    06:07 PM
    Obviously I'm not OP, but I guess by running DATAEXTRACTION on selected blocks to an Excel file.
    mjajansen likes this.
    December 26, 2011
    The Netherlands
    168
    06:07 PM
    I used dataextraction indeed to get the data from Autocad to Excel.
    And for the renumbering i tried exporting to excel to renumber but the excel table got wonky and wasn't usable so i just user a suffix, now i got a pile numbered 176 and a pile numbered 176a that was just the fastest way to go.
    May 3, 2012
    1,394
    06:07 PM
    How about numbering by location? Something like <XX.X><Y.YY> coordinates, should be accurate enough and you can always add unique numbers between existing piles.
    Or to make it more user freindly use a grid and number them <Grid Letter><Grid Number><XY from grid intersection> so users can find them easily using the two grids.
    Could all be done automatically.
    December 26, 2011
    The Netherlands
    168
    06:07 PM
    The contractor needed the numbers asap and this was fine, so i did not use any more time to fix it.
  1. RCC Pile for foundation
    By lallanji in forum Structure - Family Creation
    Last Post: November 27th, 2014, 05:51 PM
  2. Pile cap moving
    By erasje in forum Structure - General Questions
    Last Post: October 7th, 2014, 09:49 PM
  3. v2014: Pile embedding pile cap visibility
    By phoulx in forum Structure - Family Creation
    Last Post: July 23rd, 2014, 08:12 PM
  4. Pile Cap reference parameter
    By MartinGT in forum Structure - Family Creation
    Last Post: September 26th, 2013, 07:27 AM
  5. Pile cap goes to bottom of Pile?
    By cosmictraveller in forum Structure - General Questions
    Last Post: March 28th, 2013, 06:42 PM
