Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Like Tree5Likes
Thread: Attempting my first Python Node, need some basic help
  1. #11
    February 22, 2013
    316
    12:17 PM
    Quote Originally Posted by josephpeel View Post
    Exactly my experience too! They say things like "Revit doesnt have much to offer for electrical, you can only model cable trays" but electrical systems are so much more logical in their structure and data than mechanical. Even using none of the electrical calcs in Revit and only Types and parameters, it would be so much better for handling their design information...
    Im deliberately avoiding Electrical as I have enough to do with Mechanical, waiting for one of theirs to show an interest or learn dynamo...
    I'm hoping that I can generate some interest in others at my company if I can get this panel schedule tool working. Although it's actually causing some anxiety among the electrical designers, because they spend so much time manually filling out their panel schedules. I told one guy "Well, if it's not me that automates this stuff it'll be someone else later. Don't you want to be the guy who knows how the automation works and not the guy who just puts numbers in boxes?"
    josephpeel likes this.
  2. #12
    February 22, 2013
    316
    12:17 PM
    Okay, so now I'm trying to make a similar custom node that will take the Breaker Size and output a string for the wire size. Can someone tell me what I'm doing wrong here? How do I output a sting value from a code block?
    amps;
    a = [Imperative]
    if(amps=15)
    {return = "#12";
    else
    if(amps=20)
    {return = "#12";
    else
    if(amps=25)
    {return = "#12";
    else
    if(amps=30)
    {return = "#10";
    else
    if(amps=35)
    {return = "#10";
    else
    if(amps=40)
    {return = "#8";
    else
    return = 9999;
  3. #13
    September 19, 2015
    163
    05:17 PM
  4. #14
    February 22, 2013
    316
    12:17 PM
    Thanks!
    I realized my error above: I needed to use "amps==20" and "amps=20."
  1. Revit Error When Attempting to make view title multi-line
    By katewood1989 in forum Architecture and General Revit Questions
    Last Post: July 18th, 2018, 04:22 PM
  2. Replies: 8
    Last Post: April 30th, 2018, 05:00 PM
  3. Amateur attempting to create family title blocks
    By Branston in forum Architecture - Family Creation
    Last Post: January 31st, 2017, 12:21 AM
  4. Basic Rain Screen for a Basic Revit User
    By tyarndt94 in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2016, 01:37 AM
  5. attempting a waffle slab
    Last Post: January 20th, 2012, 06:00 PM
