Results 1 to 2 of 2
Thread: Help designating a point on a plan and calculating distance to object above
    November 29, 2018
    1
    09:00 AM
    Hey,
    I'm entirely new to dynamo and could use some help to understand why my code wont work. What I am trying to accomplish is to define a point on my plan, and to be given the distance to any object directly above it (complex ceiling or beam for example).
    I found this rather complex example: https://revitbeyondbim.wordpress.com...tch-your-head/
    and had the idea of using the same method of a raybounce, originating at a spot elevation instead, but it isnt working. Any ideas?
    https://imgur.com/bRWNWsI
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,124
    04:00 AM
    Take a look at what Aaron posted here: https://www.revitforum.org/architect...tml#post212061
  1. Moving an object base on a reference point
    By mhicks in forum Tutorials, Tips & Tricks
    Last Post: July 25th, 2016, 12:18 PM
  2. Hiding 3D object in Plan view not working
    By Rshub1 in forum MEP - Family Creation
    Last Post: July 12th, 2016, 02:05 PM
  3. Adding Distance from a Point to Structural Schedules
    By DGuingrich in forum Structure - General Questions
    Last Post: March 20th, 2016, 04:39 PM
  4. How to make a fixed distance from the driving point?
    By leobee in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 8th, 2014, 02:29 AM
  5. copy and paste an object with exact distance
    By pixpast in forum Structure - General Questions
    Last Post: January 7th, 2013, 12:56 PM
