Results 1 to 4 of 4
Thread: Autocad 2d to Revit object/family by Dynamo
    November 27, 2018
    1
    12:36 PM
    Good evening,
    I hope someone can help me, I have been looking for a long time. I have been looking for tutorials for some time to connect 2D autocad lines to objects / families of revit. Is there a standard script or tutorial that tells how I can convert a 2D line of for example a curb into a revit object?
    thanks in advance
    May 3, 2012
    1,401
    01:36 PM
    There is a package called 'LinkDWG' that includes some useful stuff. It has some ActiveX tools that can import selected objects, lines or layers directly from an active dwg. Then you could write the curves into a Drafting View, Detail Item or other 2D sketch using the various Revit Line From Curve nodes.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,486
    04:36 AM
    Quote Originally Posted by Fransm View Post
    Good evening,
    thanks in advance
    Check out PowerConvert from ArchSmarter. It's a small cost app that works great for CAD 2D lines to Revit lines in the family or project environment.
    October 14, 2017
    London
    7
    12:36 PM
    You can use BimorphNodes CAD.DetailCurvesFromCADLayers or CAD.SymbolicCurvesFromCADLayers nodes for creating curves from CAD links or imports. There are inputs for filtering by layer too. More info here if it's suitable for your workflow:
    https://bimorph.com/bimorph-nodes/sy...om-cad-layers/
  1. Replies: 7
    Last Post: April 24th, 2017, 05:52 AM
  2. Revit Family Imported from Autocad
    By awa5114 in forum Architecture and General Revit Questions
    Last Post: June 5th, 2016, 07:58 PM
  3. Revit Family Label on face based object
    By Charlie0825 in forum Architecture and General Revit Questions
    Last Post: February 28th, 2016, 07:25 PM
  4. Replies: 0
    Last Post: May 12th, 2014, 04:45 AM
  5. Toposurface into AutoCAD Civil 3D as a surface object
    By Alexander_J_Hicks in forum Structure - Interoperability
    Last Post: December 11th, 2013, 09:44 PM
