Results 1 to 2 of 2
Thread: Revit 2019.1 Dynamo Player Not Opening
    Member ecraider's Avatar
    May 19, 2014
    Concord, CA
    87
    10:29 PM
    When I try to open Dynamo Player in Revit 2019.1 nothing happens.......
    I click the button on the ribbon, CPU starts acting like it is opening something.... then nothing opens and my dynamo player button grays-out like it is open.
    This just started happening. I tried disabling plug-ins, reinstalling revit, still no luck.
    Has anyone experienced this or know of a fix?
    May 19, 2014
    Concord, CA
    87
    10:29 PM
    https://forum.dynamobim.com/t/dynamo...-ghost/18249/6
    Looks Like I have found my solution... I will give this a try and let you all know if it works.
    Yes this is your answer if you ever have this problem!
    go to this folder and delete it:
    C:\Users–youruser–\AppData\Local\dynamoplayer
  1. Replies: 0
    Last Post: May 2nd, 2018, 09:15 AM
  2. Dynamo for 2019 does not support 2016
    By DaveP in forum Architecture and General Revit Questions
    Last Post: April 11th, 2018, 10:45 PM
  3. Dynamo Player
    By snowyweston in forum Dynamo BIM
    Last Post: April 3rd, 2018, 02:19 PM
  4. Alphabetize the Scripts in the Player?
    By safoulkes in forum Dynamo BIM
    Last Post: January 29th, 2018, 07:34 PM
  5. Replies: 0
    Last Post: February 29th, 2012, 12:15 AM
Tags for this Thread
