Results 1 to 3 of 3
Like Tree4Likes
  • 1 Post By DanielHurtubise
  • 3 Post By engineer
Thread: Get cable trays that are vertical
    August 29, 2015
    95
    01:11 PM
    Hello!
    Is there a easy way to se if a cable tray is vertical? Maybe only read a parameter? Or do i have to calculate it with bottom and top elvation and length?
    Best regards Engineer
    February 2, 2011
    Montreal/Paris
    830
    08:11 AM
    Here's a way
    amoursol likes this.
    August 29, 2015
    95
    01:11 PM
    Quote Originally Posted by DanielHurtubise View Post
    Here's a way
    Thank you, i will try it. I solved it with the formula IF (top elevation-bottom elevation)==length then it is vertical.
    josephpeel, Ning Zhou and amoursol like this.
  1. Cable Trays = System Family?
    By ricksaus in forum Architecture and General Revit Questions
    Last Post: October 24th, 2017, 03:47 PM
  2. Copy / monitor Cable trays and ducts
    By Byrne in forum Tutorials, Tips & Tricks
    Last Post: January 21st, 2016, 10:25 AM
  3. Make different Tags as default at different Cable Trays
    By engineer in forum MEP - General
    Last Post: October 20th, 2015, 03:41 PM
  4. Electrical Cable trays
    By RAJESH87 in forum MEP - General
    Last Post: November 4th, 2014, 08:31 AM
  5. Cable Trays & Colours
    By domsib in forum MEP - General
    Last Post: July 17th, 2014, 04:14 PM
