Results 1 to 10 of 10
Like Tree4Likes
  • 3 Post By Bjorn_K
  • 1 Post By tuekappel
Thread: Renumber sheets while maintaining x.number suffixes?
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    442
    11:55 AM
    I have over 100 sheets that I need to renumber, but several groups of sheets have a number with a x.1, x.2 suffix and so on. I'd like to renumber the sheets while maintaining those number suffixes. Is that possible with Dynamo or macros?
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    322
    04:55 PM
    Could you give an example of 10 sheet numbers, old and new name, I'd like to give it a try
    Sendt fra min ONEPLUS A5000 med Tapatalk
    Gold Coast
    2,602
    02:55 AM
    It would be really easy with Dynamo to export/import via excel.
    July 7, 2017
    Hernando, MS
    442
    11:55 AM
    So I might have sheets:
    117
    118
    119.1
    119.2
    120.1
    120.2
    and I need to stick a sheet in after 117, so all the sheet numbers after 117 need to increase by one, but the .1 and .2 needs to stay the same, so 119.1 becomes 120.1 and 120.2, and 120.1 becomes 121.1 and 121.2 and so on.
    Gold Coast
    2,602
    02:55 AM
    Quote Originally Posted by PatrickGSR94 View Post
    117
    118
    119.1
    119.2
    120.1
    120.2
    Have a look at pyrevit, it has a function to increment sheet numbers, no excel needed.
    July 7, 2017
    Hernando, MS
    442
    11:55 AM
    Oh well, I went ahead and just renumbered the sheets manually. 100 sheets only took about 5 minutes to renumber in a schedule, starting at the bottom and going up, increasing each sheet number by 2 so that I could add in 2 sheets.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    313
    06:55 PM
    This is how it looks in the player.
    This should do it, fun little exercise to quickly build. Only needs a single Clockwork and Rhythem node. Rest is OOTB. Dynamo 1.3.3, Revit 2018.3
    If you want my Revit test file give me a shout, just a little to big for the upload limit.
    Attached Files Attached Files
    tuekappel, cellophane and amoursol like this.
    July 7, 2017
    Hernando, MS
    442
    11:55 AM
    ugh I need to learn how to do that. 15 year Revit veteran here, but I know zilch about Dynamo.
    February 6, 2012
    322
    04:55 PM
    Less than an hour after you posed your question, you solved it by hand.
    I love a good challenge, but next time: please let us know if you're really stuck, or you are just venting frustration......
    -People here actually do hard work to help each other out, please respect that.
    Yna_Db likes this.
    July 7, 2017
    Hernando, MS
    442
    11:55 AM
    say what? Come on I was in a time crunch and needed to get it done. But I'll look into this further for future renumbering needs.
  1. Replies: 0
    Last Post: July 2nd, 2018, 02:45 AM
  2. Replies: 0
    Last Post: July 2nd, 2018, 02:15 AM
  3. Replies: 0
  4. Replies: 0
    Last Post: March 21st, 2017, 01:45 AM
  5. Replies: 20
    Last Post: November 23rd, 2015, 09:31 AM
