Results 1 to 3 of 3
Like Tree4Likes
  • 1 Post By cellersick
  • 3 Post By Aaron_J_Clark
Thread: Trying to iterate through a list of strings
    August 24, 2018
    3
    10:08 AM
    Hi Team,
    Maybe one you gurus can help me out. I'm trying to step through a list of strings assigning each one to an instance parameter of a different notation. The idea was to read a list in from excel and then make an annotation for each entry. The watch in the lower left is that list I'm trying to step through. I guess I'm trying to wrap my head around doing without a ForEach loop function. Thanks folks!
    Attached Thumbnails Attached Thumbnails Trying to iterate through a list of strings-9-11-2018-8-51-16-am.png
    March 21, 2013
    Phoenix, AZ
    275
    10:08 AM
    Dynamo is more list-based than object-based, so you have to alter your style a bit. "Lacing" is what controls how the lists are handled / iterated over; if your lists are the same length it will iterate through the same index of each list. Get your list of elements to match your list of IDs and feed that to the SetParameterByName node.
    Joe_Charpentier likes this.
    August 24, 2018
    3
    10:08 AM
    Thank you for explaining that. I was trying to wrap my head around looping in dynamo and after thinking about your post it just clicked and I went from using about seventy nodes to accomplish what I was trying to do to about seven.
    Thanks again!
  1. Replies: 0
    Last Post: March 24th, 2017, 06:16 AM
  2. Replies: 0
  3. Text in Dimension Strings
    By sblosse in forum Architecture and General Revit Questions
    Last Post: October 2nd, 2015, 12:00 AM
  4. Building Coder: Change Type, Iterate Elements, Create Family
    Last Post: September 25th, 2015, 03:15 PM
  5. Nesting parameter values in text strings
    By cellophane in forum Architecture - Family Creation
    Last Post: May 30th, 2012, 03:03 PM
